path: root/configs
2016-03-09apalis_imx6_it_defconfig: add options needed with 3.14.52_1.1.0_gaMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7_defconfig: set SYS_BOOT_NANDMax Krummenacher
All fsl boards use this when booting from NAND. While at it minimize it with savedefconfig. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7: add initial, cp from mx7sabresdMax Krummenacher
2016-03-09mx7dsabresd: add NAND/UBI to configMax Krummenacher
2016-03-09Apalis/Colibri iMX6: add additional configsMax Krummenacher
Add configs now needed with the update of U-Boot. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09MLK-11721 imx: mx6q/dl/solo: default support SPI-NOR for sdb boardsPeng Fan
1. Default support SPI-NOR for imx6q/dl/solo sabresd board. 2. Fix bug for mx6soloxxx_spinor_defconfig. "nosmp" should be \"nosmp\". Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09MLK-11616 imx: mx6qpsabresd: Add defconfig filesPeng Fan
Add android and sata defconfig file. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09MLK-11548 imx: imx6qp: add SabreSD board supportAnson Huang
Add i.MX6QP SabreSD board support. Signed-off-by: Anson Huang <b20788@freescale.com>
2016-03-09MLK-11478 imx: mx6ul: Add QSPINOR boot support on mx6ul 9x9 evk boardYe.Li
Add new build target: mx6ul_9x9_evk_qspi1_config Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-11388 imx: mx7d: add support for mx7d 19x19 lpddr2 arm2 boardYe.Li
This mx7d 19x19 lpddr2 arm2 board is based on 19x19 lpddr3 arm2 board with DDR changed to 512M LPDDR2. We added DDR script for LPDDR2 and a new u-boot build target: mx7d_19x19_lpddr2_arm2_config LPDDR2 script source: lpddr2_0_1.ds Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-11364 imx: mx6ul : Add support for i.MX6UL 9x9 EVK boardYe.Li
The i.mx6ul 9x9 EVK shares the same base board with 6ul 14x14 EVK with two main changes on CPU board: 1. Change to use pfuze 3000. 2. Use 256MB LPDDR2 memory. This patch uses a macro CONFIG_6UL_9X9_LPDDR2 to distinguish the changes above, basing on 14x14 EVK board level codes. The new build target for the 9x9 EVK: mx6ul_9x9_evk_config Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-11227 imx: mx6ul_14x14_lpddr2_arm2 add weimnor defconfigPeng Fan
1. Add weimnor boot defconfig 2. move CONFIG_FSL_USDHC and CONFIG_VIDEO to board header 3. Add CONFIG_SYS_FLASH_PROTECTION for mx6ul 14x14 lpddr2 arm2 4. correct CONFIG_SYS_FLASH_SECT_SIZE and CONFIG_SYS_MAX_FLASH_SECT 5. Add comments for setup_eimnor, since ENET2_RXER pin conflicts with ENET2. Also eimnor support will disable SD1/SD2, need ENET to boot kernel and nfs using enet. So setup_eimnor should be invoked after setup_fec Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09MLK-11135-2 imx: mx6ul: Add MX6UL LPDDR2 ARM2 board supportYe.Li
Add MX6UL LPDDR2 ARM2 board BSP codes, supported peripherals: SD1, eMMC(USDHC2), USB OTG1, I2C, ENET2, PMIC. Due to a board issue, the SD1 only supports 1 bit bus width. Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-11121 imx: mx6qpsabreauto use correct cfg filePeng Fan
IPU on/ L2 on --> nand fail IPU close/ L2 on --> nand ok IPU on/ L2 close --> nand ok This problem is because mx6qp.cfg should be used for mx6qpsabreauto, but not imximage.cfg which is for mx6qsabreauto. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09MLK-11090 imx: mx6ul: Add build target for emmc boot on ddr3 arm2 boardYe.Li
The mx6ul ddr3 arm2 board needs rework to enable the emmc. Since the pin used by emmc are multiplexed with SD1 and QSPI, the SD1 and QSPI can't work. The u-boot build target for emmc is: mx6ul_14x14_ddr3_arm2_emmc_config Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-10956 imx: mx6ul: Change BSP name and dtb name for 14x14 packageYe.Li
Since there is another 9x9 package for mx6ul, modify the BSP names of ddr3 arm2 board and evk board to add 14x14 package info. Also modify the loaded dtb file to align with kernel. After the change, the build target for mx6ul ddr3 arm2 board is: mx6ul_14x14_ddr3_arm2_config and the build target for mx6ul evk board is: mx6ul_14x14_evk_config Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-10955 imx: mx7d arm2: Add NAND support for mx7d 19x19 lpddr3 arm2 boardYe.Li
Add the default TSOP NAND support and build target. New build target for nand boot: mx7d_19x19_lpddr3_arm2_nand_config Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09 MLK-10908: imx: mx6sx Add mx6sx_17x17_arm2_qspi2 configHan Xu
This config was missed when porting to 2015.04 u-boot. Signed-off-by: Han Xu <b45815@freescale.com>
2016-03-09MLK-10839: arm: imx: mx7d 19x19 lpddr3 arm2 board supportAdrian Alonso
* Add mx7d_19x19_lpddr3_arm2 target board supprt * Enable i2c, spinor, usb, usdhc, qspi, enet, uart * Build targets mx7d_19x19_lpddr3_arm2_defconfig mx7d_19x19_lpddr3_arm2_eimnor_defconfig - Set EIMNOR settings for Intel Sibley Asynchronous mode - Set flash sector size for 256kb (erase block size) Signed-off-by: Adrian Alonso <aalonso@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-10865 imx: mx6ulevk: Add android supportYe.Li
Add android features booti, fastboot and recovery to i.MX6UL EVK board. Since there is no user button on the board, we can't implement the recovery by using button. Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-10852 imx: mx6ul_ddr3_arm2: Add support for NAND bootYe.Li
Since the NAND has two pins conflict with SD2, when NAND is enabled, we must disable SD2. So the CONFIG_SYS_FSL_USDHC_NUM needs configure to 1 and should be moved to under defining CONFIG_SYS_USE_NAND. New build target for NAND boot: mx6ul_ddr3_arm2_nand_config Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-10841 imx: mx6ul_ddr3_arm2: Add support for WEIMNOR bootYe.Li
Correct the EIMNOR settings to non-mux mode and set the environment variables configuration to FLASH when using WEIMNOR boot. New target is added for build WEIMNOR boot u-boot: mx6ul_ddr3_arm2_eimnor_config Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-10817 imx:mx6ul_ddr3_arm2 add mx6ul ddr3 arm2 board supportPeng Fan
Add board code for mx6ul ddr3 arm2 board. QSPI, USDHC, ENET, USB, VIDEO, SPINOR, EIMNOR Add sd1, qspi and spinor boot support DDR script is 1.02 version. Signed-off-by: Fugang Duan <b38611@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09MLK-10821 imx: mx6ulevk: Add board support for mx6ulevkYe.Li
Add BSP codes to support modules on the board: I2C, SD/eMMC, NAND, QSPI, FEC1/FEC2, USB, LCDIF, 74LV, Serial DDR version: 1.0 Build target: mx6ulevk_config mx6ulevk_qspi1_config Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-10774-51 imx: Add epdc default configuration filePeng Fan
Add epdc default configuration file. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09MLK-10774-43 imx:mx7d fix DEFAULT_FDT_FILEPeng Fan
should add '\' to string, otherwise this macro will be ignored. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09MLK-10522-3: imx: mx7d_12x12_ddr3_arm2: add target board supportAdrian Alonso
* Add mx7d_12x12_ddr3_arm2 target board support * Initial support for mx7d_12x12_ddr3_arm2 target board add support for base hardware eMMC, SD and ECSPI boot. Signed-off-by: Adrian Alonso <aalonso@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com> (cherry picked from commit 51d69f7996cc6e6da8bb3f0af751549cb2435e44) Conflicts: boards.cfg
2016-03-09MLK-10774-40 imx: mx7dsabresd: Add build target for QPSI and NANDPeng Fan
Add targets for building u-boot to support QSPI booting and NAND booting. NAND booting can't work on mx7d TO1.0 Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09MLK-10448-6 imx: mx6qpsabreauto: Add MX6QP SABREAUTO CPU3 board supportYe.Li
1. Add DDR script v1.04 for i.MX6DQP SABREAUTO board. 2. On CPU3 board, enet RGMII tx clock is from internal PLL. Set the GPR5[9] and init the enet pll output to 125Mhz. 3. On CPU3 board, SW1ABC=VDDSOC_IN, SW2=VDDARM_IN. Build target: mx6qpsabreauto_config Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Robin Gong <b38343@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com> (cherry picked from commit e0b316f071aa17c8e41a50f395346ab9f012e665) Conflicts: board/freescale/mx6qsabreauto/mx6qsabreauto.c boards.cfg
2016-03-09MLK-10363-3 Android: Add android support for MX7D SABRESD boardYe.Li
Enable android fastboot, recovery, booti features for mx7d sabresd board by using new build target: mx7devkandroid_config Signed-off-by: Ye.Li <B37916@freescale.com> (cherry picked from commit bfc2b467ddac9c6eccb3f39aad3663a959546b64) Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Conflicts: boards.cfg
2016-03-09MLK-10774-33 imx:mx6 add udc and fastboot supportPeng Fan
Add udc and fastboot support We did not use the upstream way. Currently use CI_UDC and USB_GAGDET of upstream can make fastboot work, but lack of flash operation, so we still use our way. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Nitin Garg <nitin.garg@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com>
2016-03-09MLK-10774-27 imx:mx6 fix `Can't find sensor device` for temperaturePeng Fan
Add CONFIG_SYS_MALLOC_F and CONFIG_SYS_MALLOC_F_LEN to support correctly detect temperature sensor. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09MLK-10362 imx: mx7dsabresd: Add support for MX7D SABRESD boardPeng Fan
Add i.MX7D SABRESD board BSP codes, with enabled modules: UART, PMIC, USB/OTG, SD, eMMC, ENET, I2C, 74LV IOX. Build target: mx7dsabresd_config Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com> (cherry picked from commit 3bf52a153e2964d4fdc17f0e8cb816686cbb6c2b) Conflicts: boards.cfg
2016-03-09MLK-10351 imx: mx7d: Add 19x19 DDR3L ARM2 board supportYe.Li
Add BSP codes, configuration head file and build target for 19x19 DDR3L ARM2 board with basic functions: ENET2, I2C, SD/eMMC/MMC, USB, QSPI, ECSPI, pfuze3000 PMIC. Build target: mx7d_19x19_ddr3_arm2_config Signed-off-by: Ye.Li <B37916@freescale.com> (cherry picked from commit 58fd869e3097b7461fbfae3d94e3ebbd30ae2474) Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Conflicts: boards.cfg
2016-03-09MLK-10191-3 imx: mx7: Add support for i.MX7D 12x12 LPDDR3 ARM2 boardYe.Li
Add BSP codes, configuration head file and build target for 12x12 LPDDR3 ARM2 board with basic functions: ENET, I2C, SD/eMMC/MMC, USB, LCD Splash screen, QSPI, ECSPI, pfuze3000 PMIC. Note: pmic and video is still not upstream way Signed-off-by: Ye.Li <B37916@freescale.com> (cherry picked from commit ac0d51ef07fdec880e6da318c08d521506640efa) Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Conflicts: boards.cfg
2016-03-09MLK-10774-22 imx:mx6sx_arm2 add mx6sx arm2 bspPeng Fan
Add bsp and configuration file Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09MLK-10774-21 imx:imx6sxsabreauto add bspPeng Fan
2016-03-09MLK-10774-19 imx:mx6qsabreauto update bspPeng Fan
Update bsp and add configuration file Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09MLK-10774-18 imx:mx6qarm2 update bspPeng Fan
2016-03-09MLK-10774-17 imx:mx6sabresd update bspPeng Fan
2016-03-09MLK-10774-16 imx:mx6sxsabresd update board and configPeng Fan
Update mx6sxsabresd board and config file Note: Fastboot Android support is not added. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-03-09arm: tegra: initial support for apalis tk1Marcel Ziswiler
This patch adds board support for the Toradex Apalis TK1 a computer on module which can be used on different carrier boards. For the sake of ease of use we do not distinguish between different carrier boards for now as the base module features are deemed sufficient enough for regular booting. The following functionality is working so far: - eMMC boot and environment storage - Gigabit Ethernet (link detection still rather flaky) - MMC/SD cards (both MMC1 as well as SD1 slot however the later one without card detect) - USB client/host (dual role port as client e.g. for DFU/UMS, other two ports as host) Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2015-08-10colibri-vf: Enable SPI supportBhuvanchandra DV
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> [add CONFIG_DM to colibri_vf_defconfig] Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-08-10colibri_vf: Add separate defconfig for device tree supportBhuvanchandra DV
Most of the drivers available for Vybrid are not yet converted to OF model to use device tree model, only few drivers like SPI and GPIO drivers use device trees. Add separate defconfig for who needs to use device tree model. Later this can be integrated to single defconfig. Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2015-05-01Colibri iMX6: initial commitMax Krummenacher
use make colibri_imx6_defconfig
2015-05-01Apalis iMX6: initial commitMax Krummenacher
Use for the industrial temperature range rated modules: make apalis_imx6_it_defconfig Use for the commercial temperature range rated modules: make apalis_imx6_defconfig
2015-04-14ARM: vf610: Initial integration for Colibri VF50/VF61Sanchayan Maity
This adds initial support for Colibri VF50/VF61 based on Freescale Vybrid SoC. - CPU clocked at 396/500 MHz - DDR3 at 396MHz - for VF50, use PLL2 as memory clock (synchronous mode) - for VF61, use PLL1 as memory clock (asynchronous mode) - Console on UART0 (Colibri UART_A) - Ethernet on FEC1 - PLL5 based RMII clocking (E.g. No external crystal) - UART_A and UART_C I/O muxing - Boot from NAND by default - USB host and client support Tested on Colibri VF50/VF61 booting using serial loader over UART. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2015-04-14mtd: vf610_nfc: add Freescale NFC controller configs to KconfigStefan Agner
This commit allows users to enable/disable the Freescale NFC controller found in systems like Vybrid (VF610), MPC5125, MCF54418 or Kinetis K70 via Kconfig with more detailed help docs.
2015-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-04-10lpc32xx: add support for board work_92105Albert ARIBAUD \(3ADEV\)
Work_92105 from Work Microwave is an LPC3250- based board with the following features: - 64MB or 128MB SDR DRAM - 1 GB SLC NAND, managed through MLC controller. - Ethernet - Ethernet + PHY SMSC8710 - I2C: - EEPROM (24M01-compatible) - RTC (DS1374-compatible) - Temperature sensor (DS620) - DACs (2 x MAX518) - SPI (through SSP interface) - Port expander MAX6957 - LCD display (HD44780-compatible), controlled through the port expander and DACs This board has SPL support, and uses the LPC32XX boot image format. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
