path: root/configs
2016-09-06serial: bcm283x_mu: Detect disabled serial deviceAlexander Graf
On the raspberry pi, you can disable the serial port to gain dynamic frequency scaling which can get handy at times. However, in such a configuration the serial controller gets its rx queue filled up with zero bytes which then happily get transmitted on to whoever calls getc() today. This patch adds detection logic for that case by checking whether the RX pin is mapped to GPIO15 and disables the mini uart if it is not mapped properly. That way we can leave the driver enabled in the tree and can determine during runtime whether serial is usable or not, having a single binary that allows for uart and non-uart operation. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-03sunxi: Add defconfig and dts file for the Orange Pi Plus2E SBCHans de Goede
The Orange Pi Plus2E is an extended version of the Orange Pi Pc Plus, with 2G RAM and an external gbit ethernet phy. The dts file is identical to the one submitted to the upstream kernel, except that it has the pending patch to enable the ethernet controller squashed in, as u-boot already has sun8i-emac support. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-03sunxi: Enable emac on H3 orangepi boardsHans de Goede
The Orange Pi 2 and Orange Pi Plus also come with ethernet, enable support for this. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-03sunxi: Add support for A33-OLinuXino boardStefan Mavrodiev
A33-OLinuXino is A33 development board designed by Olimex LTD. It has AXP223 PMU, 1GB DRAM, a micro SD card, one USB-OTG connector, headphone and mic jacks, connector for LiPo battery and optional 4GB NAND Flash. It has two 40-pin headers. One for LCD panel, and one for additional modules. Also there is CSI/DSI connector. The dts files are identical to the ones submitted to the upstream kernel. Signed-off-by: Stefan Mavrodiev <stefan.mavrodiev@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-03sunxi: Add iNet D978 rev2 defconfigIcenowy Zheng
The iNet D978 rev2 is a tablet board designed by iNet, which is intended to use on 10" tablets with a appearance like Apple iPad. It has A33 SoC, 1GB RAM, 8GB/16GB NAND, SDIO Wi-Fi, a MicroUSB port and a MicroSD slot. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-01ARM: tegra: Add support for TK1-SOM board from Colorado EngineeringPeter Chubb
The Colorado TK1 SOM is a small form factor board similar to the Jetson TK1. The main differences lie in the pinmux, and in that the PCIe controller is set to use in 4lanes+1lane, rather than 2+2. The pinmux header here was generated from a spreadsheet provided by Colorado Engineering using the tegra-pinmux scripts. The spreadsheet was converted from v09 to v11 by me. Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-30ARM: tegra: use numeric versioning for p2771-0000Stephen Warren
The board ID EEPROM and board ID stickers on p2771-0000 will use a numeric versioning scheme, with version numbers such as 000/100/200/300/400/500. Within NVIDIA, these versions are also known as A00/A01/A02/A03/A04/B00. However, that numbering scheme is not easily visible outside of NVIDIA, and so does not make much sense to use. Convert U-Boot to use the readily visible numeric scheme. Also, it turns out that the current A02 DT actually applies to board versions 000/100/200 (A00..A02). Consequently rename this to 000 not 200 so that all U-Boot builds are named after the first version of the HW they support. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-30x86: qemu: efi: Add two boards for EFI 32-bit and 64-bit payloadBin Meng
This introduces two board defconfig files for generating EFI 32-bit and 64-bit payloads, to run on QEMU x86 target. With these in place, hopefully buildman will catch any build error with EFI payload support on x86. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-28Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2016-08-28ARM: uniphier: enable CONFIG_CMD_CACHEMasahiro Yamada
This will be useful, for example, to load firmware to DRAM and make it visible to other agents. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-28ARM: uniphier: change UNIPHIER_SERIAL to default y optionMasahiro Yamada
This is very likely to be necessary for normal use cases. Set its default to 'y' for shorter defconfig files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-28ARM: uniphier: increase CONFIG_SYS_MALLOC_F_LEN for sLD3Masahiro Yamada
Commit 76c52ce29fd7 ("ARM: uniphier: increase CONFIG_SYS_MALLOC_F_LEN to bind all nodes") missed to increase this config for sLD3. This change is needed to add "u-boot,dm-pre-reloc" to some nodes; more devices are bound, more malloc memory is needed. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-26sun5i: Add defconfig and dts file for the Empire Electronix M712 tabletHans de Goede
Add a defconfig and dts file for the Empire Electronix M712 tablet, this is a 7" A13 tablet, with micro-usb (otg), headphone and micro-sd slots on the outside. It uses a Goodix gt811 touchscreen controller, a RTL8188CTV wifi chip and a DMART06 (1238a4) accelerometer. The dts file is identical to the one submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-08-26sunxi: Sync dts files with upstream kernelHans de Goede
Sync dts files with the current (Aug 18th 2016) state of Maxime's linux/sunxi/for-next repo. Note this commit also updates configs/MSI_Primo81_defconfig, adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary because the tablet does not have a reachable uart so the dts sync drops its serial0 alias. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-08-26sun6i: Add defconfig and dts file for tablets using the inet-q972 PCBHans de Goede
Add a defconfig and dts file for tablets using the generic inet-q972 PCB. Tablets with this PCB feature a mini-hdmi output, micro-usb usb-host, micro-usb usb-otg, 3.5mm headphone jack, a micro sd slot, (mini) power-barrel and an usb wifi module. This has been tested on a 9.7" 1024x768 qware qw tb9718-qhd tablet. The dts files are identical to the ones submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-08-20Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
[trini: Drop CMD_BOOTI as it's now on by default on ARM64] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-20fastboot: move to KconfigSteve Rae
- move bcm23550_w1d to Kconfig - move bcm28155_ap to Kconfig Signed-off-by: Steve Rae <steve.rae@raedomain.com>
2016-08-17ARM: rmobile: salvator-x: Update defconfigNobuhiro Iwamatsu
This moves some config from config files. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17arm: rmobile: Update defconfigNobuhiro Iwamatsu
This updated defconfig following boards: - Alt - Gose - Koelsh - Lager - Porter - Silk - Stout - Blanche Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17arm: rmobile: Add BLANCHE board supportmasakazu.mochizuki.wd@hitachi.com
BLANCHE is development board based on R-Car V2H SoC (R8A7792) This commit supports the following periherals: - SCIF, Ethernet, QSPI, MMC Signed-off-by: Masakazu Mochizuki <masakazu.mochizuki.wd@hitachi.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Add support salvator-x boardNobuhiro Iwamatsu
Salvator-x is an entry level development board based on R-Car H3 SoC (R8A7795). This commit supports SCIF only. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2016-08-16Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2016-08-16x86: Add theadorable-x86-dfi-bt700 board supportStefan Roese
This patch adds support for the BayTrail based theadorable-x86-dfi-bt700 board which uses the DFI BT700 BayTrail Qseven SoM on a custom baseboard. The main difference to the DFI baseboard is, that it isn't equipped with a Super IO chip and uses the internal HS SIO UART (memory mapped PCI based) as the console UART. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: Add DFI BT700 BayTrail board supportStefan Roese
This patch adds support for the DFI BayTrail BT700 QSeven SoM installed on the DFI Q7X-151 baseboard. The baseboard is equipped with the Nuvoton NCT6102D Super IO chip providing the UART as console. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: conga-qeval20-qa3: Add SMBus support and SMSC2513 config codeStefan Roese
This patch includes the following changes: - Remove Designware I2C support from dts as its not used - Configure SMBus PADs in dts - Enable I2C commands and I2C support - Configure SMSC2513 USB hub via SMBus upon startup - Move environment location to match Minnowmax example - Enhancement of the default environment Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16defconfig: k2g_evm_defconfig: Enable mmc driver modelSekhar Nori
K2G can benefit from driver model support in the MMC/SD driver it uses: omap_hsmmc Enable driver model MMC support for K2G. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-15xtensa: add support for the 'xtfpga' evaluation boardChris Zankel
The 'xtfpga' board is actually a set of FPGA evaluation boards that can be configured to run an Xtensa processor. - Avnet Xilinx LX60 - Avnet Xilinx LX110 - Avnet Xilinx LX200 - Xilinx ML605 - Xilinx KC705 These boards share the same components (open-ethernet, ns16550 serial, lcd display, flash, etc.). Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-15Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2016-08-15net/ethoc: add Kconfig entry for the driverMax Filippov
Add Kconfig entry for the driver, remove #define CONFIG_ETHOC from the only board configuration that uses it and put it into that board's defconfig. Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-15ARM: tegra: enable PCIe controller on p2771-0000Stephen Warren
p2771-0000 has a couple of PCIe ports; one physically x4 desktop PCI connector (which may run at x2 electrically, depending on the board version and configuration) and a x1 connection to the M.2 slot (which may not be active, depending on the board version and configuration). This change enables those. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15ARM: tegra: enable SD card on p2771-0000Stephen Warren
Now that clock and reset drivers exist for Tegra186, we can enable the SD card controller. Now that a BPMP I2C driver exists for Tegra186, we can communicate with the PMIC to enable power to the SD card. Hook up the DT content and board code required to make the SD card work. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-12defconfig: am43xx_evm: enable eth driver modelMugunthan V N
Enable eth driver model for am43xx_evm as cpsw supports driver model. This was already added with the commit bc705ea1cf12 but with commit 4c4e3b37750f to add fit support CONFIG_DM_ETH was missed. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-12configs: dra7xx_evm: enable eth driver modelMugunthan V N
Enable eth driver model for dra7xx_evm as cpsw supports driver model. This was already added with the commit 641b936fa5ba but with commit bd7245849f7c to add fit support CONFIG_DM_ETH was missed. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-08-12ARM: dra7xx_evm: Enable regulator DM supportVignesh R
Enable DM based regulator framework and also fixed regulator support as some IPs like mmc use regulators for there functioning. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-11Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2016-08-08configs: k2l_evm: add random eth address supportMugunthan V N
There is only one ethernet mac address in e-fuse, but there are multiple slaves in keystone net, so enable random mac address support. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-08configs: k2e_evm: add random eth address supportMugunthan V N
2016-08-08configs: k2hk_evm: add random eth address supportMugunthan V N
2016-08-08ARM: dra7xx_evm: Enable support for TI PCF8575Vignesh R
On DRA7, pcf chip present at address 0x21 on i2c1, is used to switch between cpsw slave0 and slave1. Hence, enable PCF driver for the same. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-07arm: ls1021a: Enable CONFIG_DM_USB in defconfigsRajesh Bhagat
Enables driver model flag CONFIG_DM_USB for LS1021A platform defconfigs. Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2016-08-07usb: add CONFIG_USB_OHCI_HCD in KconfigMasahiro Yamada
Add this option as a common config for all OHCI controllers. Its help message was copied from Linux. Also, I moved it below EHCI to respect the order in Linux's Kconfig. Add CONFIG_USB_OHCI_HCD=y to axs103_defconfig, which is the only user of OHCI_GENERIC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-07ARM: socfpga: use the default CONFIG_BOOTDELAY=2Masahiro Yamada
This option controls how long it should be paused before entering the auto-boot mode. The default value from Kconfig should be fine except socfpga_vining_fpga_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-06Merge git://git.denx.de/u-boot-rockchipTom Rini
2016-08-05omap3: Drop omap3_evm_quick_* targetsTom Rini
These config targets were added well before the Kconfig migration began as a way to demonstrate how to make these platforms work with cut down features. At this point in time they no longer serve a good purpose so remove them. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-05config: rk3399: enable dwmmc controllerKever Yang
Enable the rockchip dwmmc driver for rk3399 and its evb. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-05rockchip: add support for rk3288 miniarm boardXu Ziyuan
Miniarm is a rockchip rk3288 based development board, which has lots of interface such as HDMI, USB, micro-SD card, Audio etc. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-05treewide: move CONFIG_PHYS_64BIT to KconfigMasahiro Yamada
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so that it is always available to the build system. Otherwise we can run into cases where we have inconsistent sizes of certain attributes. Ravi Babu reported offset mismatch of struct dwc3 across files since commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t"). Since the commit, resource_addr_t points to phys_addr_t, whose size is dependent on CONFIG_PHYS_64BIT for ARM architecture. I tried my best to use "select" where possible (for example, ARMv8 architecture) because I think this kind of option is generally user- unconfigurable. However, I see some of PowerPC boards have 36BIT defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the defconfigs for such boards. CONFIG_36BIT is no longer referenced, so all of the defines were removed from CONFIG_SYS_EXTRA_OPTIONS. Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Ravi Babu <ravibabu@ti.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-08-05arc: Rename AXS101 board to more generic AXS10xAlexey Brodkin
As of now we have 2 flavors of ARC SDP boards: 1) AXS101 - with ARC770 in ASIC 2) AXS103 - with ARC HS38 in FPGA Both options share exactly the same base-board and only differ with CPU-tiles in use. That means all peripherals are the same (they are implemented in FPGA on the base-board) and so generic board could be used for both. While at it: * Recreated defconfigs with savedefconfig * In include/configs/axs10x.h numerical sizes replaced with defines from linux/sizes.h for better readability. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-05arc: Rename ARCangel4 board to nSIMAlexey Brodkin
ARCangel was one of the main development boards back in the day but now it's gone and replaced by other boards like ARC SDP. But we also used to have simulation platform very similar to ARCangel4 in terms of CPU settings as well as basic IO like UART. Even though ARCangel4 is long gone now we have a replacement for simulation which is a plain or stand-alone nSIM and Free nSIM. Note Free nSIM is available for download here: https://www.synopsys.com/cgi-bin/dwarcnsim/req1.cgi And while at it: * Finally switch hex numerical values in nsim.h to defines from include/linux/sizes.h * Add defconfigs with ARC HS38 cores * Recreated all defconfigs with savedefconfig Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
