https://gitlab.denx.de/u-boot/custodians/u-boot-imx
For 2020.10
- mx6: SOCs user selectable
Fix for imx6q_logic
Some DM conversion
- mx7: introduce secondary boot device
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/720918010
- Add basic Marvell/Cavium OcteonTX/TX2 support (Suneel)
- Infrastructure changes to PCI uclass to support these SoC's (Suneel)
- Add PCI, MMC & watchdog driver drivers for OcteonTX/TX2 (Suneel)
- Increase CONFIG_SYS_MALLOC_F_LEN for qemu-x86 (Stefan)
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- Fix rk3399 evb sdcard support
- Fix for SPL_LED support
- Sipeed Maix support S-mode.
- Provide command sbi.
- Use fdtdec_get_addr_size_auto_parent to get fu540 cache base address.
- Fix a compiler error with CONFIG_SPL_SMP=n.
- Fix sifive ram driver 32 compiler warnings.
- Fix kendryte/pll.h redefine nop() warning.
With the upcoming increase of the malloc area in U-Boot
("pci: pci-uclass: Dynamically allocate the PCI regions"), the CI QEMU
x86 test fails:
U-Boot 2020.10-rc2-g0a668f6d38 (Aug 25 2020 - 06:12:51 +0000)
alloc space exhausted
Error binding driver 'cpu_qemu': -12
Some drivers failed to bind
initcall sequence fff6a760 failed at call fff13b3d (err=-19)
This patch now increases CONFIG_SYS_MALLOC_F_LEN to 0x1000, which is
already used on qemu-x86_64_defconfig.
Cc: Bin Meng <bmeng.cn@gmail.com>
As explained in the CONFIG_DM_MDIO text inside drivers/net/Kconfig:
"Useful in particular for systems that support
DM_ETH and have a stand-alone MDIO hardware block shared by multiple
Ethernet interfaces."
i.MX6 has a single FEC instance, so there is no need to select
CONFIG_DM_MDIO.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
We have a number of platforms that are a combination of a carrier board
and System-on-Module (SoM) that in turn allows for the board to have
different SoCs on it. In some cases, this is handled via board-specific
Kconfig options. In other cases we make use of
CONFIG_SYS_EXTRA_OPTIONS. This latter case however can lead to invalid
configurations as we will not in turn get options that in Kconfig are
selected by or depend on that setting.
To resolve this, make the SoC option a choice in Kconfig and make boards
depend on what they can support. This change opens us up for further
clean-ups in the cases where a single CONFIG_TARGET_xxx can support
different SoCs and today they do not, or do not cleanly do so.
Reported-by: Matt Porter <mporter@konsulko.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: "NXP i.MX U-Boot Team" <uboot-imx@nxp.com>
Cc: Soeren Moch <smoch@web.de>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Cc: Igor Opaniuk <igor.opaniuk@toradex.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Andreas Geisreiter <ageisreiter@dh-electronics.de>
Cc: Ludwig Zenz <lzenz@dh-electronics.de>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Akshay Bhat <akshaybhat@timesys.com>
Cc: Ken Lin <Ken.Lin@advantech.com.tw>
Cc: Ian Ray <ian.ray@ge.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
Cc: Simone CIANNI <simone.cianni@bticino.it>
Cc: Adam Ford <aford173@gmail.com>
Cc: Marcin Niestroj <m.niestroj@grinn-global.com>
Cc: "Eric Bénard" <eric@eukrea.com>
Cc: Baruch Siach <baruch@tkos.co.il>
Cc: Jason Liu <jason.hui.liu@nxp.com>
Cc: Ye Li <ye.li@nxp.com>
Cc: Eric Nelson <eric@nelint.com>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Parthiban Nallathambi <parthiban@linumiz.com>
Cc: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Niel Fourie <lusus@denx.de>
Cc: Martyn Welch <martyn.welch@collabora.com>
Cc: Richard Hu <richard.hu@technexion.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Boris Brezillon <bbrezillon@kernel.org>
Cc: Arkadiusz Karas <arkadiusz.karas@somlabs.com>
Cc: Breno Lima <breno.lima@nxp.com>
Cc: Francesco Montefoschi <francesco.montefoschi@udoo.org>
Cc: Silvio Fricke <open-source@softing.de>
Tested-by: Matt Porter <mporter@konsulko.com> [colibri_imx6]
Reviewed-by: Marcin Niestroj <m.niestroj@grinn-global.com>
This patch adds support for all OcteonTX2 96xx/95xx
boards from Marvell.
For 96xx boards, use octeontx_96xx_defconfig and
for 95xx boards, use octeontx_95xx_defconfig.
Signed-off-by: Suneel Garapati <sgarapati@marvell.com>
This patch adds support for all OcteonTX 81xx/83xx
For 81xx boards, use octeontx_81xx_defconfig and
for 83xx boards, use octeontx_83xx_defconfig.
Enable PCI memory regions in ranges property to be of multiple entry.
This helps to add support for SoC's like OcteonTX/TX2 where every
peripheral is on PCI bus.
Provide a defconfig that can be used to build U-Boot for the Maix boards
running upon OpenSBI.
Update the documentation.
Reviewed-by: Bin Meng <bin.meng@windriver.com>
Reviewed-by: Sean Anderson <seanga2@gmail.com>
CONFIG_CMD_RUN is set on by default in Kconfig.
Create xenguest_arm64_defconfig by using savedefconfig to avoid unnecessary
options.
Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
Total Compute is based on ARM architecture and has
the following features enabled in u-boot:
- PL011 UART
- PL180 MMC
- NOR Flash
- FIT image with Signature
- AVB
Signed-off-by: Usama Arif <usama.arif@arm.com>
CONFIG_SYS_DEVICE_NULLDEV
CONFIG_SPLASH_SCREEN
CONFIG_SPLASH_SCREEN_ALIGN
CONFIG_SPLASHIMAGE_GUARD
CONFIG_SPLASH_SOURCE
CONFIG_NETCONSOLE
This enable support for SD card on evb-rk3399.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx changes for v2020.10-rc3
- Fix fdtfile variable setup
- Fix bootm_*/fdt_high/initrd_high variables handling
- Fix Kconfig dependencies for Xilinx drivers
- Fix booting u-boot from lowest memory
- Fix firmware payload argument count for Versal
- Fix dfu configurations
- Fix mio_bank property handling
- Fix and align code around ID detection
- Start to use ENV_VARS_UBOOT_RUNTIME_CONFIG
- Simplify logic around reading MAC from eeprom
- Decrease malloc length for zynqmp mini qspi
- Enable preboot for ZynqMP and Versal
i2c:
- Fix i2c eeprom partitions handling
mmc:
- Fix logic around HS mode enabling and use proper functions
Enable this driver to be able to work with i2c based eeproms on Versal.
Remove adhoc dt binding for fixed-partition definition for i2c eeprom.
fixed-partition are using reg property instead of offset/size pair.
Enable DFU tftp support for firmware update. Fill dfu_ram_tftp variable to
have command present for showing how to use it.
boot FIT image has been created from below fragment. Key part is that type
of image has to be firmware. Also based on experiment load property is
completely ignored and base addresses are taken from dfu_alt_info variable.
$ cat update_uboot.its
/dts-v1/;
description = "Automatic U-Boot update";
#address-cells = <1>;
images {
Image {
description = "Kernel";
data = /incbin/("/tftpboot/Image");
compression = "none";
arch = "arm64";
type = "firmware";
os = "linux";
load = <0x80000>;
entry = <0x80000>;
hash-1 {
algo = "sha1";
system.dtb {
description = "DTB";
data = /incbin/("/tftpboot/system.dtb");
arch = "arm64";
type = "firmware";
load = <0>;
hash-1 {
algo = "sha1";
$ mkimage -f update_uboot.its /tftpboot/boot
When U-Boot starts get IP address and server IP.
dhcp
setenv serverip 192.168.0.105
And then run prepared command.
run dfu_ram_tftp
Enable preboot functionality for ZynqMP and Versal platforms.
Add PCIe command and related configs
Signed-off-by: Chuanjia Liu <Chuanjia.Liu@mediatek.com>
Signed-off-by: Henry Yen <henry.yen@mediatek.com>
- Remove pinmux definition from pico-imx6ul.c
- Enable NET_RANDOM_ETHADDR for temporary solution, because micrel_ksz8xxx
driver does not support DM_ETH yet, so cannot read MAC address directly.
Before enable DM_ETH:
Net: FEC [PRIME]
After enable DM_ETH:
Net:
Warning: using random MAC address - ca:3f:43:8f:67:d4
eth1: ethernet@20b4000
Here is the test commands:
=> dhcp
BOOTP broadcast 1
DHCP client bound to address 10.88.88.94 (139 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
=> ping 8.8.8.8
Using ethernet@20b4000 device
host 8.8.8.8 is alive
Signed-off-by: Wig Cheng <wig.cheng@technexion.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
It's due to the warning messages issue after compiled:
===================== WARNING ======================
This board does not use CONFIG_DM_VIDEO Please update
the board to use CONFIG_DM_VIDEO before the v2019.07 release.
Failure to update by the deadline may result in board removal.
See doc/driver-model/migration.rst for more info.
Enable DM_VIDEO can fix it on the stage of compilation.
=> ums 0 mmc 0
UMS: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x710000
Add initial infrastructure for Xen para-virtualized block device.
This includes compile-time configuration and the skeleton for
the future driver implementation.
Add new class UCLASS_PVBLOCK which is going to be a parent for
virtual block devices.
Add new interface type IF_TYPE_PVBLOCK.
Implement basic driver setup by reading XenStore configuration.
Signed-off-by: Andrii Anisov <andrii_anisov@epam.com>
Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
Add support for Xen para-virtualized serial driver. This
driver fully supports serial console for the virtual machine.
Please note that as the driver is initialized late, so no banner
nor memory size is visible.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Introduce a minimal Xen guest board running as a virtual
machine under Xen Project's hypervisor [1], [2].
Part of the code is ported from Xen mini-os and also uses
work initially done by different authors from NXP: please see
relevant files for their copyrights.
[1] https://xenbits.xen.org
[2] https://wiki.xenproject.org/
Switch DTB provider form OF_EMBED to OF_SEPARATE
to avoid the compile warning message:
CONFIG_OF_EMBED is enabled. This option should only
be used for debugging purposes. Please use
CONFIG_OF_SEPARATE for boards in mainline.
See doc/README.fdt-control for more info.
Signed-off-by: Chia-Wei, Wang <chiawei_wang@aspeedtech.com>
Move the BOOTCOMMAND definition from the board inclusion
header to the default configuration file.
https://gitlab.denx.de/u-boot/custodians/u-boot-stm
- Use IS_ENABLED to prevent ifdef in board_key_check for STM32MP
- Add STM32 FMC2 EBI controller driver
- Fix dwc3-sti-glue which allows STiH410-B2260 to boot again
- Add fitImage its entry for 587-200 DHCOR SoM
- Add both PDK2 and DRC02 DT into DHCOM fitImage its
- Fix DHCOM KS8851 ethernet MAC address
- Remove stm32mp1 board.c file
- Use const for struct node_info in board stm32mp1.c file
Include both PDK2 and DRC02 DTs in the DHCOM fitImage .its and implement
support in SPL to select the correct configuration entry for U-Boot by
using the machine compatible string from SPL DT.
Cc: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
This patch enables the support of FMC2 EBI.
Signed-off-by: Christophe Kerello <christophe.kerello@st.com>
Add initial A72 defconfig support.
Add initial R5 defconfig support
Because of space constraints, create a new USB defconfig for R5 to
faciliate booting from USB mass storage devices
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
faciliate booting in USB peripheral (DFU) bootmode
Enable configs to facilitate booting from USB Mass Storage devices
as well as USB peripheral boot
This commit completes the migrations for DM_ETH and DM_USB. The board
is now consistent with omap3_beagle and other remaining OMAP3 boards.
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
Add Python scripts to test 'ls' and 'load' commands. The scripts
generate a SquashFS image and clean the directory after the assertions,
or if an exception is raised.
Signed-off-by: Joao Marcos Costa <joaomarcos.costa@bootlin.com>
Add various fixes and improvements to this command that were missed in
the original version. Unfortunately I forgot to send v2.
- Fix Kconfig name
- Use a separate variable for the remaining search length
- Correct a minor bug
- Move into a separate test suite
- Add -q flag to the 'quiet' test to test operation when console is enabled
- Enable the feature for sandbox
Update the MikroTik CRS305-1G-4S flash layout to support redundant UBI
partitions.
Additionally enable the UBI commands in crs305-1g-4s_defconfig.
Signed-off-by: Luka Kovacic <luka.kovacic@sartura.hr>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Jakov Petrina <jakov.petrina@sartura.hr>
MikroTik CRS328-4C-20S-4S board has a switch chip with an integrated
Marvell Prestera 98DX3236 CPU.
This commit includes two board variants, namely the factory
default one and a Bit variant. The Bit board variant has a
bigger Macronix flash.
Add basic U-Boot, UART and SPI flash support.
MikroTik CRS326-24G-2S board has a switch chip with an integrated
MikroTik CRS305-1G-4S Bit board has a switch chip with an integrated
The Bit board variant is added, which has a bigger Macronix flash.
Add basic U-Boot, UART and Winbond SPI flash support.
- r2dplus updates
This commit moves CONFIG_PREBOOT="usb start" to common/KConfig
for all boards also declaring USB_KEYBOARD.
Besides simplifying defconfig files, this also enables support for
board-specific CONFIG_PREBOOT for sunxi boards:
commit 37304aaf60bf ("Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to
Kconfig") intended to support CONFIG_PREBOOT, but
include/configs/sunxi-common.h hardcodes preboot as part of internally
defined CONSOLE_STDIN_SETTINGS, silently ignoring any board-specific
CONFIG_PREBOOT.
Signed-off-by: Jonas Smedegaard <dr@jones.dk>
Reviewed-by: Neil Armstrong <narmstrong@baylibre.com>
Series-Cc: Jagan Teki <jagan@amarulasolutions.com>
Series-Cc: Lukasz Majewski <lukma@denx.de>
Series-Cc: Andre Przywara <andre.przywara@arm.com>
