Enable DM I2C driver on SoCFPGA platforms.
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot
could load distro images that usually get shipped as iso images. These images
usually come with a board agnostic boot environment.
However, there is very little point in having ISO support enabled (for anyone
really) in SPL, as the whole idea of SPL is to load U-Boot proper which again
is board specific. So the fact that we enable ISO support in U-Boot proper does
not mean at all that we want ISO support in U-Boot SPL.
Hence, let's remove the Kconfig dependency. Along the way, let's also clean up
all those default configs that disabled SPL ISO support.
We only use coreboot as a target on x86 platforms, since on ARM platforms
U-Boot always runs as the primary boot loader. Rename the coreboot-x86
platform to reflect this.
This changes some boards' default FRAMEBUFFER_VESA_MODE to use 32-bit
pixel format for better VxWorks compatibility.
This platform has been marked as orphaned since September 2013, remove.
Replace fatload with the fs generic loading interface ('load' command).
Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
This commit provides support for Kieback & Peter GmbH IMX6Q based
TPC board.
U-boot console output:
U-Boot SPL 2018.05-rc1-00005-g631e2d01fd (Apr 04 2018 - 21:16:24 +0200)
Trying to boot from MMC1
U-Boot 2018.05-rc1-00005-g631e2d01fd (Apr 04 2018 - 21:16:24 +0200)
CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 37C
Reset cause: POR
Board: K+P KP_IMX6Q_TPC i.MX6Q
Watchdog enabled
I2C: ready
DRAM: 2 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... OK
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Autoboot in 3 seconds
Windbond's been in the AVL list and need to enable the support
Signed-off-by: Ken Lin <yungching0725@gmail.com>
Drop the CONFIG_MMC_RENESAS_TUNING symbol from Gen3 configs.
This symbol is no longer used after the Matsushita SDHI driver,
instead the renesas-sdhi driver uses CONFIG_MMC_HS200_SUPPORT
to discern whether the tuning support should be compiled in.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
V2: Submit this on top of configs which are actually in mainline
There is currently no use for building the SPL anymore, since the
SPI loader can easily be replaced by TPL and TPL does load U-Boot
directly. Upgrade TPL to SPL and replace what used to be SPL with
it. This way we build the U-Boot sources only twice, not thrice.
Shrink the TPL by using tiny printf and tiny memset by default.
This removes the biggest symbol -- vsnprintf_internal -- from
the TPL and reduces the text segment by about 2 kiB.
The H2 Stout port was broken since some time. This patch updates
the H2 Stout port to use modern frameworks, DM, DT probing, SPL
and TPL for the preloading and puts it on par with the M2 Porter
board.
- For am335x_pdu001 we do not want the CPSW driver, drop it
- Re-sync the defconfig for am43xx_evm_rtconly as it came in after the
patch that converted CPSW to Kconfig was posted but before it was
applied.
- Drop empty section / comments from pengwyn
- Drop empty section / comments from baltos and drop unused
CONFIG_SPL_NET_VCI_STRING (it does not enable CONFIG_SPL_NET_SUPPORT
currently and SPL_NET_VCI_STRING has been migrated already).
Cc: Felix Brack <fb@ltec.ch>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Yegor Yefremov <yegorslists@googlemail.com>
Cc: Lothar Felten <lothar.felten@gmail.com>
Fixes: f02b8d17619f ("Migrate CONFIG_DRIVER_TI_CPSW to Kconfig")
Reviewed-by: Felix Brack <fb@ltec.ch>
Tested-by: Felix Brack <fb@ltec.ch>
Some boards expect to find more than one phy while other boards are old
and need to be limited to a specific phy address. Only limit the phy
address for boards that opt in.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Those options are required to enable support for SATA on DRA7 platforms.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Enable the HS200 on RCar Gen3 platforms, since the SDHI core supports it.
Since the Renesas SDHI has it's own custom driver sharing the
common code with Uniphier one, adjust the Kconfig entries.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Enable the HUSH shell, since it is far more capable.
Add JTAG recovery support into the M2 Porter TPL. This allows the
TPL to be loaded over JTAG, initialize the system, wait for the
JTAG debugger to load U-Boot image into RAM and then resume and
start U-Boot from RAM.
The procedure is as follows:
1) Load u-boot-tpl.bin to 0xe6300000
2) Write magic number 0x1337c0de to 0xe6300020
TPL checks for this particular magic and starts JTAG recovery
if this number is present. This is not present by default.
3) Start U-Boot TPL from 0xe6300000
4) Wait for a message from TPL on UART indicating JTAG boot:
"JTAG boot detected!"
5) Halt the system in JTAG debugger
6) Load U-Boot image (u-boot.img) to 0x4fffffc0
7) Write magic number 0xb33fc0de to 0xe6300024
TPL checks for this particular magic to verify that the U-Boot
image was loaded into DRAM by the JTAG debugger.
8) Resume the system in JTAG debugger
Add and enable TPL on M2 Porter. The TPL must fit into 16 kiB due
to the Gen2 BootROM restriction. The TPL is running from MERAM and
is capable of performing the initial initialization of PFC, Clock,
GPIO, LBSC, DBSC and QSPI NOR. DBSC is responsible for bringing up
the DDR DRAM access. The TPL is capable of loading the next stage,
U-Boot, from either SPI NOR or UART as a fallback. If either does
provide a valid U-Boot uImage, the system stops, which allows the
operator to load U-Boot ie. via JTAG and start it manually.
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all
configurations using it to Kconfig.
Xilinx changes for v2018.05-rc2
- Various DT changes and sync with mainline kernel
- Various defconfig updates
- Add SPL init for zcu102 revA
- Add new zynqmp boards zcu100/zcu104/zcu106/zcu111/zc12XX
and zc1751-dc3
- Net fixes - xlnx,phy-type
- 64bit axi ethernet support
- arasan: Fix nand write issue
- fpga fixes
- Maintainer file updates
Xilinx zcu111 is a customer board. It is reusing some parts from zcu102.
Xilinx zcu106 is a customer board. It is reusing some parts from zcu102.
Xilinx zcu104 is another customer board. It is sort of zcu102 clone with
some differences.
Add support for zc12xx boards. All of them are internal boards for
silicon validation and share very similar base platforms.
zc1751 is based board with dc3 extenstion card which is used for silicon
validation.
Add support for Xilinx zcu100.
This patch enables the fixed link support for
all ZynqMP boards.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
There is no memory which stores mac address that's why generate it.
Enable ethernet phys for zc1751 dc5.
U-Boot is now able to boot to ARM Trusted Firmware (ATF). The boot
flow is SPL(EL3) loads ATF and full u-boot and jump to ATF(EL3) which
pass control to full u-boot(EL2). This has been tested on zcu106, so
enable it in this defconfig.
To generate an image that triggers this booting flow, you need to pass
'-O arm-trusted-firmware' to mkimage.
Signed-off-by: Luca Ceresoli <luca@lucaceresoli.net>
Makes naming in line with other Zynq boards.
Signed-off-by: Anton Gerasimov <tossel@gmail.com>
CONFIG_VERSION_VARIABLE had already been mostly migrated to Kconfig,
but two headers still referenced it. Also set defaults so that
most of the defconfigs inherit the default rather than needing it
to be set explicitly.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
This converts CONFIG_DRIVER_TI_CPSW to Kconfig
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Migrate the CONFIG_TSEC_ENET option to Kconfig.
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig.
[trini: Re-run migration]
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig.
Migrate the CONFIG_BOARD_EARLY_INIT_R option to Kconfig.
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig.
[trini: Re-run migration after also including CMD_MEMTEST]
Move am43xx_evm_qspiboot_defconfig to DM. This is required as SPI core
and TI QSPI driver no longer supports non DM interfaces.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Signed-off-by: Andrew F. Davis <afd@ti.com>
Reviewed-by: Lokesh vutla <lokeshvutla@ti.com>
