path: root/configs
2019-06-14sh: ap_sh4a_4a: Remove the boardMarek Vasut
Last change to this board was done in 2016, has no prospects of ever being converted to DM, drop it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Chris Brandt <chris.brandt@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Vladimir Zapolskiy <vz@mleia.com> Cc: Yoshihiro Shimoda <shimoda.yoshihiro.uh@renesas.com>
2019-06-14sh: ms7750se: Remove the boardMarek Vasut
2019-06-14sh: ms7722: Remove the boardMarek Vasut
2019-06-14sh: espt_giga: Remove the boardMarek Vasut
2019-06-13configs: Disable now unbuildable SPI options for boardsTom Rini
Now that various SPI related options depend on CONFIG_DEPRECATED, in order for platforms to build out of the box they need to disable various other options. Cc: Albert ARIBAUD <albert.aribaud@3adev.fr> Cc: Marek Vasut <marex@denx.de> Cc: Vladimir Zapolskiy <vz@mleia.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-13arm: Remove zipitz2 boardTom Rini
Per discussion on the list, drop this board again. Cc: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Vasily Khoruzhick <anarsoul@gmail.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-12ARM: defconfig: add Raspberry Pi 3 Model B+Heinrich Schuchardt
Provide a defconfig file for the Raspberry Pi 3 Model B+. It is based on the Raspberry Pi 3 file, just changing the device tree. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-06-11Merge tag 'u-boot-stm32-20190606' of https://github.com/pchotard/u-bootTom Rini
- Add Ethernet support for STM32MP1 - Add saveenv support for STM32MP1 - Add STM32MP1 Avenger96 board support - Add SPI driver suport for STM32MP1 - Add watchdog support for STM32MP1 - Update power supply check via USB TYPE-C for STM32MP1 discovery board
2019-06-11Merge tag 'u-boot-imx-20190612' of git://git.denx.de/u-boot-imxTom Rini
u-boot-imx-20190612 -------------------- - Board fixes: - imx6logic - wandboard - mx6sabre boots again - imx8qm_mek - pico-* boards - Toradex apalis / colibri - engicam imx6 (environment) - KP MX53 - opos6ul - Switch to DM: - vining2000 - dh MX6 - Toradex colibri i.MX7 - Novena - Security : fix CSF size for HAB - Other: - imx: fix building for i.mx8 without spl - pcie and switch to DM mx6sabreauto: Enable SPL SDP support
2019-06-11configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORTHeinrich Schuchardt
The SPL for the Tinker Board has to fit into 32 KiB. Currently this limit is exceeded. CONFIG_SPL_I2C_SUPPORT is not needed to move to main U-Boot. So let's disable it. Suggested-by: David Wu <david.wu@rock-chips.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: David Wu <david.wu@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-06-11mx6sabreauto: Enable SPL SDP supportSjoerd Simons
To allow loading u-boot over USB enable SDP support in the SPL. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-06-11mx6sabreauto: Remove CONFIG_SPL_DM to decrease the SPL sizeSjoerd Simons
The i.mx6 SPL binary cannot be bigger then 68K, while with the current defconfig for sabreauto it's only about 56K as soon as USB support gets added the size will overflows. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-06-11mx6sabreauto: set SYS_MALLOC_F for videoSjoerd Simons
Sabre Auto boards currently hang with: ``` U-Boot 2019.07-rc3-00057-gc41940c406 (Jun 03 2019 - 14:42:41 +0200) CPU: Freescale i.MX6QP rev1.0 996 MHz (running at 792 MHz) CPU: Automotive temperature grade (-40C to 125C)Reset cause: WDOG Model: Freescale i.MX6 Quad Plus SABRE Automotive Board Board: MX6Q-Sabreauto revA I2C: ready DRAM: 2 GiB Video device 'ipu@2400000' cannot allocate frame buffer memory -ensure the device is set up before relocation Error binding driver 'ipuv3_video': -28 Video device 'ipu@2800000' cannot allocate frame buffer memory -ensure the device is set up before relocation Error binding driver 'ipuv3_video': -28 Some drivers failed to bind Error binding driver 'generic_simple_bus': -28 Some drivers failed to bind initcall sequence 8ffe00b8 failed at call 1780e93b (err=-28) ``` Set SYS_MALLOC_F_LEN to reserve_video to work. This is similar to the change Peng Fan did for mx6sabresd (9002e735e717) Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2019-06-11mx6sabreauto: Select pinctrl driverSjoerd Simons
With the conversion to DM we should select the pinctrl driver. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2019-06-11ARM: imx: vining2000: Enable DM SerialMarek Vasut
Enable DM Serial support on iMX6SX VINING|2000. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: vining2000: Enable DM PCIMarek Vasut
Enable DM PCI support on iMX6SX VINING|2000. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: vining2000: Enable DM GPIOMarek Vasut
Enable DM GPIO support on iMX6SX VINING|2000 and fix up board code where applicable. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: vining2000: Enable DM USBMarek Vasut
Enable DM USB support on iMX6SX VINING|2000. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: vining2000: Convert MMC and block to DMMarek Vasut
Enable DM block and DM MMC support on iMX6SX VINING|2000 . Convert board code to match the DM support. This disables USB mass storage support due to missing DM USB, however that will be re-enabled in subsequent patch. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: vining2000: Enable DM pin controlMarek Vasut
Enable DM pin control support on iMX6SX VINING|2000. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: dts: imx: vining2000: Import VINING|2000 DT from LinuxMarek Vasut
Import iMX6SX VINING|2000 device tree from Linux 5.1.1 b724e9356404 . Enable DT control in full U-Boot . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: Rename VINING|2000Marek Vasut
The company Samtec was merged into Softing, migrate the board over to the new name and update copyright headers. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: novena: Enable DM PCIMarek Vasut
Enable DM PCI support on iMX6Q Novena. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-11mx6sabresd: Select pinctrl driverFabio Estevam
With the conversion to DM we should select the pinctrl driver. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-06-11mx6sabresd: Remove CONFIG_SPL_DM to decrease the SPL sizeFabio Estevam
Currently the mx6qsabresd board does not boot: U-Boot SPL 2019.07-rc2 (May 16 2019 - 14:28:55 -0300) Trying to boot from MMC1 spl: could not find mmc device 0. error: -19 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### The reason for the boot failure is that that the SPL size got greater than the 68KB limit (4KB header + 64KB max size) as explained in include/configs/imx6_spl.h. Remove the CONFIG_SPL_DM option, so that the SPL binary could fit into the allowed size and the board can boot again. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-06-11imx: Extend PCL063 support for phyCORE-i.MX6ULL SOMParthiban Nallathambi
Extend PHYTEC phyBOARD-i.MX6UL for phyCORE-i.MX6UL SoM (PCL063) with eMMC on SoM. CPU: Freescale i.MX6ULL rev1.0 792 MHz (running at 396 MHz) CPU: Industrial temperature grade (-40C to 105C) at 38C Reset cause: POR Model: Phytec phyBOARD-i.MX6ULL-Segin SBC Board: PHYTEC phyCORE-i.MX6ULL DRAM: 256 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial@02020000 Out: serial@02020000 Err: serial@02020000 Net: FEC0 Working: - Eth0 - i2C - MMC/SD - eMMC - UART (1 & 5) - USB (host & otg) Signed-off-by: Parthiban Nallathambi <parthitce@gmail.com>
2019-06-11board: toradex: add apalis imx8qm 4gb wb it v1.0b module supportMarcel Ziswiler
This commit adds initial support for the Toradex Apalis iMX8QM 4GB WB IT V1.0B module. Unlike the V1.0A early access samples exclusively booting from SD card, they are now strapped to boot from eFuses which are factory fused to properly boot from their on-module eMMC. U-Boot supports either booting from the on-module eMMC or may be used for recovery purpose using the universal update utility (uuu) aka mfgtools 3.0. Functionality wise the following is known to be working: - eMMC, 8-bit and 4-bit MMC/SD card slots - Gigabit Ethernet - GPIOs - I2C Unfortunately, there is no USB functionality for the i.MX 8QM as of yet. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-11colibri_imx7: fastboot supportIgor Opaniuk
Enable fastboot support (including "fastboot oem" subset of commands). Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-06-11ARM: imx: novena: Convert to DM VIDEOMarek Vasut
Enable DM Video support on iMX6Q Novena and fix minor details to restore previous behavior of the system. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-11ARM: imx: novena: Enable DM USBMarek Vasut
Enable DM USB support on iMX6Q Novena. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-11ARM: imx: novena: Convert block devices to DMMarek Vasut
Enable DM block, DM MMC and DM SATA support on iMX6Q Novena convert board code to match the DM support. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-11ARM: imx: novena: Enable DM GPIOMarek Vasut
Enable DM GPIO support on iMX6Q Novena and fix up board code where applicable. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-11ARM: imx: novena: Enable DM pin controlMarek Vasut
Enable DM pin control support on iMX6Q Novena. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-11ARM: dts: imx: novena: Import Novena DT from LinuxMarek Vasut
Import iMX6Q Novena device tree from Linux 5.1-rc7 37624b58542f . Enable DT control in full U-Boot . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-11pico-imx7d: Add bl33 configJun Nie
Add default configuration to run u-boot as BL33 in the boot flow case of ATF(ARM Trusted Firmware) -> OPTEE -> U-boot. Signed-off-by: Jun Nie <jun.nie@linaro.org> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-06-11ARM: imx: dh-imx6: Convert SPI support to DMMarek Vasut
Enable DM SPI and SF support on DHCOM iMX6 PDK2. Convert board code to match the DM support. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: dh-imx6: Convert USB support to DMMarek Vasut
Enable DM USB host support on DHCOM iMX6 PDK2. Convert board code to match the DM support. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: dh-imx6: Convert SATA support to DMMarek Vasut
Enable DM SATA support on DHCOM iMX6 PDK2. Convert board code to match the DM support. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: dh-imx6: Convert SD/MMC support to DMMarek Vasut
Enable DM block and DM MMC support on DHCOM iMX6 PDK2. Convert board code to match the DM support. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: dh-imx6: Enable DM GPIOMarek Vasut
Enable DM GPIO support on DHCOM iMX6 PDK2 and fix up board code where applicable. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: imx: dh-imx6: Enable DM pin controlMarek Vasut
Enable DM pin control support on DHCOM iMX6 PDK2. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: dts: imx: dh-imx6: Import DHCOM iMX6 PDK2 DTs from LinuxMarek Vasut
Import DHCOM iMX6 PDK2 device tree from Linux 5.1.1 b724e9356404 . Enable DT control in full U-Boot . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11colibri_imx7: migrate usb to driver modelIgor Opaniuk
Migrate USB to Driver Model (CONFIG_DM_USB=y). Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-11toradex apalis/colibri: extend CONFIG_SYS_MALLOC_F_LENIgor Opaniuk
Extend size of the malloc() pool for use before relocation, from 0x400 (default one) to 0x2000 (CONFIG_SYS_MALLOC_F_LEN=0x2000), as adding of DM_FLAG_PRE_RELOC flag to simple-bus driver introduced a regression on multiple boards, because of more intensive usage of malloc() pool and therefore a broken boot as the size of pool isn't sufficient. Fixes: 3a7c45f6a7 ("simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus") Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-06-11board: toradex: add colibri imx8qxp 2gb wb it v1.0b module supportMarcel Ziswiler
This commit adds initial support for the Toradex Colibri iMX8QXP 2GB WB IT V1.0B module. Unlike the V1.0A early access samples exclusively booting from SD card, they are now strapped to boot from eFuses which are factory fused to properly boot from their on-module eMMC. U-Boot supports either booting from the on-module eMMC or may be used for recovery purpose using the universal update utility (uuu) aka mfgtools 3.0. Functionality wise the following is known to be working: - eMMC and MMC/SD card - Ethernet - GPIOs - I2C Unfortunately, there is no USB functionality for the i.MX 8QXP as of yet. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-10Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- mpc8xxx spi driver fixes (Mario) - mpc8xxx spi dm conversion (Mario, Jagan) - SPI DM Migration update (Jagan)
2019-06-10Merge tag 'video-updates-for-2019.07-rc3' of git://git.denx.de/u-boot-videoTom Rini
- mxsfb DM_VIDEO conversion - splash fix for DM_VIDEO configurations - meson HDMI fix for boards without hdmi-supply regulator
2019-06-10Merge tag 'u-boot-atmel-fixes-2019.07-a' of git://git.denx.de/u-boot-atmelTom Rini
First set of u-boot-atmel fixes for 2019.07 cycle
2019-06-10ids8313: Disable SPIMario Six
With the recent SPI changes, the ids8313 board won't compile anymore. Until further information from the manufacturer, disable SPI support, so that the board will at least compile again. Signed-off-by: Mario Six <mario.six@gdsys.cc> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-08Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
The bulk of these changes are an effort to unify Tegra186 builds with builds of prior 64-bit Tegra generations. On top of that there are various improvements that allow data (such as the MAC address and boot arguments) to be passed through from early firmware to the kernel on boot.
