Now all UniPhier SoCs support a pinctrl driver. Select (SPL_)PINCTRL
since it is mandatory even for base use.
Sinlinx SinA33 has a USB OTG port, but VBUS is controlled manually from
a jumper pad.
Enable OTG in gadget mode, as well as the download gadget and related
functions.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Sinlinx SinA33 has 1 USB host port. Enable EHCI_HCD support for it.
Also enable USB mass storage support so we can access USB sticks.
Sinlinx SinA33 uses PB4 for mmc0 card detect.
The NanoPi NEO is a simple h3 board with 512MB RAM, ethernet, one usb
and one usb OTG connector.
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig
Move this option to Kconfig and tidy up existing uses.
CONFIG_SPL_NET_VCI_STRING
There are a few options which use lower case. We should use upper case for
all CONFIG options.
[trini: Add usbtty/nand hunk to include/configs/spear3xx_evb.h]
A few boards define this in a header file which is incorrect. It means that
Kconfig options that rely on this cannot be used. Move it.
Note that quite a few boards defined this options but do not appear to
actually use SPL:
BSC9132QDS_NOR_DDRCLK100_SECURE
BSC9132QDS_NOR_DDRCLK133_SECURE
BSC9132QDS_SDCARD_DDRCLK100_SECURE
BSC9132QDS_SDCARD_DDRCLK133_SECURE
BSC9132QDS_SPIFLASH_DDRCLK100_SECURE
BSC9132QDS_SPIFLASH_DDRCLK133_SECURE
C29XPCIE_NOR_SECBOOT
P1010RDB-PA_36BIT_NAND_SECBOOT
P1010RDB-PA_36BIT_SPIFLASH_SECBOOT
P1010RDB-PA_NAND_SECBOOT
P1010RDB-PA_NOR_SECBOOT
P1010RDB-PB_36BIT_NOR_SECBOOT
P1010RDB-PB_36BIT_SPIFLASH_SECBOOT
P1010RDB-PB_NAND_SECBOOT
P1010RDB-PB_NOR_SECBOOT
P3041DS_SECURE_BOOT
P4080DS_SECURE_BOOT
P5020DS_NAND_SECURE_BOOT
P5040DS_SECURE_BOOT
T1023RDB_SECURE_BOOT
T1024QDS_DDR4_SECURE_BOOT
T1024QDS_SECURE_BOOT
T1024RDB_SECURE_BOOT
T1040RDB_SECURE_BOOT
T1042D4RDB_SECURE_BOOT
T1042RDB_SECURE_BOOT
T2080QDS_SECURE_BOOT
T2080RDB_SECURE_BOOT
T4160QDS_SECURE_BOOT
T4240QDS_SECURE_BOOT
ls1021aqds_nor_SECURE_BOOT
ls1021atwr_nor_SECURE_BOOT
ls1043ardb_SECURE_BOOT
For these boards CONFIG_SPL_DM will no-longer be defined in SPL. But since
they apparently don't have an SPL, this should not matter.
Move the SPL settings into common/spl where most of the SPL code is kept.
Update the defconfig files to match their canonical form, as produced by
'make safedefconfig'.
This is the result of running 'tools/moveconfig.py -s' on the tree.
LS1046AQDS Specification:
Memory subsystem:
* 8GByte DDR4 SDRAM (64bit bus)
* 128 Mbyte NOR flash single-chip memory
* 512 Mbyte NAND flash
* 64 Mbyte high-speed SPI flash
* SD connector to interface with the SD memory card
Ethernet:
* Two XFI 10G ports
* Two SGMII ports
* Two RGMII ports
PCIe: supports Gen 1 and Gen 2
SATA 3.0: one SATA 3.0 port
USB 3.0: two micro AB connector and one type A connector
UART: supports two UARTs up to 115200 bps for console
Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com>
Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com>
Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
LS1046ARDB Specification:
Memory subsystem:
* Two 64 Mbyte high-speed SPI flash
* On-board 4G eMMC
Ethernet:
* Two XFI 10G ports
* Two SGMII ports
* Two RGMII ports
PCIe:
* PCIe1 (SerDes2 Lane0) to miniPCIe slot
* PCIe2 (SerDes2 Lane1) to x2 PCIe slot
* PCIe3 (SerDes2 Lane2) to x4 PCIe slot
SATA:
* SerDes2 Lane3 to SATA port
USB 3.0: one super speed USB 3.0 type A port
one Micro-AB port
This SoC is equipped with two EHCI cores and two xHCI cores.
Enable the generic EHCI driver for the former.
This driver has not been converted to Driver Model, and it is an
obstacle to migrate other block device drivers. Remove it for now.
The UniPhier SoCs already use a DM-based EHCI driver, so now
ARCH_UNIPHIER can select DM_USB.
These two changes must be done atomically because removing the
legacy driver causes a build error.
move VERSION_VARIABLE from board config file into a
Kconfig option.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
