path: root/configs
2015-08-14Merge git://git.denx.de/u-boot-x86Tom Rini
2015-08-14x86: minnowmax: Define and enable interrupt setupSimon Glass
Set up interrupts correctly so that Linux can use all devices. Use savedefconfig to regenerate the defconfig file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-14x86: Convert minnowmax to use CONFIG_DM_NETSimon Glass
Move to driver model for networking on minnowmax. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-14x86: Convert minnowmax to use CONFIG_DM_USBSimon Glass
Move to driver model for USB on minnowmax. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-14x86: Re-order efi-x86_defconfigSimon Glass
Use savedefconfig to get this file into the correct order. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-14sunxi: Display: Add support for eDP panels connected via an anx9804 bridgeHans de Goede
Add support for 4 1.62G lane eDP panels connected via an anx9804 bridge, such as found on the Colombus devkit. While at it also fix the wrong indentation of the SSD2828 Kconfig help text in board/sunxi/Kconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-14sunxi: Fix gmac not working on the Colombus boardHans de Goede
The phy is using a RGMII interface, which we need to specify in our board-config, and the dts needs a gmac section (the dts changes have also been submitted to the kernel). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-14sunxi: display: Disable HDMI support on A13 based tabletsHans de Goede
The sun5i die has a hdmi encoder onboard, but the A13 package does not route this to the outside, disable hdmi support on A13 based boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-14sunxi: display: Enable composite video support on more boardsHans de Goede
Enable composite video support on all boards which have a composite video out connector (either cinch or jack). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-14sunxi: Add support for the Auxtek-T003 HDMI stickHans de Goede
The Auxtek-T003 HDMI stick is an A10s based HDMI stick with USB wifi, and composite video out support. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-12ARM: drop "optional" from target select in favor of ARCH_VERSATILEMasahiro Yamada
Since commit a26cd04920dc ("arch: Make board selection choices optional"), Kconfig could create such an insane .config file that no SoC/board is selected. This is now a real problem for Buildroot, for example. (http://lists.busybox.net/pipermail/buildroot/2015-July/135125.html) This commit drops the "optional" from the ARM target select menu in favor of "Versatile family". Rationale: - Historically, Linux chose versatile_defconfig as the default of ARM defconfig. (arch/arm/Makefile of Linux describes: KBUILD_DEFCONFIG := versatile_defconfig) - It was published by ARM Ltd. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-08-12dra7xx: Add dra72_evm_defconfig using CONFIG_DMTom Rini
- Import various DT files for DRA7 / DR72x / dra72-evm from Linux Kernel v4.1 - Add config file for this board, enable DM and DM_GPIO Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-12dra7xx: Move CONS_INDEX to Kconfig and enable CONFIG_SPL_STACK_ADDRTom Rini
- Move the CONS_INDEX selection out of CONFIG_SYS_EXTRA_OPTIONS and into Kconfig proper. - While in here, enable CONFIG_SPL_STACK_ADDR Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12am33xx: Update DT files, add am335x_gp_evm_config targetTom Rini
- Re-sync DT files for am33xx with Linux Kernel v4.1 - Include DT file now for the "AM335x GP EVM" and build target for it, via device tree and DM. - We only need to provide platform data for UART when OF_CONTROL isn't also enabled really. We can just push GPIO to coming from DT Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12arm: am437x: Introduce new board cm-t43Nikita Kiryanov
Add initial support for CM-T43, an AM437x based SoM. This support includes: serial, MMC/eMMC, NAND, USB, ETH, I2C, GPIO, DRAM detection. Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-08-12ARM64: hikey: hi6220: Add u-boot support for the 96boards CE HiKey board.Peter Griffin
HiKey is the first 96boards consumer edition compliant board. It features a hi6220 SoC which has eight ARM A53 cpu's. This initial port adds support for: - 1) Serial 2) eMMC / SD card 3) USB 4) GPIO It has been tested with Arm Trusted Firmware running u-boot as the BL33 executable. Notes: eMMC has been tested with basic reading of eMMC partition into DDR. I have not tested writing / erasing. Due to lack of clock control it won't be running in the most performant high speed mode. SD card slot has been tested for reading and booting kernels into DDR. It is also currently configured to save the u-boot environment to the SD card. USB has been tested with ASIX networking adapter to tftpboot kernels into DDR. On v2015.07-rc2 dhcp now works, and also USB mass storage are correctly enumerated. GPIO has been tested using gpio toggle GPIO4_1-3 to flash the LEDs. Basic SoC datasheet can be found here: - https://github.com/96boards/documentation/blob/master/hikey/ Hi6220V100_Multi-Mode_Application_Processor_Function_Description.pdf Board schematic can be found here: - https://github.com/96boards/documentation/blob/master/hikey/ 96Boards-Hikey-Rev-A1.pdf Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
2015-08-12sniper: Fastboot supportPaul Kocialkowski
This adds support for the fastboot USB gadget, including flashing to the internal MMC and reboot to bootloader or not. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Update to use Kconfig for MUSB] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12LG Optimus Black (P970) codename sniper supportPaul Kocialkowski
The LG Optimus Black (P970) codename sniper is a smartphone that was designed and manufactured by LG Electronics (LGE) and released back in 2011. It is using an OMAP3630 SoC GP version, which allows running U-Boot and the U-Boot SPL from the ground up. This port is aimed at running an Android version such as Replicant, the fully free Android distribution. However, support for upstream Linux with device-tree and common GNU/Linux distros boot commands could be added in the future. For more information about the journey to freeing this device, please read the series of blog posts at: http://code.paulk.fr/article20/a-hacker-s-journey-freeing-a-phone-from-the-ground-up-first-part Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Add CONFIG_OF_SUPPORT] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12lpc32xx: devkit3250: add spl build supportVladimir Zapolskiy
The change adds SPL build support to Timll DevKit3250 board, the generated SPL image can be uploaded over UART5, JTAG or stored on NAND. SPL is designed to load U-boot image from NAND. All new NAND chip defines in board configuration are needed by SPL NAND "simple" framework, the framework is used to reduce potentially duplicated code from LPC32xx SLC NAND driver. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-08-12lpc32xx: devkit3250: update of board configurationVladimir Zapolskiy
This change adds more peripherals to Timll DevKit3250 board, namely MAC and SMSC phy, SLC NAND, GPIO, SPI and I2C. Also the default serial console is changed to UART5, added an option to pass device tree blob by means of bootm, predefined environment variables are slightly extended and reserved space on NAND to store user defined U-boot environment. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-08-12arm, at91: support for sam9260 based smartweb boardHeiko Schocher
add support for the at91sam9260 based board smartweb from siemens. SPL is used without serial support, as this SoC has only 4k sram for running SPL. Here a U-Boot bootlog: RomBOOT > U-Boot 2015.07-rc2-00109-g4ae828c (Jun 15 2015 - 09:31:16 +0200) CPU: AT91SAM9260 Crystal frequency: 18.432 MHz CPU clock : 198.656 MHz Master clock : 99.328 MHz Watchdog enabled DRAM: 64 MiB WARNING: Caches not enabled NAND: 256 MiB In: serial Out: serial Err: serial Net: macb0 Hit any key to stop autoboot: 0 U-Boot> Signed-off-by: Heiko Schocher <hs@denx.de>
2015-08-08Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-08-08sunxi: display: Add composite video out supportHans de Goede
Add composite video out support. This only gets enabled on the Mele M3 for now, since that is were it was tested. It will be enabled on more boards after testing. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-08sunxi: Enable musb in host mode on the Jesurun Q5Hans de Goede
The Jesurun Q5 has the musb hooked up to an usb-a receptacle, enable it in host-only mode. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-08sunxi: Add CONFIG_USB0_ID_DET setting to 2 more tabletsHans de Goede
Now that we have code to check the id-pin and detect usb-host adapters plugged into the otg port that way, enable it on the tablets which I own. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-08sunxi: Enable USB DRC on Wexler TAB7200Aleksei Mamlin
Enable the otg/drc usb controller on the Wexler TAB7200 tablet. Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-08-08arm: socfpga: config: Move SPL GD and malloc to RAMMarek Vasut
Now that the SPL structure is organised such that it matches the U-Boot's SPL design, it is possible to use the option of relocating GD to RAM. And since we have GD in RAM, move malloc area to RAM as well. We point the malloc base pointer 1 MiB past U-Boot's load address. We use simple malloc for SPL because it is 3kiB smaller in terms of code size than regular malloc which was used thus far. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-08arm: socfpga: misc: Probe ethernet GMAC from OFMarek Vasut
The GMAC can now be probed from OF, so enable DM ethernet and remove the old ad-hoc designware_initialize() invocation. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2015-08-08arm: socfpga: spl: Add support for booting from QSPIMarek Vasut
Add code and configuration options to support booting from QSPI NOR. Enable support for booting from QSPI NOR. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-08arm: socfpga: spl: Add support for booting from SD/MMCMarek Vasut
Add code and configuration options to support booting from RAW SD/MMC card as well as for ext4/vfat filesystems. Enable support for booting from SD/MMC card, but don't enable the filesystem support just yet to retain compatibility with old SoCFPGA card format. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-06Merge git://git.denx.de/u-boot-dmTom Rini
2015-08-06ARM: tegra: Add p2371-0000 boardStephen Warren
P2371-0000 is a P2581 or P2530 CPU board married to a P2595 I/O board. The combination contains SoC, DRAM, eMMC, SD card slot, HDMI, USB micro-B port, Ethernet via USB3, USB3 host port, SATA, a GPIO expansion header, and an analog audio jack. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-06ARM: tegra: Add e2220-1170 boardStephen Warren
E2220-1170 is a Tegra210 bringup board with onboard SoC, DRAM, eMMC, SD card slot, HDMI, USB micro-B port, and sockets for various expansion modules. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-06x86: Enable debug UART for MinnowmaxSimon Glass
Enable the debug UART and emit a single 'a' early in the init sequence to show that it is working. Unfortunately the debug UART implementation needs a stack to work. I cannot seem to remove this limitation as the absolute 'jmp %eax' instruction goes off into the weeds. So this means that the character output cannot be any earlier than car_init_ret, where memory is available for a stack. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-08-06sandbox: Enable devres subsystemSimon Glass
This should be used for sandbox. We can convert at least one driver to use it, but in the meantime, enable the feature so that the code is build-tested. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-06dm: Make regmap and syscon optionalSimon Glass
Not all boards use garbage collection in their link step, so we should avoid adding options that rely on this for prevention of code bloat. Add separate Kconfig options for syscon and regmap uclasses. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: Add support for springSimon Glass
Spring is the first ARM-based HP Chromebook 11. It is similar to snow and it uses the same Samsung Exynos5250 chip. But has some unusual features. Mainline support for it has lagged snow (both in kernel and U-Boot). Now that the exynos5 code is common we can support spring just by adding a device tree and a few lines of configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: Enable new features for exynos5 boardsSimon Glass
Enable PMICs, regulators and the like so that new drivers will be made available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05dm: cros_ec: Convert the I2C tunnel code to use driver modelSimon Glass
The Chrome OS EC supports tunnelling through to an I2C bus on the EC. This currently uses a copy of the I2C command code and a special 'crosec' sub-command. With driver model we can define an I2C bus which tunnels through to the EC, and use the normal 'i2c' command to access it. This simplifies the code and removes some duplication. Add an I2C driver which tunnels through to the EC. Adjust the EC code to support binding child devices so that it can be set up. Adjust the existing I2C xfer function to fit driver model better. For now the old code remains to allow things to still work. It will be removed in a later patch once the new flow is fully enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05Tegra: spi: Move TEGRA114_SPI switch to defconfigsTom Warren
All T114+ Tegra boards should be using the Kconfig TEGRA114_SPI switch. Remove it from include/config and put it into defconfig. Also removed unused TEGRA114_SPI_CTRLS from T114+ configs. All Tegra SoCs build OK with this change. Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-05Merge git://git.denx.de/u-boot-x86Tom Rini
2015-08-05sunxi: usb: USB_MUSB_SUNXI move to musb-new KconfigPaul Kocialkowski
Now that the musb-new driver has a Kconfig, we can move Kconfig options to enable controllers to it, so that it's easier in e.g. menuconfig. In addition, this allows declaring support for USB_MUSB_HOST/GADGET in defconfigs instead of the USB_MUSB_SUNXI controller, that will get selected automatically when needed. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-08-05x86: Add definitions for the x86-efi board and plumb it inBen Stoltz
Add configuration and Kconfig changes for this board. Signed-off-by: Ben Stoltz <stoltz@google.com> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05x86: Move Chrome OS options to defconfigSimon Glass
Drop these from the header file and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05x86: bayleybay: Configure PCI IRQBin Meng
Add PCI IRQ routing information in the board device tree and enable writing PIRQ routing table and MP table. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-05x86: Add Intel Bayley Bay board supportBin Meng
Intel Bayley Bay board is a BayTrail based board. Add this board with existing baytrail fsp support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-05x86: qemu: Add MP initializationBin Meng
Add a cpu1 node to the device tree and enable the MP initialization on QEMU targets (i440fx and q35). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-08-02Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-08-02arm: mx6: tqma6: fix build for WRU-IV baseboardStefano Babic
Fix: undefined reference to `spi_flash_free' undefined reference to `spi_flash_probe' Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Stefan Roese <sr@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Stefan Roese <sr@denx.de>
