path: root/configs
2015-02-12powerpc: ppc4xx: Change from OF_SEPARATE to OF_EMBEDStefan Roese
This is necessary, as ppc4xx has the reset vector located at the end of the U-Boot image. This needs to be flashed to the end of the NOR flash. Adding the dtb to the main U-Boot image will break booting on ppc4xx. This patch now embeds the dtb in the U-Boot image instead. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Use CONFIG_OF_CONTROL for canyonlands boardsSimon Glass
Enable CONFIG_OF_CONTROL so that U-Boot on these three boards uses a device tree for its configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Add ramboot config for glacierSimon Glass
Add a new ramboot config for glacier so that it is possible to test U-Boot loaded over Ethernet instead of using JTAG. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Move CANYONLANDS/GLACIER/ARCHES to KconfigSimon Glass
Move these options to Kconfig and remove them from the CONFIG files. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2015-02-10Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-02-09Merge git://git.denx.de/u-boot-arcTom Rini
2015-02-09arc: move SYS_MONITOR_BASE setup in KonfigAlexey Brodkin
Following SPARK ARC now has SYS_MONITOR_BASE setup via Kconfig. This makes "include/configs/*.h" cleaner and more flexible. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-09arc: add selection of endianess in KconfigAlexey Brodkin
This change allows to keep board description clean and minimalistic. This is especially helpful if one board may house different CPUs with different features. It is applicable to both FPGA-based boards or those that have CPUs mounted on interchnagable daughter-boards. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-09arc: select cache settings via menuconfigAlexey Brodkin
2015-02-07ARM: at91: mmc portA support is only for at91sam9g20ek_2mmc boardWu, Josh
Current the MMC support will enable MCI port A, Which is only exist for 2mmc board. So by default we need to disable MMC (port A) support. And only enable it for 2mmc board. Otherwise, dataflash won't work in at91sam9260ek board as MMC has confliction with Dataflash in the CLK pin. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-02-07ARM: atmel: sama5d4_xplained: enable spl supportBo Shen
Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-02-07ARM: atmel: sama5d4ek: enable SPL supportBo Shen
The sama5d4ek support boot up from NAND flash, SD/MMC card and also the SPI flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-02-06x86: Add basic Intel Galileo board supportBin Meng
New board/intel/galileo board directory with minimum codes, plus board dts, defconfig and configuration files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-06x86: Add support for Intel Minnowboard MaxSimon Glass
This is a relatively low-cost x86 board in a small form factor. The main peripherals are uSD, USB, HDMI, Ethernet and SATA. It uses an Atom 3800 series CPU. So far only the dual core 2GB variant is supported. This uses the existing FSP support. Binary blobs are required to make this board work. The microcode update is included as a patch (all 3000 lines of it). Change-Id: I0088c47fe87cf08ae635b343d32c332269062156 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-06arm: db-mv784mp-gp: Enable SPL to include DDR training code into U-BootStefan Roese
This patch adds SPL support to the db-mv784mp-gp eval board. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2015-02-06arm: maxbcm: Enable SPL to include DDR training code into U-BootStefan Roese
This patch adds SPL support to the maxbcm MV78460 based board. Including the fixed DDR configuratrion needed for the DDR training code. And the the serdes PHY init code. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2015-02-02Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2015-02-02sunxi: video: Force h/vsync active high when using ext. vga dac on some boardsHans de Goede
On both my A13-OLinuxIno and my A13-OLinuxIno-Micro, the vga output gives an unstable image when active low v or hsync is used. The problem seems to be specific to the OLinuxIno A13 (normal & micro) boards. I've just looked up the schematics and they use an opendrain driver for the vga sync lines, and with sync pulses it is the logical high->low edge of the pulse which counts for the timing, which with an active low sync is being driven by the pull-up, and that simply seems to not drive it hard enough to get a stable image. So force v and hsync active high on these boards. independent of what the modeline says. This fixes the unstable image. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: Add Inet 86VS supportMichal Suchanek
Signed-off-by: Michal Suchanek <hramrach@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-02sunxi: TZX-Q8-713B7 supportPaul Kocialkowski
Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-02sunxi: Add Linksprite_pcDuino3_Nano board / defconfigAdam Sampson
This is a low-cost Allwinner A20 board with Arduino-style GPIO headers; it features 1G RAM, 4G NAND flash, 1 micro-SD, 2 USB sockets, 1 micro USB socket for OTG and another for power in, HDMI, SATA, 5V power for SATA devices, gigabit Ethernet, an IR receiver, 3.5mm audio out and a MIPI camera connector. Like the BananaPi, this board needs GMAC_TX_DELAY set to 3 in order for GMAC to work reliably at gigabit speeds. For more details, see: http://linux-sunxi.org/LinkSprite_pcDuino3_Nano Signed-off-by: Adam Sampson <ats@offog.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-02sunxi: Remove CONFIG_TARGET_FOO for sun5i and sun7i boardsHans de Goede
CONFIG_TARGET_FOO was only used in board/sunxi/Makefile to select the dram config for sun5i and sun7i boards and in board/sunxi/gmac.c for some special handling of the bananapi/bananapro (both sun7i), all sun5i and sun7i boards have been moved over to using a single dram_sun5i_autoconfig file, and the tx clk delay handling for the Banana boards now has its own Kconfig. IOW nothing is using CONFIG_TARGET_FOO anymore, so remove it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: Add a GMAC Transmit Clock Delay Chain Kconfig optionHans de Goede
And use this to set the GMAC Transmit Clock Delay Chain value on Banana boards, rather then keying of CONFIG_TARGET_FOO. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: Convert sun5i boards to use auto dram configurationHans de Goede
Currently we've separate detailed dram settings for all sun5i boards, this moves them over to using auto dram configuration so that we can get rid of all the per board dram_foo.c files. This has been tested on a A10s-Olinuxino, A13-Olinuxino, A13-OlinuxinoM, mk802-a10s and r7-tv-dongle board. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: Hyundai_A7HD_defconfig fix USB vbus pin configHans de Goede
USB1_VBUS is not used, and USB2_VBUS uses the pin normally used to control USB1_VBUS. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-30Merge branch 'master' of git://git.denx.de/u-boot-dmTom Rini
2015-01-30vexpress64: support the Juno Development PlatformLinus Walleij
The Juno Development Platform is a physical Versatile Express device with some differences from the emulated semihosting models. The main difference is that the system is split in a SoC and an FPGA where the SoC hosts the serial ports at totally different adresses. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-01-30vexpress64: get rid of CONFIG_SYS_EXTRA_OPTIONSLinus Walleij
The Versatile Express ARMv8 semihosted FVP platform is still using the legacy CONFIG_SYS_EXTRA_OPTIONS method to configure some compile-time flags. Get rid of this and create a Kconfig entry for the FVP model, and a selectable bool for the semihosting library. The FVP subboard is now modeled as a target choice so we can eventually choose between different ARMv8 versatile express boards (FVP, base model, Juno...) this way. All dependent symbols are updated to reflect this. The 64bit Versatile Express board symbols are renamed VEXPRESS64 so we have some chance to see what is actually going on. Tested on the FVP fast model. Acked-by: Steve Rae <srae@broadcom.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-01-29lib/rsa: Modify rsa to use DM driverRuchika Gupta
Modify rsa_verify to use the rsa driver of DM library .The tools will continue to use the same RSA sw library. CONFIG_RSA is now dependent on CONFIG_DM. All configurations which enable FIT based signatures have been modified to enable CONFIG_DM by default. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29configs: Move CONFIG_FIT_SIGNATURE to defconfigRuchika Gupta
For the platforms which use,CONFIG_FIT_SIGNATURE, the required configs are moved to the platform's defconfig file. Selecting CONFIG_FIT_SIGNATURE using defconfig automatically resolves the dependencies for signature verification. The RSA library gets automatically selected and user does not have to define CONFIG_RSA manually. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29ARM: UniPhier: enable I2C for UniPhier SoCsMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-26Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2015-01-26Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2015-01-23arm: ls102xa: Add LPUART support for LS1021ATWR boardAlison Wang
This patch adds LPUART support for LS1021ATWR board. For ls1021atwr_nor_lpuart_defconfig, LPUART is used as the console. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-23arm: ls102xa: Add LPUART support for LS1021AQDS boardAlison Wang
This patch adds LPUART support for LS1021AQDS board. For ls1021aqds_nor_lpuart_defconfig, LPUART is used as the console. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-23x86: Drop the x86_fb driverSimon Glass
Now that we have a full VESA driver we may as well use that. We need to support the VESA layer being set up by early start-up code or by running a VGA ROM. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-23powerpc: remove icecube_5200, Lite5200, cpci5200, mecp5200, pf5200Masahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2015-01-23powerpc: mpc5xxx: PM520 board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Josef Wagner <Wagner@Microsys.de>
2015-01-23powerpc: mpc5xxx: remove Total5200 board supportMasahiro Yamada
2015-01-23powerpc: ppc4xx: remove PPChameleonEVB, CATcenter boardsMasahiro Yamada
These boards are still non-generic boards. It is a good thing that we can drop board-specific hack code from drivers/mtd/nand/nand_base.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Andrea "llandre" Marson <andrea.marson@dave-tech.it>
2015-01-23powerpc: mpc85xx: remove P2020DS board supportMasahiro Yamada
2015-01-23powerpc: mpc85xx: remove P2020COME board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Ira W. Snyder <iws@ovro.caltech.edu>
2015-01-23powerpc: mpc85xx: remove P1_P2_RDB boardsMasahiro Yamada
These boards are still non-generic boards: P1011RDB, P1022RDB, P2010RDB, P2020RDB Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
2015-01-23powerpc: mpc83xx: remove MPC8360ERDK, EMPC8360EMDS supportMasahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Dave Liu <daveliu@freescale.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
2015-01-23Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-01-23sunxi: Add Hyundai A7HD supportHans de Goede
The Hyundai A7HD is a 7" 16:9 A10 powered tablet featuring 1G RAM, 8G nand, 1024x600 IPS screen, a mini hdmi port, mini usb receptacle and a headphones port for details see: http://linux-sunxi.org/Hyundai_A7HD Cc: Mark Janssen <maniac@maniac.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-23sunxi: Add support for Mele M5.Ian Campbell
HDMI, SATA, USB and Ethernet appear functional, I've not done extensive tests of all peripherals though. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-23sunxi: Convert sun7i boards to use auto dram configurationHans de Goede
Currently we've separate detailed dram settings for all sun7i boards, this moves them over to using auto dram configuration so that we can get rid of all the per board dram_foo.c files. This has been tested on a A20-Olinuxino-Lime, A20-Olinuxino_MICRO, Bananapi, Bananapro, Cubieboard2, Cubietruck, Mele_M3 and a Linksprite_pcDuino3. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
