path: root/configs
2015-04-18cros_ec: Drop unused CONFIG_DM_CROS_ECSimon Glass
Since all supported boards enable this option now, we can remove it along with the old code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: cros_ec: Convert cros_ec LPC driver to driver modelSimon Glass
This is the last driver to be converted. It requires an LPC bus and a special check_version() method. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: x86: pci: Convert chromebook_link to use driver model for pciSimon Glass
Move chromebook_link over to driver model for PCI. This involves: - adding a uclass for platform controller hub - removing most of the existing PCI driver - adjusting how CPU init works to use driver model instead - rename the lpc compatible string (it will be removed later) This does not really take advantage of driver model fully, but it does work. Furture work will improve the code structure to remove many of the explicit calls to init the board. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: x86: pci: Convert coreboot to use driver model for pciSimon Glass
Move coreboot-x86 over to driver model for PCI. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: sandbox: pci: Enable PCI for sandboxSimon Glass
Enable PCI options so that sandbox can be used for testing this bus with driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16x86: Add support for panther (Asus Chromebox)Simon Glass
Support running U-Boot as a coreboot payload. Tested peripherals include: - Video (HDMI and DisplayPort) - SATA disk - Gigabit Ethernet - SPI flash USB3 does not work. This may be a problem with the USB3 PCI driver or something in the USB3 stack and has not been investigated So far this is disabled. The SD card slot also does not work. For video, coreboot will need to run the OPROM to set this up. With this board, bare support (running without coreboot) is not available as yet. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-15sunxi: iNet 3F supportPaul Kocialkowski
The iNet 3F is an A10 tablet with 1GiB RAM and a 1024x768 screen. Also see: http://linux-sunxi.org/INet_3F Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: iNet 3W supportPaul Kocialkowski
The iNet 3W is an A10 tablet with 1GiB RAM and a 1024x768 screen. Also see: http://linux-sunxi.org/INet_3W Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: Proper iNet board config namingPaul Kocialkowski
The official name for the iNet manufacturer is iNet with a lowercase i and an uppercase N. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Michal Suchanek <hramrach@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: A20-OLinuXino-Lime2 USB0 VBUS detect and enable pinsPaul Kocialkowski
This allows enabling MUSB (on the OTG port). Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: Cubieboard2 mmc0 card-detect pinPaul Kocialkowski
2015-04-15sunxi: A20-OLinuXino-Lime2 mmc0 card-detect pinPaul Kocialkowski
2015-04-15sunxi: Yones Toptech BD1078 mmc0 and mmc1 card-detect pinsPaul Kocialkowski
2015-04-15sunxi: Ainol AW1 mmc0 card-detect pinPaul Kocialkowski
2015-04-15sunxi: Ampe A76 mmc0 card-detect pinPaul Kocialkowski
2015-04-15sunxi: TZX-Q8-713B7 mmc0 card-detect pinPaul Kocialkowski
2015-04-15sunxi: Yones Toptech BD1078 supportPaul Kocialkowski
The Yones Toptech BD1078 is an A20 based 10" tablet with a 1024x600 lcd screen, volume up/down and back buttons, headphones jack, mini hdmi, micro usb (otg), micro usb (host), external micro-sd slot and a separate internal micro-sd slot. Also see: http://linux-sunxi.org/Yones_Toptech_BD1078 Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: Ainol AW1 supportPaul Kocialkowski
The Ainol AW1 is an A20 based tablet with a 800x480 lcd screen, sdio wifi, volume up/down and home buttons, micro-sd slot, micro usb (otg), headphones connector and a SPCI modem connector. Also see: http://linux-sunxi.org/Ainol_AW1 Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: usb: Drop AXP-sepcific VBUS detection and drive logicPaul Kocialkowski
VBUS detection and enable is now be used with virtual AXP GPIOs, so all the USB code has to use GPIO in every case and let sunxi_gpio do the heavy lifting. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sun6i: Add support for the Mixtile LOFT-Q boardHan Pengfei
The Mixtile LOFT-Q is an A31 based board with 2G RAM, 8G EMMC, sdio wifi, 1Gbit ethernet, HDMI display, toslink audio plug, 4 USB2.0 port, external USB2SATA connector, sd card plug, 3x60 external fpic expansion connector, NXP JN5168 zigbee gw, remote support. Also see http://focalcrest.com/en/pc.html#pro02 Signed-off-by: Han Pengfei <pengphei@sina.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-04-10lpc32xx: add support for board work_92105Albert ARIBAUD \(3ADEV\)
Work_92105 from Work Microwave is an LPC3250- based board with the following features: - 64MB or 128MB SDR DRAM - 1 GB SLC NAND, managed through MLC controller. - Ethernet - Ethernet + PHY SMSC8710 - I2C: - EEPROM (24M01-compatible) - RTC (DS1374-compatible) - Temperature sensor (DS620) - DACs (2 x MAX518) - SPI (through SSP interface) - Port expander MAX6957 - LCD display (HD44780-compatible), controlled through the port expander and DACs This board has SPL support, and uses the LPC32XX boot image format. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-04-09ARM: mx5: add support for USB armory boardAndrej Rosano
Add support for Inverse Path USB armory board, an open source flash-drive sized computer based on Freescale i.MX53 SoC. http://inversepath.com/usbarmory Signed-off-by: Andrej Rosano <andrej@inversepath.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Chris Kuethe <chris.kuethe@gmail.com> Cc: Fabio Estevam <festevam@gmail.com> Cc: Vagrant Cascadian <vagrant@debian.org> Tested-By: Vagrant Cascadian <vagrant@debian.org> Tested-by: Chris Kuethe <chris.kuethe@gmail.com>
2015-04-08ARM: zynq: disable CONFIG_SYS_MALLOC_F to fix MMC bootMasahiro Yamada
Since commit 326a682358c1 (malloc_f: enable SYS_MALLOC_F by default if DM is on), Zynq MMC boot hangs up after printing the following: U-Boot SPL 2015.04-rc5-00053-gadcc570 (Apr 08 2015 - 12:59:11) mmc boot reading system.dtb Prior to commit 326a682358c1, Zynq boards enabled CONFIG_DM, but not CONFIG_SYS_MALLOC_F. That commit forcibly turned on CONFIG_SYS_MALLOC_F. I have not figured out the root cause, but anyway it looks like CONFIG_SYS_MALLOC_F gave a bad impact on the Zynq MMC boot. We are planning to have the v2015.04 release in a few days. I know this is a defensive fixup, but what I can do now is to add # CONFIG_SYS_MALLOC_F is not set to every Zynq defconfig file to get back the original behavior. Tested on: - Zedboard - ZC706 board Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org>
2015-04-04sunxi: Fix Orangepi_mini dtb filenameHans de Goede
The Orangepi_mini is different enough from the regular Orangepi that it needs its own dtb, but when it got added a copy and paste error was made and it got the same dtb filename, fix this. While at it also add a short description of both Orangepi boards to the defconfig files for them. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-04-03Merge git://git.denx.de/u-boot-arcTom Rini
2015-04-03Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
Conflicts: board/armltd/vexpress64/vexpress64.c Signed-off-by: Tom Rini <trini@konsulko.com>
2015-04-03board: Switch Abilis TB-100 board to Driver Model for serial portAlexey Brodkin
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org>
2015-04-03serial-arc: switch to DMAlexey Brodkin
Now when all infrastructure in ARC is ready for it let's switch ARC UART to driver model. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org>
2015-04-03arc: re-generate defconfigsAlexey Brodkin
Before that moment our defconfigs were manually modified with addition of new options. That means once anybody wants to add another option and re-genarate defconfig with "make defconfig" there will be lots of differences. So to make future modifications more clean we'll do bulk re-generation right away. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-03-31Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2015-04-01ARM: atmel: at91sam9n12ek: enable spl supportBo Shen
Enable SPL support for at91sam9n12ek boards, now it supports boot up from NAND flash, serial flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-04-01ARM: atmel: at91sam9x5ek: enable spl supportBo Shen
Enable SPL support for at91sam9x5ek board. Now, it supports boot up from NAND flash and SPI flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-04-01ARM: atmel: at91sam9m10g45ek: enable spl supportBo Shen
Supports boot up from NAND flash with software ECC eanbled. And supports boot up from SD/MMC card with FAT file system. As the boot from SD/MMC card with FAT file system, the BSS segment is too big to fit into SRAM, so, use the lds to put it into SDRAM. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-04-01arm, at91: corvus: move MACH_TYPE to defconfigHeiko Schocher
move MACH_TYPE into defconfig Signed-off-by: Heiko Schocher <hs@denx.de>
2015-03-31Merge branch 'master' of git://git.denx.de/u-boot-imxTom Rini
2015-03-30ARM: tegra: rename colibri_t20 board/configuration/device-treeMarcel Ziswiler
In accordance with our other modules supported by U-Boot and as agreed upon for Apalis/Colibri T30 get rid of the carrier board in the board/ configuration/device-tree naming. While at it also bring the prompt more in line with our other products. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-29sunxi: a10-LIME set the cpu clock at boot to 912MHzIain Paton
following kernel patches to reduce the cpu clock to 912MHz due to reported instability at 1008MHz, select 912MHz as the boot speed for the a10-lime Signed-off-by: Iain Paton <ipaton0@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-03-28vexpress64: cut config and defaults for unclear variantLinus Walleij
This variant that is neither FVP / Base Model or Juno Versatile Express 64bit is confusing. Get rid of it unless someone can point out what machine that really is. Seems to be an evolutional artifact in the config base. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-28ARM: bcm283x: merge BCM2835/BCM2836 directories into mach-bcm283xMasahiro Yamada
BCM2835 (used on Raspberry Pi) and BCM2836 (used on Raspberry Pi 2) are similar enough. One of the biggest differences is the ARM processor. It is reasonable to collect the source files into a single place, arch/arm/mach-bcm283x/. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2015-03-28malloc_f: enable SYS_MALLOC_F by default if DM is onMasahiro Yamada
This option has a bool type, not hex. Fix it and enable it if CONFIG_DM is on because Driver Model always requires malloc memory. Devices are scanned twice, before/after relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc memory before relocation. As it is board-independent, handle it globally. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-03-28malloc_f: remove redundant defalut values of CONFIG_SYS_MALLOC_F_LENMasahiro Yamada
The default value of CONFIG_SYS_MALLOC_F_LEN is defined by ./Kconfig as 0x400. Each defconfig or Kconfig need not repeat the same value. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-03-26sunxi: set GMAC TX delay = 0x1 on Cubietruck.Ian Campbell
Of 4 boards in our automated test system 2 do not have reliable networking with the default TX delay of 0x0. Increasing to 0x1 seems to make things reliable on all 4 boards. Some previous ad-hpoc tests with tx delay set to 0, 1, 2 and 3 on one of the problematic boards showed: 0: mw.l 0x1c20164 0x006 1 -- t/o in 4/5 tftp runs 1: mw.l 0x1c20164 0x406 1 -- t/o in 1/5 tftp runs 2: mw.l 0x1c20164 0x806 1 -- t/o in 1/5 tftp runs 3: mw.l 0x1c20164 0xc06 1 -- t/o many times in first tftp run For 0, 1 and 2 "t/o" means one or two "T" glitches in the download, but it did complete. For 3 those were basically continuous and it couldn't complete. tftp was of a 16M initrd. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-03-24bav335x: Update defconfigs and fix typo in EEPROM config formatGilles Gameiro
After v2015.01 we need to have DM enabled in order to use UART. Also fix a typo in the EEPROM config format. Signed-off-by: Gilles Gameiro <gilles@gigadevices.com> [trini: Reword commit message, re-save defconfigs with 'savedefconfig'] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-24ARM: UniPhier: enable Driver Model and UART on SPLMasahiro Yamada
Enable CONFIG_SPL_DM and CONFIG_SPL_SERIAL_SUPPORT, which provide Driver Model UART support on SPL. CONFIG_SYS_SPL_MALLOC_{START,SIZE} should be dropped because simple malloc is preferred on SPL. Dlmalloc requires some static variables on .data section that is not available yet for NOR boot mode etc. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-03-23imx:mx6slevk support reading temperaturePeng Fan
This patch is to support reading temperature for mx6slevk board. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-03-23imx:mx6dlsabresd fix error detecting thermalPeng Fan
Before add CONFIG_SYS_MALLOC_F and CONFIG_SYS_MALLOC_F_LEN, uboot will complains "CPU: Temperature: Can't find sensor device". This is because DM and DM_THERMAL are enabled, but SYS_MALLOC_F is not configured. After applying this patch, uboot can correctly detect the temperature. " U-Boot 2015.04-rc2-00146-g48b6e30-dirty (Mar 09 2015 - 13:04:36) CPU: Freescale i.MX6DL rev1.1 at 792 MHz CPU: Temperature 44 C " Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-03-23board/seco: Add mx6q-uq7 basic board supportBoris BREZILLON
Add basic SECO MX6Q/uQ7 board support (Ethernet, UART, SD are supported). It also adds a Kconfig skeleton to later add more SECO board (supporting SoC and board variants). Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
2015-03-20at91sam9rlek_mmc_defconfig: Add CONFIG_ARCH_AT91=yTom Rini
This flag was missing and thus the board was totally being configured wrong. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-18ARM: at91: at91sam9rlek: add hush parser to defconfigWu, Josh
HUSH parser will handle the variable easier. That will be helpful for write a complicated U-Boot commands or varaibles. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com>
