Define config USB_STORAGE through defconfig for all
respective zynq boards
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Add Kconfig entry config option for USB_EHCI_ZYNQ
and update the same to enable for all zynq boards
which supports USB
Compile SPL for all boards even psu_init.c/h files are not in the tree
yet. But this change enables covering SPL issues in mainline.
Serial driver starts to use clk framework that's why
enable it by default.
Based on:
"ARM: uniphier: use the default CONFIG_BOOTDELAY=2"
(sha1: 7c8ef0feb97586d35b0296b48903daef8c06ab21)
"I do not insist on CONFIG_BOOTDELAY=3. The default value in Kconfig,
CONFIG_BOOTDELAY=2, is just fine for these boards."
Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com>
For mpc85xx SoCs, the core begins execution from address 0xFFFFFFFC.
In non-secure boot scenario from NAND, this address will map to CPC
configured as SRAM. But in case of secure boot, this default address
always maps to IBR (Internal Boot ROM).
The IBR code requires that the bootloader(U-boot) must lie in 0 to 3.5G
address space i.e. 0x0 - 0xDFFFFFFF.
For secure boot target from NAND, the text base for SPL is kept same as
non-secure boot target i.e. 0xFFFx_xxxx but the SPL U-boot binary will
be copied to CPC configured as SRAM with address in 0-3.5G(0xBFFC_0000)
As a the virtual and physical address of CPC would be different. The
virtual address 0xFFFx_xxxx needs to be mapped to physical address
0xBFFx_xxxx.
Create a new PBI file to configure CPC as SRAM with address 0xBFFC0000
and update DCFG SCRTACH1 register with location of Header required for
secure boot.
The changes are similar to
commit 467a40dfe35f48d830f01a72617207d03ca85b4d
powerpc/mpc85xx: SECURE BOOT- NAND secure boot target for P3041
While P3041 has a 1MB CPC and does not require SPL. On T104x, CPC
is only 256K and thus SPL framework is used.
The changes are only applicable for SPL U-Boot running out of CPC SRAM
and not the next level U-Boot loaded on DDR.
Reviewed-by: Ruchika Gupta <ruchika.gupta@nxp.com>
Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com>
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
There are multiple versions of p2771-0000 board. There are SW visible
incompatible differences between the versions, and they are relevant to
U-Boot. Create separate "A02" and "B00" defconfigs (named after the first
and/or only board rev the defconfig supports) so that users can select
which build they want.
With the minimal set of HW currently enabled in U-Boot, the differences
are irrelevant, hence the DT files aren't different. However, that will
change in a future patch.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Use existing Kconfig symbols to let the user configure whether to
build a U-Boot with non-secure mode support or not. This also allows
to enable virtualization extension easily.
Add a new config CONFIG_MXC_USB_OTG_HACTIVE which configures the
OTG Power Pin to be high active. Low active is the reset value
of the affected configuration register, hence the config option
is named by the non-reset configuration.
Create an entry for "config USB_EHCI_MX7" in Kconfig and
switch over to it for all boards.
It's not necessary anymore to declare the CONFIG_BOOTDELAY variable,
it's already set by default as 2 seconds.
Signed-off-by: Breno Lima <breno.lima@nxp.com>
Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
The Orange Pi Lite SBC is a small H3 based SBC, with 512MB RAM,
micro-sd slot, HDMI out, 2 USB-A connectors, 1 micro-USB connector,
sdio attached rtl8189ftv wifi and an ir receiver.
The dts file is identical to the one submitted to the upstream kernel.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
The Plus variant of the Orange Pi PC has an eMMC, add support for this.
Note we are using the same u-boot defconfig / dts for both the regular
Orange Pi PC as well as the Orange Pi PC Plus.
This patch add EMAC driver support for H3/A83T/A64 SoCs.
Tested on Pine64(A64-External PHY) and Orangepipc(H3-Internal PHY).
BIG Thanks to Andre for providing some of the DT code.
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
As an experiment, move this board over to use of-platdata. This means that
its SPL configuration will come from C structures generated at build-time
from the device tree, instead of coming from the device tree at run-time.
Enable this feature so that we can use it for testing in sandbox_spl.
It is useful to be able to build SPL for sandbox. It provides additional
build coverage and allows SPL features to be tested in sandbox. However
it does not need worthwhile to always create an SPL build. It nearly
doubles the build time and the feature is (so far) seldom used.
So for now, create a separate build target for sandbox SPL. This allows
experimentation with this new feature without impacting existing workflows.
Enable bootz command on Texas Instruments DA850 EVM
board. This helps it boot zImage with device-tree
blob passed.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Tested-by: Kevin Hilman <khilman@baylibre.com>
Modify the SPL build procedure for AM437x high-security (HS) device
variants to create a secure u-boot_HS.img FIT blob that contains U-Boot
and DTB artifacts signed (and optionally encrypted) with a TI-specific
process based on the CONFIG_TI_SECURE_DEVICE config option and the
externally-provided image signing tool.
Also populate the corresponding FIT image post processing call to be
performed during SPL runtime.
Signed-off-by: Madan Srinivas <madans@ti.com>
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
Modify the SPL build procedure for AM57xx and DRA7xx high-security (HS)
device variants to create a secure u-boot_HS.img FIT blob that contains
U-Boot and DTB artifacts signed with a TI-specific process based on the
CONFIG_TI_SECURE_DEVICE config option and the externally-provided image
signing tool.
Signed-off-by: Daniel Allred <d-allred@ti.com>
DFU is a convenient way to program U-boot binary into the eMMC.
Add support for it.
Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Booting a NXP kernel with mainline U-boot leads to the following kernel
crash:
caam: probe of 30900000.caam failed with error -11
Unable to handle kernel NULL pointer dereference at virtual address 00000004
pgd = 80004000
[00000004] *pgd=00000000
Internal error: Oops: 805 [#1] PREEMPT SMP ARM
This happens because NXP kernel expects MX7 to boot in secure mode,
so introduce mx7dsabresd_secure_defconfig that selects CONFIG_MX7_SEC
and allows booting a NXP provided kernel successfully.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Add Phytec-i.MX6 SOM with NAND
Support:
- 1GB RAM
- Ethernet
- SPI-NOR Flash
- NAND (1024 MB)
- external SD
- UART
Custom Board based on MX6 Dual, 1GB RAM and eMMC.
There are two variants of the board with and without
PCIe (ZC5202 and ZC5601).
Add support for Advantech SOM-DB5800 with the SOM-6867 installed.
This is very similar to conga-qeval20-qa3-e3845 in that there is a
reference carrier board (SOM-DB5800) with a Baytrail based SoM (SOM-6867)
installed.
Currently supported:
- 2x UART (From ITE EC on SOM-6867) routed to COM3/4 connectors on
SOM-DB5800.
- 4x USB 2.0 (EHCI)
- Video
- SATA
- Ethernet
- PCIe
- Realtek ALC892 HD Audio
Pad configuration for HDA_RSTB, HDA_SYNC, HDA_CLK, HDA_SDO
HDA_SDI0 is set in DT to enable HD Audio codec.
Pin defaults for codec pin complexs are not changed.
Not supported:
- Winbond Super I/O (Must be disabled with jumpers on SOM-DB8500)
- USB 3.0 (XHCI)
- TPM
Signed-off-by: George McCollister <george.mccollister@gmail.com>
This patch adds support to enable and use the internal BayTrail UART
instead of the one integrated in the Super IO Winbond chip. For this,
a 2nd defconfig file is added.
This is useful for tests done for the congatec SoM used on baseboards
without such a Super IO chip.
Cc: Bin Meng <bmeng.cn@gmail.com>
There are quite a number of BayTrail boards that uses an external
SuperIO chipset to provide the legacy UART. For such cases, it's
better to have a Kconfig option to enable the internal UART.
So far BayleyBay and MinnowMax boards are using internal UART as
the U-Boot console, enable this on these two boards.
Update this board to use driver model for block devices and MMC operations.
Update the sandbox MMC emulation to use driver model for MMC operations.
Enable Cadence QSPI controller support to use QSPI on K2G SoC. Also
enable Spansion flash support to access s25fl512s flash present on K2G
QSPI bus.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Jagan Teki <jteki@openedev.com>
Enable SPI and SPI Flash driver model as K2G SPI controller driver
supports driver model.
Enable SPI and SPI Flash driver model as K2L SPI controller driver
Enable SPI and SPI Flash driver model as K2E SPI controller driver
Enable SPI and SPI Flash driver model as K2HK SPI controller driver
We have standard drivers for panels and backlights which can do most of the
work for us. Move the tegra20 LCD driver over to use those instead of custom
code.
This patch includes device tree changes for the nvidia boards. I have only
been able to test seaboard. If this patch is applied, these boards will
also need to be synced with the kernel, and updated to use display-timings:
- colibri
- medcom-wide
- paz00
- tec
The Parrot Board is an evaluation board with an Allwinner R16 (assumed
to be close to an Allwinner A33), 4GB of eMMC, 512MB of RAM, USB host
and OTG, a WiFi/Bluetooth combo chip, a micro SD Card reader, 2
controllable buttons, an LVDS port with separated backlight and
capacitive touch panel ports, an audio/microphone jack, a camera CSI
port, 2 sets of 22 GPIOs and an accelerometer.
The DTS file is identical to the one submitted to the upstream kernel.
Signed-off-by: Quentin Schulz <quentin.schulz@free-electrons.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2
means the autoboot with no delay, with no abort check even if
CONFIG_ZERO_BOOTDELAY_CHECK is defined.
To sum up, the autoboot behaves as follows:
[1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y
autoboot with no delay, but you can abort it by key input
[2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n
autoboot with no delay, with no check for abort
[3] CONFIG_BOOTDELAY=-1
disable autoboot
[4] CONFIG_BOOTDELAY=-2
As you notice, [2] and [4] come to the same result, which means we
do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the
cases only by CONFIG_BOOTDELAY, like this:
[2] CONFIG_BOOTDELAY=-1
disable autoboot
[3] CONFIG_BOOTDELAY=-2
This commit converts the logic as follow:
--> CONFIG_BOOTDELAY=-2
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Christian Riesch <christian.riesch@omicronenergy.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
This recently added board missed the tree-wide migration of
CONFIG_BOOTDELAY.
Acked-by: Pavel Machek <pavel@denx.de>
Align the name of the defconfig file for high-security (HS) device variants
from the AM43xx family of SoCs with the corresponding name used for the
general purpose devices. This allows for easier cross-association of those
files and also provides room to grow from an HS device part number
perspective.
Furthermore, update and cleanup associated MAINTAINERS file.
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Madan Srinivas <madans@ti.com>
add DM and DTS support for the at91 based siemens
boards.
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
[rebased on current ToT]
Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
[rebase on current ToT, don't delete gurnard DTB creation]
Rename B&R kwb board to brxre1
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Rename B&R tseries board to brppt1
