In order to migrate this symbol to Kconfig introduce a new symbol to
guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then
provide the exact final location o the script.
While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances
where these configuration items are conditional on SPL. This commit adds SPL
variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates
the configurations as required.
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Trevor Woerner <trevor@toganlabs.com>
[trini: Make the default depend on the setting for full U-Boot, update
more zynq hardware]
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
All platforms are converted to DM_I2C that's why there is no reason to
keep this code here.
This patch is doing two things.
1. Exchanging order of boot commands. distro_bootcmd is run first
followed by Xilinx boot command.
2. Remove CONFIG_BOOTCOMMAND from configs (and follow mainline) by
creating Xilinx distribution bootcommand and wiring it as the last
bootcommand.
QSPI, NAND distribution boot command will be added later.
Now that new SPI NOR layer uses stateless 4 byte opcodes by default,
don't enable SPI_FLASH_BAR. For SPI controllers that cannot support
4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c,
renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to
not break functionality.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Tested-by: Stefan Roese <sr@denx.de>
Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
There is no i2c connected in base DT that's why disable I2C commands.
Also remove zynq_zybo which is not needed now.
Only add CONFIG_DISPLAY to defconfig because CONFIG_I2C_EDID
is automatically selected by CONFIG_DISPLAY
Signed-off-by: Luis Araneda <luaraneda@gmail.com>
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_DEBUG_UART_BASE and CONFIG_DEBUG_UART_CLOCK have changed that's
why this sync.
Now that showing silicon version is part of the CPU
info display, let's remove checkboard().
Note that the generic show_board_info() will still
show the DT 'model' property. For instance:
U-Boot 2018.05-rc2-00025-g611b3ee0159b (Apr 19 2018 - 11:23:12 +0200)
CPU: Zynq 7z045
Silicon: v1.0
Model: Zynq ZC706 Development Board
I2C: ready
Based on patches from Ariel D'Alessandro <ariel@vanguardiasur.com.ar>,
and Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
mini configuration doesn't need to show this information.
This converts IMAGE_FORMAT_LEGACY to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all
configurations using it to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Make defconfigs up2date with current location.
This patch added Kconfig support for CONFIG_ZYNQ_I2C0 and
CONFIG_ZYNQ_I2C1 and enabled it in respective defconfig.
Signed-off-by: Vipul Kumar <vipulk@xilinx.com>
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
This patch added Kconfig support for CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET
This patch enabled CONFIG_SYS_I2C_ZYNQ in the respective
defconfig.
This patch added Kconfig support for CONFIG_FPGA_ZYNQPL and migrates the
values over to the defconfigs.
This commit moves USB_FUNCTION_THOR config to Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
This patch moved ethernet PHY configs of Zynq boards
to respective defconfig.
BOOTCOMMAND is composed with distro_bootcmd but this variable is not
present. Enabling distro defaults setting is fixing it.
It will cleanup generic config and enable option to change it for every
board.
There are two reasons for doing this change.
There is still !DM driver for xilinx soft gpio IP and especially it is
saving some space for memory constrained boards like cse (almost ~400B).
This patch is fixing two issues:
1. Insufficient stack size for fat fs buffers
2. Insufficient space in malloc area
Tested on zc702 and zc706.
Move cadence/zynq serial driver via Kconfig
Enabling fpga via Kconfig.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
CONFIG_CMD_THOR_DOWNLOAD
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_ENV_IS_IN_SPI_FLASH
CONFIG_CMD_FPGA_LOADBP
CONFIG_CMD_FPGA_LOADFS
CONFIG_CMD_FPGA_LOADMK
CONFIG_CMD_FPGA_LOADP
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
Xilinx fixes for v2017.03
- defconfig alignment
- Topic.nl board updates
- Minor microblaze comment fix
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
Keep all defconfig sorted to ensure the smallest diff.
Make the naming scheme consistent; all SDHCI-base drivers prefixed
with CONFIG_MMC_SDHCI_.
While we are here, add "depends on ARCH_ZYNQ || ARCH_ZYNQMP".
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Enable CONFIG_SYS_TEXT_BASE via Kconfig.
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI.
My motivation for the rename is, ultimately, to make all the MMC
options prefixed with MMC_ and SDHCI options with MMC_SDHCI_,
like Linux.
[1] Rename the config option with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g'
[2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig
[3] run "tools/moveconfig.py -y MMC_SDHCI"
[4] add "depends on MMC_SDHCI" to existing SDHCI driver entries
Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
in certain architectures. Migrate all config files.
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Move the SPL settings into common/spl where most of the SPL code is kept.
