This commit enables support for DFU_TFTP on the am335x bone black device.
Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
This fixes building in automated flow that doesn't use defconfigs.
See discussion on that topic here:
http://patchwork.ozlabs.org/patch/502558/
See similar patches for other architectures/platforms here:
[1] http://git.denx.de/?p=u-boot.git;a=commit;h=ff560a13056a565a4e9ce1761bd04276a3cace88
[2] http://git.denx.de/?p=u-boot.git;a=commit;h=589907e2c187ec69b351c38ccda36730d25ab5d6
And while at it add missing shell prompt to axs103.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Add support for the Terasic DE0-Nano/Atlas-SoC Kit, which is a CycloneV
based board. The board can boot from SD/MMC. Ethernet is also supported.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Add support for DENX MCV SoM, which is CycloneV based and the
associated DENX MCVEVK baseboard. The board can boot from eMMC.
Ethernet and USB is supported.
Add support for Terasic SoCkit, which is CycloneV based board.
The board can boot either from SD/MMC or QSPI. Ethernet is also
supported.
With LED support enabled the SPL easily goes over the size limit (e.g.
with both Debians gcc 4.9 and 5.2 cross-compilers). Turn off LED support
in the SPL to reduce the size just enough for those compilers.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Tweaked commit subject to remove _SUPPORT
This builds and displays an SPL message, but does not function beyond that.
The Firefly RK3288 is a suitable target board for initial mainline Rockchip
support. It includes a good set of peripherals, a recent SoC and it is
readily available.
This adds only some basic files required to allow the baord to display a
serial message in SPL and hang.
In 2178282 this config wasn't updated by accident, so update it.
These have not been converted to Generic Board, so should be removed.
(See doc/README.generic-board for details.)
Cc: Dan Malek <dan@embeddedalley.com>
This has not been converted to Generic Board, so should be removed.
Cc: Stefan Roese <sr@denx.de>
Remove CONFIG_LWMON5 references.
(Also, remove undefined CONFIG_WD_MAX_RATE while I am here.)
Cc: Tolunay Orkun <torkun@nextio.com>
CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE works better than
CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP (keyboards that previously didn't
work such as Microsoft Comfort Curve 1000 now do work, and it's also faster).
Switch to CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE.
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
there is a 2b board version of the aristainetos2
board. Differences to the v2:
- spi cs for the nor flash and display controller
changed
- some pinmux changes
- LED gpio settings changed
Discard MX6UL from CONFIG_SYS_EXTRA_OPTIONS, since we default
select MX6UL for mx6ul_14x14_evk board.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Add SPL boot support for mx6slevk board.
1. Introduce a configuration file mx6slevk_spl_defconfig.
2. i.MX6SL has same DRAM space with i.MX6SX, need to change SPL DRAM SPACE.
3. Include imx6_spl.h and related SPL macro in mx6slevk.h.
4. select SUPPORT_SPL for TARGET_MX6SLEVK.
5. Add SPL board code to do related initialization.
Boot Log:
U-Boot SPL 2015.07-00544-g1594a76 (Aug 17 2015 - 01:56:59)
reading u-boot.img
reading u-boot.img
U-Boot 2015.07-00544-g1594a76 (Aug 17 2015 - 01:56:59 +0000)
CPU: Freescale i.MX6SL rev1.2 996 MHz (running at 396 MHz)
CPU: Commercial temperature grade (0C to 95C) at 50C
Reset cause: POR
Board: MX6SLEVK
I2C: ready
DRAM: 1 GiB
PMIC: PFUZE100 ID=0x10
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
move options from CONFIG_SYS_EXTRA_OPTIONS to board specific Kconfig
Signed-off-by: Soeren Moch <smoch@web.de>
Add enet support for mx6ul_14x14_evk board:
1. add pinmux settings
2. implement board_eth_init
3. implement board_phy_config
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig.
Add enable "CONFIG_ARCH_MX6" for boards based on mx6.
Then we can choose target boards using "make ARCH=arm menuconfig"
with ARCH_MX6 defined.
If using original way, we have no chance to enable ARCH_MX6 when
"make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig,
kconfig will complains "arch/../configs/platinum_titanium_defconfig:3:
warning: override: TARGET_PLATINUM_TITANIUM changes choice state"
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Eric BĂ©nard <eric@eukrea.com>
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Soeren Moch <smoch@web.de>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Soeren Moch <smoch@web.de>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
This commit adds basic support including:
MMC, Serial console, TS4800 watchdog
The config use CONFIG_SKIP_LOWLEVEL_INIT as U-boot is used as a second
stage bootloader.
Signed-off-by: Lucile Quirion <lucile.quirion@savoirfairelinux.com>
signed-off-by: Damien Riegel <damien.riegel@savoirfairelinux.com>
This patch removes the SPI support from the WRU-IV baseboard as its
not used at all.
Cc: Clemens Gruber <clemens.gruber@pqgruber.com>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Tested-by: Clemens Gruber <clemens.gruber@pqgruber.com>
Reviewed-by: Jagan Teki <jteki@openedev.com>
Currently we need to build one U-boot image for each of the udoo
variants: quad and dual-lite.
By switching to SPL we can support all two variants with a single binary.
Based on the SPL for wandboard.
Tested with OpenELEC (Open Embedded Linux Entertainment Center)
on both boards.
Signed-off-by: Peter Vicman <peter.vicman@gmail.com>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
The emulator with DDR3 model was used during model bringup. DDR4
controllers are used with ls2085a. Drop the DDR4 target defconfig
and enable DDR4 in ls2085a_emu_defconfig.
Signed-off-by: York Sun <yorksun@freescale.com>
Previously the DDR4 targets were named with _D4. Rename them with
_DDR4 for easy identification.
T1024QDS with DDR4 has been supported. Add the missing defconfig.
CC: Shengzhou Liu <Shengzhou.Liu@freescale.com>
This driver actually does nothing but test pinctrl uclass, and
demonstrate how things work.
To try this driver, uncomment /* #define DEBUG */ in the
drivers/pinctrl/pinctrl-sandbox.c, and debug messages will be
displayed.
DRAM: 128 MiB
sandbox pinmux: group = 1 (serial_a), function = 1 (serial)
Using default environment
In: cros-ec-keyb
Out: lcd
Err: lcd
Net: Net Initialization Skipped
eth0: eth@10002000, eth1: eth@80000000, eth5: eth@90000000
=> i2c dev 0
Setting bus to 0
sandbox pinmux: group = 0 (i2c), function = 0 (i2c)
sandbox pinconf: group = 0 (i2c), param = 3, arg = 1
The TPM is listed in the device tree. Enable the driver and 'tpm' command
so that it can be used.
Acked-by: Christophe Ricard <christophe-h.ricard@st.com>
This command provides a few useful tests so enable it for common boards.
Acked-by: Christophe Ricard<christophe-h.ricard@st.com>
Convert the tpm_tis_lpc driver to use driver model and update boards which
use it.
Convert the tpm_tis_i2c driver to use driver model and update boards which
use it.
Convert the sandbox TPM driver to use driver model. Add it to the device
tree so that it can be found on start-up.
Convert all TPM options to Kconfig and tidy up.
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
The inet98v_rev2 is a pcb used in generic A13 based tablets. It features
volume buttons, a power barrel, micro-usb otg, headphone connector and
a power button.
The dts file is identical to the one submitted to the upstream kernel.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
The inet97fv2 is a board found in the first generation of cheap allwinner
A10 based 7" tablets.
Note that this patch does not add a dts file as we already have one from
our dts syncs with the kernel.
Add otg id pin configuration, this speeds up bootup when no host cable
is plugged into the otg port.
Add CONFIG_MMC0_CD_PIN to various boards, this stops the SPL from still
trying to access the sdcard when there is none (e.g. when booting from
nand).
With the unified / cleaned up default display output selection changes,
which were done as part of adding composite video out support, our
example LCD_MODE line in the A13-OLinuxIno defconfigs causes the display
code to setup a LCD console by default, rather then a VGA console.
Given that the LCD console is only useful for people who have hooked up
the exact lcd-panel from the config, while most people will not have any
lcd panel connected to these boards, this is not a good default.
Dropping the LCD_MODE line which was intended as an example fixes this,
instead add a link to the LCD_MODE help text pointing to
http://linux-sunxi.org/LCD which contains the removed and other example
modes.
