This commit moves:
CONFIG_OF_CONTROL
CONFIG_OF_SEPARATE
CONFIG_OF_EMBED
CONFIG_OF_HOSTFILE
Because these options are currently not supported for SPL,
the "Device Tree Control" menu does not appear in the SPL
configuration.
Note:
zynq-common.h should be adjusted so as not to change the
default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME.
Cc: Stephen Warren <swarren@nvidia.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Since CONFIG_CMD_IMPORTENV is defined in config_cmd_defaults.h,
it should be enabled for all the boards except bf506f-ezkit
that undefs it explicitely.
Since CONFIG_CMD_EXPORTENV is defined in config_cmd_defaults.h,
Since CONFIG_CMD_CRC32 is defined in config_cmd_defaults.h,
it is enabled for all the boards except the ones undefining it
explicitly:
kwb
tseries_mmc
tseries_nand
tseries_spi
vct_platinum_onenand_small
vct_platinum_small
vct_platinumavc_onenand_small
vct_platinumavc_small
vct_premium_onenand_small
vct_premium_small
The default value of this config option should be "y" and
"# CONFIG_CMD_CRC32 is not set" should be added for those exceptions.
CONFIG_CMD_BOOTM is defined in config_cmd_defaults.h
which is forcebly included from each board.
So, the default value of "config CMD_BOOTM" should be "y".
For some boards undefining it (bf506f-ezkit, controlcenterd_TRAILBLA,
controlcenterd_TRAILBLAZER_DEVELOP, controlcenterd_TRAILBLAZER),
"# CONFIG_CMD_BOOTM is not set" should be added to their defconfig.
If this option is enabled, the objects under lib/ directory
are compiled with speed optimization, not size optimization.
(Currently, only used by some Blackfin boards.)
We do not have to distinguish CONFIG_TARGET_VEXPRESS_AEMV8A_SEMI
from CONFIG_TARGET_VEXPRESS_AEMV8A. Rename the former to the latter.
Reviewed-by: Steve Rae <srae@broadcom.com>
Cc: David Feng <fenghua@phytium.com.cn>
Currently mx6dlsabresd shares the same DCD settings with the nitrogen board.
Provide a DCD configuration file specific to mx6dlsabresd with the settings
recommended by the Freescale hardware team.
Add initial support for Compulab CM-FX6 CoM.
Support includes MMC, SPI flash, and SPL with dynamic DRAM detection.
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
LS102xA is an ARMv7 implementation. This patch is to add
basic support for LS1021ATWR board.
One DDR controller
DUART1 is used as the console
For the detail board information, please refer to README.
Signed-off-by: Chen Lu <chen.lu@freescale.com>
Signed-off-by: Yuan Yao <yao.yuan@freescale.com>
Signed-off-by: Alison Wang <alison.wang@freescale.com>
basic support for LS1021AQDS board.
One DDR controller
Signed-off-by: Jason Jin <jason.jin@freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
This patch adds support for Olimex A20-OLinuXino-LIME board.
Signed-off-by: FUKAUMI Naoki <naobsd@gmail.com>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Patch is the result of:
sed -i -e 's/FTDFILE/FDTFILE/g' board/sunxi/Kconfig configs/* include/configs/sunxi-common.h
sed -i -e 's/ftdfile/fdtfile/g' board/sunxi/Kconfig
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Acked-by: Hans de Goede <hdegoede@redhat.com>
[ ijc -- s/Spotted-by/Reported-by/ and resolve conflict vs "remove
redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONS" ]
CONFIG_SPL is defined as a primary option in Kconfig.
It should not be added to CONFIG_SYS_EXTRA_OPTIONS.
This config is valid for two devices:
- Odroid X2,
- Odroid U3.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
The QS Systems TQMa6 board support was added by commit cb07d74e
and lost by commit e82abaeb.
Commit e82abaeb merged the IMX branch based on pre-Kconfig
and the mainline based on post-Kconfig, simply deleting
the boards.cfg file. As a result, some boards added just before
the merge were lost.
This commit adds Kconfig, defconfig, MAINTAINERS for TQMa6 board
to work on the Kconfig infrastructure.
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Becuase the board select menu in arch/arm/Kconfig is too big,
move the Nomadik board select menu to nomadik/Kconfig.
Move also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="nomadik").
Move Highbank-specific settings to highbank/Kconfig.
Cc: Rob Herring <robh@kernel.org>
move the Orion5x board select menu to orion5x/Kconfig.
CONFIG_SYS_SOC="orion5x").
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
move the Keystone board select menu to keystone/Kconfig.
Move also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="keystone").
Reviewed-by: Tom Rini <trini@ti.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
move the OMAP5 board select menu to omap5/Kconfig.
CONFIG_SYS_SOC="omap5").
Cc: Lokesh Vutla <lokeshvutla@ti.com>
move the OMAP4 board select menu to omap4/Kconfig.
CONFIG_SYS_SOC="omap4").
move the OMAP3 board select menu to omap3/Kconfig.
CONFIG_SYS_SOC="omap3
move the Davinci board select menu to davinci/Kconfig.
CONFIG_SYS_SOC="davinci").
Cc: Sandeep Paulraj <s-paulraj@ti.com>
move the Exynos board select menu to exynos/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="exynos").
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
move the KirkWood board select menu to kirkwood/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="kirkwood").
Acked-by: Prafulla Wadasdkar <prafulla@marvell.com>
Cc: Luka Perkov <luka@openwrt.org>
Move Versatile-specific settings to versatile/Kconfig.
move the Rmobile board select menu to rmobile/Kconfig.
CONFIG_SYS_SOC="rmobile").
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
move the Tegra board select menu to tegra/Kconfig.
Insert the Tegra SoC select menu between the arch select and the
board select.
Architecture select
|-- Tegra Platform (Tegra)
|- Tegra SoC select (Tegra20 / 30 / 114 / 124)
|- Board select
CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows:
config TEGRA
bool
select SPL
Cc: Tom Warren <twarren@nvidia.com>
move the Zynq board select menu to zynq/Kconfig.
CONFIG_SYS_SOC="zynq").
Refactor board/xilinx/zynq/MAINTAINERS too.
Tested-by: Michal Simek <michal.simek@xilinx.com>
Convert the bcm958300k and the bcm958622hr boards from "boards.cfg" to Kconfig.
Signed-off-by: Steve Rae <srae@broadcom.com>
Add board which has Broadcom StarFighter2 Ethernet capability.
- Drop CONFIG_SERIAL[1-6] and use CONFIG_CONS_INDEX tests instead
- Add choice and help text to board/ti/am335x/Kconfig
- Correct comment about IDK in board/ti/am335x/mux.c
- Remove am335x_evm_uart* defconfig files as they're just variations
on a config option now.
This board has been orphaned for a while and old enough.
These boards have been orphaned for a while and old enough.
Emails to the board maintainer
"Rishi Bhattacharya <rishi@ti.com>"
have been bouncing.
Tom suggested to remove this board.
Remove also omap1510_udc.c because this is the last board
to enable it.
Suggested-by: Tom Rini <trini@ti.com>
mx6sxsabresd was not in the master branch when the conversion to the new Kconfig
style happened, so convert it now so that it can build again.
