These are generic and should be turned on on coreboot and qemu-x86.
This patch adds QSPI boot support for LS2080AQDS board.
The QSPI boot image need to be programmed into the QSPI flash
first. Then we can switch to booting from QSPI memory space.
Signed-off-by: Yuan Yao <yao.yuan@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
The Freescale QSPI driver has been converted to Driver Model.
This patch enables FSL_QSPI and its dependence options, DM, DM_SPI,
OF_CONTROL and so on.
The Mele_A1000G_quad has an onboard usb <-> sata conversion which needs
longer then the usb-spec allows to connect after getting power.
These are used for the usb wifi and if we leave the enabling up to the
kernel, we get hit by the axp209 issues with enabling ldo3 or 4 post boot
and the systems hangs as soon as it is enabled.
In the draco CPU board family, etamin is a new variant
with bigger flash and more RAM. Due to new flash that
uses larger pages (4K) some changes are necessary because
it impacts the MTD partition layout and the ubi mount
parameters.
Signed-off-by: Samuel Egli <samuel.egli@siemens.com>
[trini: Move BOOTDELAY into defconfig, just always be 3 now]
U-Boot SPL 2016.03-rc3-00019-g6dfb4c2-dirty (Mar 09 2016 - 07:40:06)
SHC C3-Sample
MPU reference clock runs at 6 MHz
Setting MPU clock to 594 MHz
Enabling Spread Spectrum of 18 permille for MPU
Trying to boot from MMC
reading u-boot.img
reading u-boot.img
U-Boot 2016.03-rc3-00019-g6dfb4c2-dirty (Mar 09 2016 - 07:05:35 +0100)
Watchdog enabled
I2C: ready
DRAM: 512 MiB
reloc off 1f783000
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Net: cpsw
U-Boot#
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Disable unused FPGA, NFS, FAT and EFI support to reduce the bootloader
size. Don't clear memory reserved for malloc to improve boot speed.
Signed-off-by: Andrew Shadura <andrew.shadura@collabora.co.uk>
The network support is only useful for development and shouldn't be enabled
in production, so it has to be disabled in U-boot by default.
The USB support is only useful for development and shouldn't be enabled
configs/peach-pi_defconfig
configs/peach-pit_defconfig
Some SPL loaders (like Allwinner's boot0, and Broadcom's boot0)
require a header before the actual U-Boot binary to both check its
validity and to find other data to load. Sometimes this header may
only be a few bytes of information, and sometimes this might simply
be space that needs to be reserved for a post-processing tool.
Introduce a config option to allow assembler preprocessor commands
to be inserted into the code at the appropriate location; typical
assembler preprocessor commands might be:
.space 1000
.word 0x12345678
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Steve Rae <srae@broadcom.com>
Commit Notes:
Please note that the current code:
start.S (arm64) and
vectors.S (arm)
already jumps over some portion of data already, so this option basically
just increases the size of this region (and the resulting binary).
For use with Allwinner's boot0 blob there is a tool called boot0img[1],
which fills the header to allow booting A64 based boards.
For the Pine64 we need a 1536 byte header (including the branch
instruction) at the moment, so we add this to the defconfig.
[1] https://github.com/apritzel/pine64/tree/master/tools
END
Use a single defconfig for all DRA7xx hs platforms by enabling FIT and delete
the platform specific defconfigs.
There is new strider cpu flavor with DisplayPort video.
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
There is a new strider console flavor with DisplayPort
video.
Modified:
configs/ls1012afrdm_qspi_defconfig
configs/ls1012aqds_qspi_defconfig
configs/ls1012ardb_qspi_defconfig
include/configs/ls1012afrdm.h
include/configs/ls1012aqds.h
include/configs/ls1012ardb.h
For boards which have more devices it is necessary to extend malloc
space.
Enable support for RAM based FIT images read by SPL.
Empty function for now to keep compiler happy.
zc1751-dc4 contains four GEMs.
Add debug uart for zc1751-dc2.
Select MSR instructions via Kconfig instead of xparameters.h.
Remove autogenerated config.mk and select CPU options via Kconfig.
Simplify board file by enabling CMD_NAND via Kconfig.
Create an entry for "config USB_XHCI_DWC3" in Kconfig and
switch over to it for all boards.
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it
into CONFIG_USB_XHCI_HCD.
As commented in the help of "config USB_XHCI" entry, this has been
a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI
have been unified in favor of the former.
Note:
Some boards define CONFIG_USB_XHCI in their headers without
CONFIG_USB, which does not meet the "depends on" in Kconfig.
I added CONFIG_USB=y for those boards when converting.
Otherwise, they would fail to build.
These Blackfin boards are the last ones that define CONFIG_USB in
their headers.
QorIQ LS1012A FREEDOM (LS1012AFRDM) is a high-performance
development platform, with a complete debugging environment.
The LS1012AFRDM board supports the QorIQ LS1012A processor and is
optimized to support the high-bandwidth DDR3L memory and
a full complement of high-speed SerDes ports.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com>
Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com>
Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
QorIQ LS1012A Reference Design System (LS1012ARDB) is a high-performance
The LS1012ARDB board supports the QorIQ LS1012A processor and is
QorIQ LS1012A Development System (LS1012AQDS) is a high-performance
The LS1012AQDS board supports the QorIQ LS1012A processor and is
Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com>
Enable support for tiny printf on the omap3_logic board to trim down
the SPL size. This makes the SPL actually build again and fit into
the SRAM.
Cc: lesne@alse-fr.com
This fixes the last remaining libgcc warning, where the symbol was
defined twice.
Enable both features to reduce the SPL size by 6 kiB.
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Stefan Roese <sr@denx.de>
Add support for board based on the popular Altera Cyclone V SoC.
This board has the following properties:
- 1 GiB of DRAM
- 1 Gigabit ethernet
- 1 USB gadget port
- 1 USB host port with an on-board hub
- 2 QSPI NORs connected to the Cadence QSPI core
- Multiple I2C EEPROMs and one I2C temperature sensor
V2: Update the defconfig as per Tom's request
P2771-0000 is a P3310 CPU board married to a P2597 I/O board. The
combination contains SoC, DRAM, eMMC, SD card slot, HDMI, USB micro-B
port, Ethernet, USB3 host port, SATA, PCIe, and two GPIO expansion
headers.
Currently, due to U-Boot's level of support for Tegra186, the only
features supported by U-Boot are the console UART and the on-board eMMC.
Additional features will be added over time.
U-Boot has so far been tested by replacing the kernel image on the device
with a U-Boot binary. It is anticipated that U-Boot will eventually
replace the CCPLEX bootloader binary, as on previous chips. This hasn't
yet been tested.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This patch enable network function for ap121 board.
Signed-off-by: Wills Wang <wills.wang@live.com>
Add defconfigs for recently introduced MIPS64 support on
Malta boards to get more build coverage for MIPS64.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
EFI is not needed on x600. So lets remove the EFI support to make it fit
into the 0x60000 image size limit again.
In the big move of CONFIG_HUSH_PARSER to config files the clearfog
somehow missed out.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Enable ACPI table generation by creating a DSDT table.
