path: root/configs
2016-01-08rockchip: Fix the configuration for chromebook_jerrySimon Glass
Various updates did not make it through to this board. Also the instructions for building a SPI image are no-longer correct. Fix these so that Jerry can boot to a prompt again. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-12-27Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-12-27sunxi: Reduce Orangepi PC RAM speed to 624 MHzHans de Goede
There are some reports of stability issues at 672 MHz, see: http://linux-sunxi.org/Orange_Pi_PC#DRAM_clock_speed_limit So reduce the DRAM speed to 624MHz which seems to be reliable everywhere. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-24Merge git://git.denx.de/u-boot-socfpgaTom Rini
Conflicts: include/configs/axs101.h Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-22arm: socfpga: sr1500: Undefine CONFIG_SPI_FLASH_USE_4K_SECTORSChin Liang See
Undefine CONFIG_SPI_FLASH_USE_4K_SECTORS for UBI and UBIFS support on serial NOR flash Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2015-12-22arm: socfpga: arria5: Undefine CONFIG_SPI_FLASH_USE_4K_SECTORSChin Liang See
2015-12-22arm: socfpga: cyclone5: Undefine CONFIG_SPI_FLASH_USE_4K_SECTORSChin Liang See
2015-12-23ARM: uniphier: rename rest of defconfig filesMasahiro Yamada
Rename rest of defconfig files of UniPhier SoC family to have the prefix uniphier_. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-23ARM: uniphier: support ProXstream2, PH1-LD6b boards in single defconfigMasahiro Yamada
These boards are similar enough to be supported in a single defconfig file. Distinguish one from another by "DEVICE_TREE" from the command line. The how-to-build in doc/README.uniphier should be also updated. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-23ARM: uniphier: merge ph1_ld4_defconfig and ph1_sld8_defconfigMasahiro Yamada
These two are similar enough to be merged into a single defconfig file. Distinguish one from another by "DEVICE_TREE" from the command line. The how-to-build in doc/README.uniphier should be also updated. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-22arm: socfpga: Enable simple bus in SPL on all boardsMarek Vasut
The simple bus support must be enabled in SPL, otherwise the boards will not be able to parse the DT and will fail to boot. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-21Merge git://git.denx.de/u-boot-arcTom Rini
2015-12-21axs103: add support of generic OHCI USB 1.1 controllerAlexey Brodkin
This commit adds support of USB 1.1 storage media on AXS103 board. For some yet unknown reason USB 2.0 doesn't work on AXS103 board issuing messages like this: ------------------------>8------------------- AXS# usb start starting USB... USB0: USB EHCI 1.00 scanning bus 0 for devices... EHCI timed out on TD - token=0x80008c80 unable to get device descriptor (error=-1) 1 USB Device(s) found ------------------------>8------------------- As a work-around we're falling back to USB 1.1. Indeed it is much slower but at least USB storage devices are usable on AXS103. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org>
2015-12-21sunxi: Add CONFIG_SUNXI_NO_PMIC to Marsboard A10 configAleksei Mamlin
Marsboard A10 haven't any PMIC at all, so add CONFIG_SUNXI_NO_PMIC=y to Marsboard_A10_defconfig Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-12-21sunxi: A20-Olimex-SOM-EVB defconfig: enable mmc3Karsten Merker
The Olimex A20-SOM-EVB is an evaluation board for the Olimex A20-SOM system-on-module. The baseboard provides a full-size SD socket (connected to mmc3) in addition to the micro-SD socket on the SOM itself (which is connected to mmc0). Enable the mmc3 controller in the board defconfig. Signed-off-by: Karsten Merker <merker@debian.org> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-12-21sun5i: Add defconfig and dts file for the Empire Electronix D709 tabletHans de Goede
The Empire Electronix D709 tablet is a fairly standard 7" A13 tablet, featuring usb-wifi, a micro-sd slot, micro-usb otg and headphone jack. Empire Electronix is written on the back of the tablet, the D709 model info can be found in the about tablet menu in android. The PCB has no markings to speak of. This dts file is identical to the one submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-19Merge branch 'master' of git://www.denx.de/git/u-boot-socfpgaTom Rini
2015-12-20arm: socfpga: socrates: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
This patch adds the necessary OF alias for the UDC node, which let's the code locate the DWC2 UDC base address in OF instead of hard-coding it into the U-Boot binary. The code is adjusted to use the address from OF instead of the hard-coded one. Finally, the hard-coded address is removed and USB DM support is enabled. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Lukasz Majewski <l.majewski@majess.pl> Cc: Lukasz Majewski <l.majewski@samsung.com>
2015-12-20arm: socfpga: sockit: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
2015-12-20arm: socfpga: mcvevk: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
2015-12-20arm: socfpga: de0_nano: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
2015-12-20arm: socfpga: cyclone5-socdk: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
2015-12-20arm: socfpga: arria5-socdk: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
2015-12-19nios2: Enable support for fitImageMarek Vasut
The uImage format is legacy for years now, enable support for the fitImage format, which allows combining multiple files (kernel and dtb) into a single file, offers better protection of the payload and so on. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-12-18microblaze: Enable DM by defaultMichal Simek
Enable DM for the whole architecture. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18microblaze: Enable OF_CONTROL by defaultMichal Simek
2015-12-18microblaze: Use malloc setting via KconfigMichal Simek
Clean board specific file. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-12-18net: gem: Add driver dependencies to PHYLIBMichal Simek
Clear driver dependecies via Kconfig. Remove PHYLIB dependency from the driver. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18arm: zynq: Update ZYBO config optionsNathan Rossi
Update the ZYBO device tree and enable config options that relate to the added devices in the device tree. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Michal Simek <monstr@monstr.eu> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-16Merge git://git.denx.de/u-boot-rockchipTom Rini
2015-12-15armv8/ls1043ardb: add SECURE BOOT target for NORAneesh Bansal
LS1043ARDB Secure Boot Target from NOR has been added. - Configs defined to enable esbc_validate. - ESBC Address in header is made 64 bit. - SMMU is re-configured in Bypass mode. Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-12-13rockchip: Add basic support for kylin boardhuang lin
kylin board use rk3036 SOC, 512M sdram, 8G emmc. This add some basic files required to allow the board to output serial message and can run command(mmc info etc). Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-13rockchip: firefly: Use tiny-printfSjoerd Simons
Switch to using tiny-printf for the firefly SPL, this reduces the SPL by around 1800 bytes bringing it back under the 32k limit for both gcc 4.9 and gcc 5. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-12-10sunxi: Add suport for A83T HomletV2 Board by Allwinnervishnupatekar
Add dts and defconfig for h8homletv2 board. H8Homlet Proto v2.0 Board is A83T Dev Board by Allwinner. It has UART, ethernet, USB, HDMI, etc ports on it. A83T patches are tested on this board. Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-12-08axs10x: add support of generic EHCI USB 2.0 controllerAlexey Brodkin
This commit adds support of USB 2.0 storage media on AXS10x boards. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org>
2015-12-07Merge branch 'zynq' of git://www.denx.de/git/u-boot-microblazeTom Rini
2015-12-07ARM: zynq: Enable debug console for zc702Michal Simek
2015-12-07ARM64: zynqmp: Enable FIT config option via KconfigMichal Simek
Remove configuration options from board file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-07net: gem: Move gem to KconfigMichal Simek
Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-12-07ARM: zynq: Remove PHYLIB from config to defconfigMichal Simek
Move PHYLIB from board config to defconfig Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-12-07arm: socfpga: Enable CONFIG_DM_MMCMarek Vasut
Enable driver model MMC support on SoCFPGA. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com>
2015-12-07arm: socfpga: Add SoCFPGA SR1500 boardStefan Roese
The SR1500 board is a CycloneV based board, similar to the EBV SoCrates, equipped with the following devices: - SPI NOR - eMMC - Ethernet Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Cc: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Pavel Machek <pavel@denx.de>
2015-12-05tegra: Remove merge markers in some Kconfig filesSimon Glass
These were added by mistake in commit fde7e189. They cause a warning when configuring the boards. Remove them. Fixes: fde7e18938d8 ("dm: tegra: pci: Move CONFIG_PCI_TEGRA to Kconfig") Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Reported-by: Kevin Hilman <khilman@linaro.org> Acked-by: Thomas Chou <thomas@wytron.com.tw>
2015-12-05defconfig: dra74_evm: enable serial driver modelMugunthan V N
Enable serial driver model for dra74_evm as ns16550 supports driver model. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-12-04Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-12-01iocon: Disable FIT_VERBOSETom Rini
In order to fit into image constraints again, remove this feature. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-01rockchip: Explicitly set CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LENSjoerd Simons
Now that u-boot relocates the malloc area in SPL to SDRAM, with the malloc area sitting below the SPL_STACK_R_ADDR the SPL_STACK_R_MALLOC_SIMPLE_LEN needs to be set explicitly for rockchip as its SPL_STACK_R_ADDR (512kb) is smaller then STACK_R_MALLOC_SIMPLE_LEN (1Mb). Using the same value as SYS_MALLOC_F_LEN (8kb) is enough to load u-boot from SD card. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: Add basic support for evb-rk3036 boardhuang lin
This add some basic files required to allow the board to dispaly serial message and can run command(mmc info etc) Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Moved board Kconfig fragment from previous patch into this one to fix build error: Signed-off-by: Simon Glass <sjg@chromium.org> Series-changes: 8 - moved board Kconfig fragment from previous patch into this one
2015-12-01dm: core: Add SPL Kconfig for REGMAP and SYSCONhuang lin
Add SPL Kconfig for REGMAP and SYSCON, so REGMAP and SYSCON can remove from SPL stage. Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
