path: root/configs/zynq_zybo_defconfig
2015-06-10dts: Disable device tree for SPL on all boardsSimon Glass
We plan to enable device tree in SPL by default. Before doing this, explicitly disable it for all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-29ARM: zynq: rename CONFIG_ZYNQ to CONFIG_ARCH_ZYNQMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-18ARM: zynq: use "select" instead of default value in defconfigMasahiro Yamada
All the Zynq boards have switch to Driver Model. "select DM" is better than default value in each defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-08ARM: zynq: disable CONFIG_SYS_MALLOC_F to fix MMC bootMasahiro Yamada
Since commit 326a682358c1 (malloc_f: enable SYS_MALLOC_F by default if DM is on), Zynq MMC boot hangs up after printing the following: U-Boot SPL 2015.04-rc5-00053-gadcc570 (Apr 08 2015 - 12:59:11) mmc boot reading system.dtb Prior to commit 326a682358c1, Zynq boards enabled CONFIG_DM, but not CONFIG_SYS_MALLOC_F. That commit forcibly turned on CONFIG_SYS_MALLOC_F. I have not figured out the root cause, but anyway it looks like CONFIG_SYS_MALLOC_F gave a bad impact on the Zynq MMC boot. We are planning to have the v2015.04 release in a few days. I know this is a defensive fixup, but what I can do now is to add # CONFIG_SYS_MALLOC_F is not set to every Zynq defconfig file to get back the original behavior. Tested on: - Zedboard - ZC706 board Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org>
2015-01-29lib/rsa: Modify rsa to use DM driverRuchika Gupta
Modify rsa_verify to use the rsa driver of DM library .The tools will continue to use the same RSA sw library. CONFIG_RSA is now dependent on CONFIG_DM. All configurations which enable FIT based signatures have been modified to enable CONFIG_DM by default. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29configs: Move CONFIG_FIT_SIGNATURE to defconfigRuchika Gupta
For the platforms which use,CONFIG_FIT_SIGNATURE, the required configs are moved to the platform's defconfig file. Selecting CONFIG_FIT_SIGNATURE using defconfig automatically resolves the dependencies for signature verification. The RSA library gets automatically selected and user does not have to define CONFIG_RSA manually. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-13zynq: zybo: Move CONFIG_DEFAULT_DEVICE_TREE to defconfigMichal Simek
This is a MIME GnuPG-signed message. If you see this text, it means that your E-mail or Usenet software does not support MIME signed messages. The Internet standard for MIME PGP messages, RFC 2015, was published in 1996. To open this message correctly you will need to install E-mail or Usenet software that supports modern Internet standards. Move CONFIG_DEFAULT_DEVICE_TREE from board config directly to defconfig. This patch removes compilation warning: include/configs/zynq_zybo.h:24:0: warning: "CONFIG_DEFAULT_DEVICE_TREE" redefined [enabled by default] #define CONFIG_DEFAULT_DEVICE_TREE zynq-zybo Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-11-11kconfig: zynq: Add ZYBO boardPeter Crosthwaite
Add a defconfig and Kconfigury for the Digilent ZYBO board. Signed-off-by: Peter Crosthwaite <crosthwaite.peter@gmail.com> Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
