path: root/configs/zynq_zybo_defconfig
2016-05-24ARM: zynq: Simplify zynq configurationMichal Simek
Extending Kconfig for adding new platform is a lot of work for nothing. Setting SYS_CONFIG_NAME directly in Kconfig and remove all dependencies on TARGET_ZYNQ_* options including SPL. As a side-effect it also remove custom init folder for ps7_init_gpl.* files. Folder is chosen based on device-tree file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-04ARM: zynq: Enable FLASH_BAR for microzed and zyboMichal Simek
Enable FLASH_BAR for these targets to be in sync with all zynq boards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-01Migrate CONFIG_ULPI* to KconfigMateusz Kulikowski
Move CONFIG_USB_ULPI* from headers to defconfigs for boards that use it. Also - add CONFIG_USB where necesarry - all boards use it, but some are not defining it explicitly. Affected boards: colibri_t20, harmony, mcx, mt_ventoux, twister, zynq_(picozed, zc702, zc706, zed, zybo) Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-22mmc: Kconfig: Add Arasan SDHCI entryMichal Simek
Add Arasan SDHCI entry to Kconfig and fix all references. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Fix defconfig for zyboMichal Simek
Change possition of SPI_FLASH to by align with savedefconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Define sys prompt for all Zynq boardsSiva Durga Prasad Paladugu
Define CONFIG_SYS_PROMPT for all Zynq boards It was removed by: "kconfig: add config option for shell prompt" (sha1: 181bd9dc61d2da88b78f1c1138a685dae39354d6) Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-13arm: zynq: Enable SPL_DM_SEQ_ALIAS for all Zynq configsNathan Rossi
This feature is required in SPL to enable support for loading from SPI flash when the device is booted from QSPI. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18net: gem: Add driver dependencies to PHYLIBMichal Simek
Clear driver dependecies via Kconfig. Remove PHYLIB dependency from the driver. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18arm: zynq: Update ZYBO config optionsNathan Rossi
Update the ZYBO device tree and enable config options that relate to the added devices in the device tree. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Michal Simek <monstr@monstr.eu> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-07net: gem: Move gem to KconfigMichal Simek
Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-12-07ARM: zynq: Remove PHYLIB from config to defconfigMichal Simek
Move PHYLIB from board config to defconfig Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-11-04arm: zynq: Support the debug UARTSimon Glass
Add support for the debug UART to assist with early debugging. Enable it for Zybo as an example. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-11-04arm: zynq: Use separate device tree instead of embeddedSimon Glass
Production boards should not use CONFIG_OF_EMBED. Fix this for the Zybo boards. The image to use now becomes u-boot-dtb.bin. For example, the .bif file should contain a line like: [load = 0x04000000,startup=0x04000000]/path/to/u-boot-dtb.bin instead of: [load = 0x04000000,startup=0x04000000]/path/to/u-boot.bin When device tree is enabled we need to load u-boot-dtb.img. Change the settings so that SPL does the right thing. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-10-24Revert "ARM: zynq: disable CONFIG_SYS_MALLOC_F to fix MMC boot"Simon Glass
This reverts commit 321f86e18d6aae9f7b7ba3ef1eb0cec769481874. The original bug has been fixed. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-on: Zedboard and ZC706 board Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-on: zc702 Tested-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19zynq: enable CONFIG_NET_RANDOM_ETHADDRMasahiro Yamada
We have to set a MAC address to use network. Otherwise, the tftpboot command fails with the following message: Gem.e000b000 Waiting for PHY auto negotiation to complete........ done *** ERROR: `ethaddr' not set Since commit 92ac52082140 ("net: Remove all references to CONFIG_ETHADDR and friends"), we can not use CONFIG_ETHADDR. The easiest way to set a MAC address is to enable CONFIG_NET_RANDOM_ETHADDR. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19zynq: Make CONFIG_OF_EMBED default caseMichal Simek
Use embedded DTB to let users use u-boot instead of u-boot-dtb.bin. And fix SPL to use this target. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-07-01zynq: defconfig: Move CONFIG_OF_* to KconfigJagan Teki
This commit moves: - CONFIG_OF_CONTROL - SPL_DISABLE_OF_CONTROL from zynq_*_defconfig files into arch/arm/Kconfig "config ARCH_ZYNQ" Signed-off-by: Jagan Teki <jteki@openedev.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-10dts: Disable device tree for SPL on all boardsSimon Glass
We plan to enable device tree in SPL by default. Before doing this, explicitly disable it for all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-29ARM: zynq: rename CONFIG_ZYNQ to CONFIG_ARCH_ZYNQMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-18ARM: zynq: use "select" instead of default value in defconfigMasahiro Yamada
All the Zynq boards have switch to Driver Model. "select DM" is better than default value in each defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-08ARM: zynq: disable CONFIG_SYS_MALLOC_F to fix MMC bootMasahiro Yamada
Since commit 326a682358c1 (malloc_f: enable SYS_MALLOC_F by default if DM is on), Zynq MMC boot hangs up after printing the following: U-Boot SPL 2015.04-rc5-00053-gadcc570 (Apr 08 2015 - 12:59:11) mmc boot reading system.dtb Prior to commit 326a682358c1, Zynq boards enabled CONFIG_DM, but not CONFIG_SYS_MALLOC_F. That commit forcibly turned on CONFIG_SYS_MALLOC_F. I have not figured out the root cause, but anyway it looks like CONFIG_SYS_MALLOC_F gave a bad impact on the Zynq MMC boot. We are planning to have the v2015.04 release in a few days. I know this is a defensive fixup, but what I can do now is to add # CONFIG_SYS_MALLOC_F is not set to every Zynq defconfig file to get back the original behavior. Tested on: - Zedboard - ZC706 board Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org>
2015-01-29lib/rsa: Modify rsa to use DM driverRuchika Gupta
Modify rsa_verify to use the rsa driver of DM library .The tools will continue to use the same RSA sw library. CONFIG_RSA is now dependent on CONFIG_DM. All configurations which enable FIT based signatures have been modified to enable CONFIG_DM by default. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29configs: Move CONFIG_FIT_SIGNATURE to defconfigRuchika Gupta
For the platforms which use,CONFIG_FIT_SIGNATURE, the required configs are moved to the platform's defconfig file. Selecting CONFIG_FIT_SIGNATURE using defconfig automatically resolves the dependencies for signature verification. The RSA library gets automatically selected and user does not have to define CONFIG_RSA manually. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-13zynq: zybo: Move CONFIG_DEFAULT_DEVICE_TREE to defconfigMichal Simek
This is a MIME GnuPG-signed message. If you see this text, it means that your E-mail or Usenet software does not support MIME signed messages. The Internet standard for MIME PGP messages, RFC 2015, was published in 1996. To open this message correctly you will need to install E-mail or Usenet software that supports modern Internet standards. Move CONFIG_DEFAULT_DEVICE_TREE from board config directly to defconfig. This patch removes compilation warning: include/configs/zynq_zybo.h:24:0: warning: "CONFIG_DEFAULT_DEVICE_TREE" redefined [enabled by default] #define CONFIG_DEFAULT_DEVICE_TREE zynq-zybo Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-11-11kconfig: zynq: Add ZYBO boardPeter Crosthwaite
Add a defconfig and Kconfigury for the Digilent ZYBO board. Signed-off-by: Peter Crosthwaite <crosthwaite.peter@gmail.com> Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
