Use CONFIG_ARCH_T2080 and CONFIG_ARCH_T2081 instead.
Signed-off-by: York Sun <york.sun@nxp.com>
T208XRDB only has one target T2080RDB. Use TARGET_T2080RDB in Kconfig
and clean up existing macros.
Use two separated targets in Kconfig to simplify configurations.
CONFIG_T104xRDB is defined in T104xRDB.h, so it is always enabled for
all T1040RDB, T1040D4RDB, T1042RDB, T1042D4RDB, T1042RDB_PI.
CONFIG_T104XD4RDB is defined for all T1040D4RDB, T1042D4RDB.
Use TARGET_T1042RDB instead.
Use TARGET_T1042D4RDB in Kconfig to simplify config options.
Remove macro CONFIG_T1042D4RDB.
Use separated TARGET_T1042RDB_PI to simplify config options.
Remove macro CONFIG_T1042RDB_PI.
Replace CONFIG_PPC_T1042 with ARCH_T1024 in Kconfig and clean up
existing macros.
Use CONFIG_TARGET_T1040RDB instead.
Use TARGET_T1040D4RDB in Kconfig to simplify config macros. Replace
CONFIG_T1040D4RDB with TARGET_T1040D4RDB and clean up existing macros.
Replace CONFIG_PPC_T1040 with ARCH_T1040 in Kconfig and clean up
existing macros.
Split ARCH_T104XRDB as ARCH_T1040RDB and ARCH_T1042RDB in Kconfig to
Replace CONFIG_PPC_T1024 with ARCH_T1024 in Kconfig and clean up
existing macros.
Rename TARGET_T102XQDS to TARGET_T1024QDS to match the name.
Replace CONFIG_PPC_T1023 with ARCH_T1023 in Kconfig and clean up
existing macros.
The defconfig files are separated. Splitting targets in Kconfig simplifies
config options.
Replace CONFIG_PPC_B4420 with ARCH_B4420 in Kconfig and clean up
existing macros.
Replace CONFIG_PPC_B4860 with ARCH_B4860 in Kconfig and clean up
existing macros.
Use TARGET_B4420QDS to simplify Kconfig options.
Replace CONFIG_P5040 with ARCH_P5040 in Kconfig and clean up
existing macros.
Replace CONFIG_PPC_P5020 with ARCH_P5020 in Kconfig and clean up
existing macros.
Use TARGET_P2020RDB_PC instead of sharing with P1_P2_RDB_PC to
simplify Kconfig and config macros.
Remove macro CONFIG_P2020RDB.
Use TARGET_P1025RDB instead of sharing with P1_P2_RDB_PC to
Remove macro CONFIG_P1025RDB.
Use TARGET_P1024RDB instead of sharing with TARGET_P1_P2_RDB_PC to
simplify Kconfig and macros.
Remove macro CONFIG_P1024RDB.
Use TARGET_P1021RDB instead of sharing with TARGET_P1_P2_RDB_PC to
Remove macro CONFIG_P1021RDB.
Use TARGET_P1020UTM instead of sharing with TARGET_P1_P2_RDB_PC
to simplify Kconfig and config macros.
Remove macro CONFIG_P1020UTM.
Use TARGET_P1020RDB_PD instead of sharing with P1_P2_RDB_PC
Remove macro CONFIG_P1020RDB_PD.
Use TARGET_P1020RDB_PC instead of sharing with TARGET_P1_P2_RDB_PC
Remove macro CONFIG_P1020RDB_PC.
Use TARGET_P1020MBG instead of sharing with TARGET_P1_P2_RDB_PC to
simplify Kconfig and other macros.
Remove macro CONFIG_P1020MBG.
Remove CONFIG_P1010RDB_PA and CONFIG_P1010RDB_PB and split TARGET_P1010RDB
to TARGET_P1010RDB_PA and TARGET_P1010RDB_PB in Kconfig.
Use CONFIG_TARGET_C29XPCIE instead.
Use CONFIG_TARGET_BSC9132QDS from Kconfig option, remove CONFIG_BSC9132QDS
macro.
This macro CONFIG_BSC9131RDB is no longer needed.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Fix sniper and kc1 migration]
Patch queue for efi - 2016-11-17
Highlights this time around:
- x86 efi_loader support
- hello world efi test case
- network device name is now representative
- terminal output reports modes correctly
- fix psci reset for ls1043/ls1046
- fix efi_add_runtime_mmio definition for x86
- efi_loader support for ls2080
The SinA33 comes with an optional 7" display. Enable it in the
configuration.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
The SinA33 has an 4GB Toshiba eMMC connected to the MMC2 controller.
Enable it.
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
Enable zynq Nand flash controller driver for a zynq ZC770
XM011(dc2) board.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
The topic-miami SoMs contain a Zynq xc7z015 or xc7z030 SoC, 1GB DDR3L RAM,
32MB QSPI NOR flash and 256MB NAND flash.
The topic-miamiplus SoMs contain a Zynq xc7z035, xc7z045 or xc7z100 SoC,
2x 1GB DDR3L RAM, 64MB dual-parallel QSPI flash, clock sources
and a fan controller.
The "Florida" carrier boards add SD, USB, ethernet and other interfaces.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
Enable this so that EFI applications (notably grub) can be run under U-Boot
on x86 platforms.
At present the 'hello world' EFI application is not supported for the
qemu-x86_efi_payload64 board. That board builds a payload consisting of a
64-bit header and a 32-bit U-Boot, which is incompatible with the way the
EFI loader builds its EFI application. The following error is obtained:
x86_64-linux-ld.bfd: i386 architecture of input file
`lib/efi_loader/helloworld.o' is incompatible with i386:x86-64 output
This could be corrected with additional Makefile rules. For now, this
feature is disabled for that board.
[agraf: drop hello kconfig bits]
Defconfigs should remain the same except CONFIG_SYS_EXTRA_OPTIONS.
Drop NAND specific defconfig as flash type is runtime detected.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Reviewed-by: Javier Martinez Canillas <javier@samsung.com>
As a single U-Boot binary can now run on various board modifications,
drop CONFIG_DISPLAY_BOARDINFO as it prints flash memory information
too early to give us chance to easily detect it. Also saves few bytes
as a bonus.
Tested-by: Javier Martinez Canillas <javier@samsung.com>
Enable the Ethernet device in DT, provide board-specific configuration,
and enable the driver in Kconfig.
Enable ROCKCHIP_SPL_BACK_TO_BROM and disable CONFIG_SPL_MMC_SUPPORT
to save memory in order to enable add source code for dram capacity
auto-detect.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
The Cubieboard4 is an A80 SoC based development board from Cubietech.
This board has a UART port, 4 USB host ports, a USB 3.0 OTG connector,
HDMI and VGA outputs, a micro SD slot, 8G eMMC flash, 2G DRAM, a WiFi/BT
combo chip, headphone and microphone jacks, IR receiver, and GPIO headers.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Hans de Goede <hdegoede@redhat.com>
The A80 Optimus Board was launched with the Allwinner A80 SoC.
It was jointly developed by Allwinner and Merrii.
This board has a UART port, a JTAG connector, 2 USB host ports, a USB
3.0 OTG connector, an HDMI output, a micro SD slot, 16G eMMC flash,
2G DRAM, a camera sensor interface, a WiFi/BT combo chip, a headphone
jack, IR receiver, and additional GPIO headers.
[hdegoede@redhat.com: update existing Merrii_A80_Optimus_defconfig
instead of adding a new defconfig]
Mostly by adding MACH_SUN50I to some existing #ifdefs enable support
for the the HCI0 USB host controller on the A64.
Fix up some minor 64-bit hiccups on the way.
Add the bare minimum DT bits to the A64 .dtsi and enable the controllers
and the PHY on the Pine64.
This is limited to the first USB controller at the moment, which is
connected to the lower USB socket on the Pine64 board.
[Andre: remove unneeded defines, enable OHCI, add commit message]
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Originally dram clock was set to 480MHz, but this behaves
unstable. To improve stability the clock is reduced to 384MHz
Signed-off-by: Stefan Mavrodiev <stefan.mavrodiev@gmail.com>
This was turned off by accident, re-enble.
