path: root/configs
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-16x86: Rename coreboot-x86 to corebootSimon Glass
We only use coreboot as a target on x86 platforms, since on ARM platforms U-Boot always runs as the primary boot loader. Rename the coreboot-x86 platform to reflect this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-04-16x86: Change default FRAMEBUFFER_VESA_MODE of some boardsBin Meng
This changes some boards' default FRAMEBUFFER_VESA_MODE to use 32-bit pixel format for better VxWorks compatibility. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-15Merge git://git.denx.de/u-boot-imxTom Rini
2018-04-15Merge git://git.denx.de/u-boot-netTom Rini
2018-04-15mx31ads: DeleteTom Rini
This platform has been marked as orphaned since September 2013, remove. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-15imx31_phycore: DeleteTom Rini
2018-04-15pico-imx7d: Replace fatload commandVanessa Maegima
Replace fatload with the fs generic loading interface ('load' command). Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-04-15imx: board: Add support for the K+P's kp_imx6q_tpc boardLukasz Majewski
This commit provides support for Kieback & Peter GmbH IMX6Q based TPC board. U-boot console output: U-Boot SPL 2018.05-rc1-00005-g631e2d01fd (Apr 04 2018 - 21:16:24 +0200) Trying to boot from MMC1 U-Boot 2018.05-rc1-00005-g631e2d01fd (Apr 04 2018 - 21:16:24 +0200) CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz) CPU: Extended Commercial temperature grade (-20C to 105C) at 37C Reset cause: POR Board: K+P KP_IMX6Q_TPC i.MX6Q Watchdog enabled I2C: ready DRAM: 2 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from MMC... OK In: serial Out: serial Err: serial Net: FEC [PRIME] Autoboot in 3 seconds
2018-04-15arm: imx: Add Winbond SPI-NOR support for Advantech DMS-BA16 boardKen Lin
Windbond's been in the AVL list and need to enable the support Signed-off-by: Ken Lin <yungching0725@gmail.com>
2018-04-14ARM: rmobile: Zap CONFIG_MMC_RENESAS_TUNINGMarek Vasut
Drop the CONFIG_MMC_RENESAS_TUNING symbol from Gen3 configs. This symbol is no longer used after the Matsushita SDHI driver, instead the renesas-sdhi driver uses CONFIG_MMC_HS200_SUPPORT to discern whether the tuning support should be compiled in. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> -- V2: Submit this on top of configs which are actually in mainline
2018-04-13ARM: rmobile: Convert TPL to SPLMarek Vasut
There is currently no use for building the SPL anymore, since the SPI loader can easily be replaced by TPL and TPL does load U-Boot directly. Upgrade TPL to SPL and replace what used to be SPL with it. This way we build the U-Boot sources only twice, not thrice. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-13ARM: rmobile: Shrink the TPLMarek Vasut
Shrink the TPL by using tiny printf and tiny memset by default. This removes the biggest symbol -- vsnprintf_internal -- from the TPL and reduces the text segment by about 2 kiB. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-13ARM: rmobile: Update H2 StoutMarek Vasut
The H2 Stout port was broken since some time. This patch updates the H2 Stout port to use modern frameworks, DM, DT probing, SPL and TPL for the preloading and puts it on par with the M2 Porter board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-13configs: Fixup some CPSW-related itemsTom Rini
- For am335x_pdu001 we do not want the CPSW driver, drop it - Re-sync the defconfig for am43xx_evm_rtconly as it came in after the patch that converted CPSW to Kconfig was posted but before it was applied. - Drop empty section / comments from pengwyn - Drop empty section / comments from baltos and drop unused CONFIG_SPL_NET_VCI_STRING (it does not enable CONFIG_SPL_NET_SUPPORT currently and SPL_NET_VCI_STRING has been migrated already). Cc: Felix Brack <fb@ltec.ch> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Yegor Yefremov <yegorslists@googlemail.com> Cc: Lothar Felten <lothar.felten@gmail.com> Fixes: f02b8d17619f ("Migrate CONFIG_DRIVER_TI_CPSW to Kconfig") Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Felix Brack <fb@ltec.ch> Tested-by: Felix Brack <fb@ltec.ch>
2018-04-13net: phy: Don't limit phy addresses by defaultJoe Hershberger
Some boards expect to find more than one phy while other boards are old and need to be limited to a specific phy address. Only limit the phy address for boards that opt in. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-04-13configs: dra7xx_evm/dra7xx_hs_evm: Enable AHCI and PIPE3Jean-Jacques Hiblot
Those options are required to enable support for SATA on DRA7 platforms. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-04-11ARM: rmobile: Enable HS200 mode on RCar Gen3Marek Vasut
Enable the HS200 on RCar Gen3 platforms, since the SDHI core supports it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11ARM: rmobile: Switch to CONFIG_RENESAS_SDHIMarek Vasut
Since the Renesas SDHI has it's own custom driver sharing the common code with Uniphier one, adjust the Kconfig entries. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-11ARM: rmobile: Enable HUSH on M2 PorterMarek Vasut
Enable the HUSH shell, since it is far more capable. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11ARM: rmobile: Add JTAG recovery support for M2 PorterMarek Vasut
Add JTAG recovery support into the M2 Porter TPL. This allows the TPL to be loaded over JTAG, initialize the system, wait for the JTAG debugger to load U-Boot image into RAM and then resume and start U-Boot from RAM. The procedure is as follows: 1) Load u-boot-tpl.bin to 0xe6300000 2) Write magic number 0x1337c0de to 0xe6300020 TPL checks for this particular magic and starts JTAG recovery if this number is present. This is not present by default. 3) Start U-Boot TPL from 0xe6300000 4) Wait for a message from TPL on UART indicating JTAG boot: "JTAG boot detected!" 5) Halt the system in JTAG debugger 6) Load U-Boot image (u-boot.img) to 0x4fffffc0 7) Write magic number 0xb33fc0de to 0xe6300024 TPL checks for this particular magic to verify that the U-Boot image was loaded into DRAM by the JTAG debugger. 8) Resume the system in JTAG debugger Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11ARM: rmobile: Add TPL support on R8A7791 M2 PorterMarek Vasut
Add and enable TPL on M2 Porter. The TPL must fit into 16 kiB due to the Gen2 BootROM restriction. The TPL is running from MERAM and is capable of performing the initial initialization of PFC, Clock, GPIO, LBSC, DBSC and QSPI NOR. DBSC is responsible for bringing up the DDR DRAM access. The TPL is capable of loading the next stage, U-Boot, from either SPI NOR or UART as a fallback. If either does provide a valid U-Boot uImage, the system stops, which allows the operator to load U-Boot ie. via JTAG and start it manually. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-09Merge tag 'xilinx-for-v2018.05-rc2' of git://git.denx.de/u-boot-microblazeTom Rini
Xilinx changes for v2018.05-rc2 - Various DT changes and sync with mainline kernel - Various defconfig updates - Add SPL init for zcu102 revA - Add new zynqmp boards zcu100/zcu104/zcu106/zcu111/zc12XX and zc1751-dc3 - Net fixes - xlnx,phy-type - 64bit axi ethernet support - arasan: Fix nand write issue - fpga fixes - Maintainer file updates
2018-04-09arm64: zynqmp: Add support for Xilinx zcu111-revAMichal Simek
Xilinx zcu111 is a customer board. It is reusing some parts from zcu102. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Add support for Xilinx zcu106-revAMichal Simek
Xilinx zcu106 is a customer board. It is reusing some parts from zcu102. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Add support for zcu104 customer boardMichal Simek
Xilinx zcu104 is another customer board. It is sort of zcu102 clone with some differences. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Add support for zc12xx boardsMichal Simek
Add support for zc12xx boards. All of them are internal boards for silicon validation and share very similar base platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Add support for zc1751 dc3Michal Simek
zc1751 is based board with dc3 extenstion card which is used for silicon validation. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Add support for zcu100 aka Ultra96 boardMichal Simek
Add support for Xilinx zcu100. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Enable Fixed link supportMichal Simek
This patch enables the fixed link support for all ZynqMP boards. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Enable mac address randomization for zc1751 dc5Michal Simek
There is no memory which stores mac address that's why generate it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Enable ethernet phys for zc1751 dc5Michal Simek
Enable ethernet phys for zc1751 dc5. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Enable booting to ATFLuca Ceresoli
U-Boot is now able to boot to ARM Trusted Firmware (ATF). The boot flow is SPL(EL3) loads ATF and full u-boot and jump to ATF(EL3) which pass control to full u-boot(EL2). This has been tested on zcu106, so enable it in this defconfig. To generate an image that triggers this booting flow, you need to pass '-O arm-trusted-firmware' to mkimage. Signed-off-by: Luca Ceresoli <luca@lucaceresoli.net> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09ARM: dts: zynq: Rename dts for Z-turn boardAnton Gerasimov
Makes naming in line with other Zynq boards. Signed-off-by: Anton Gerasimov <tossel@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-08Cleanup CONFIG_VERSION_VARIABLE migrationAlex Kiernan
CONFIG_VERSION_VARIABLE had already been mostly migrated to Kconfig, but two headers still referenced it. Also set defaults so that most of the defconfigs inherit the default rather than needing it to be set explicitly. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-08Migrate CONFIG_DRIVER_TI_CPSW to KconfigAlex Kiernan
This converts CONFIG_DRIVER_TI_CPSW to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_LAST_STAGE_INIT to KconfigMario Six
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-06configs: am43xx_evm_qspiboot_defconfig: Move to DMVignesh R
Move am43xx_evm_qspiboot_defconfig to DM. This is required as SPI core and TI QSPI driver no longer supports non DM interfaces. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-04-06configs: k2hk_hs_evm: Resync defconfig with non-HS defconfigAndrew F. Davis
Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh vutla <lokeshvutla@ti.com>
2018-04-06configs: k2e_hs_evm: Resync defconfig with non-HS defconfigAndrew F. Davis
2018-04-06configs: k2g_hs_evm: Resync defconfig with non-HS defconfigAndrew F. Davis
