CONFIG_CMD_THOR_DOWNLOAD
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_ENV_IS_IN_SPI_FLASH
CONFIG_CMD_FPGA_LOADBP
CONFIG_CMD_FPGA_LOADFS
CONFIG_CMD_FPGA_LOADMK
CONFIG_CMD_FPGA_LOADP
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
Xilinx fixes for v2017.03
- defconfig alignment
- Topic.nl board updates
- Minor microblaze comment fix
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
Keep all defconfig sorted to ensure the smallest diff.
Make the naming scheme consistent; all SDHCI-base drivers prefixed
with CONFIG_MMC_SDHCI_.
While we are here, add "depends on ARCH_ZYNQ || ARCH_ZYNQMP".
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Enable CONFIG_SYS_TEXT_BASE via Kconfig.
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI.
My motivation for the rename is, ultimately, to make all the MMC
options prefixed with MMC_ and SDHCI options with MMC_SDHCI_,
like Linux.
[1] Rename the config option with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g'
[2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig
[3] run "tools/moveconfig.py -y MMC_SDHCI"
[4] add "depends on MMC_SDHCI" to existing SDHCI driver entries
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
in certain architectures. Migrate all config files.
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Move the SPL settings into common/spl where most of the SPL code is kept.
Update Microblaze, Zynq and ZynqMP defconfigs to reflect
latest Kconfig changes.
Enable config CONFIG_SYS_NO_FLASH through defconfig
for all zynq boards.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Define config USB_STORAGE through defconfig for all
respective zynq boards
Add Kconfig entry config option for USB_EHCI_ZYNQ
and update the same to enable for all zynq boards
which supports USB
Based on:
"ARM: uniphier: use the default CONFIG_BOOTDELAY=2"
(sha1: 7c8ef0feb97586d35b0296b48903daef8c06ab21)
"I do not insist on CONFIG_BOOTDELAY=3. The default value in Kconfig,
CONFIG_BOOTDELAY=2, is just fine for these boards."
Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Extending Kconfig for adding new platform is a lot of work
for nothing. Setting SYS_CONFIG_NAME directly in Kconfig and
remove all dependencies on TARGET_ZYNQ_* options including SPL.
As a side-effect it also remove custom init folder for ps7_init_gpl.*
files. Folder is chosen based on device-tree file.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
Enable FLASH_BAR for these targets to be in sync with all zynq boards.
Move CONFIG_USB_ULPI* from headers to defconfigs for boards that use it.
Also - add CONFIG_USB where necesarry - all boards use it,
but some are not defining it explicitly.
Affected boards:
colibri_t20, harmony, mcx, mt_ventoux, twister,
zynq_(picozed, zc702, zc706, zed, zybo)
Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
Add Arasan SDHCI entry to Kconfig and fix all references.
Change possition of SPI_FLASH to by align with savedefconfig.
Define CONFIG_SYS_PROMPT for all Zynq boards
It was removed by:
"kconfig: add config option for shell prompt"
(sha1: 181bd9dc61d2da88b78f1c1138a685dae39354d6)
This feature is required in SPL to enable support for loading from SPI
flash when the device is booted from QSPI.
Signed-off-by: Nathan Rossi <nathan@nathanrossi.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Clear driver dependecies via Kconfig. Remove PHYLIB dependency from
the driver.
Update the ZYBO device tree and enable config options that relate to the
added devices in the device tree.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Reviewed-by: Jagan Teki <jteki@openedev.com>
Move PHYLIB from board config to defconfig
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Add support for the debug UART to assist with early debugging. Enable it
for Zybo as an example.
Production boards should not use CONFIG_OF_EMBED. Fix this for the Zybo
boards.
The image to use now becomes u-boot-dtb.bin.
For example, the .bif file should contain a line like:
[load = 0x04000000,startup=0x04000000]/path/to/u-boot-dtb.bin
instead of:
[load = 0x04000000,startup=0x04000000]/path/to/u-boot.bin
When device tree is enabled we need to load u-boot-dtb.img. Change the
settings so that SPL does the right thing.
This reverts commit 321f86e18d6aae9f7b7ba3ef1eb0cec769481874.
The original bug has been fixed.
Tested-on: Zedboard and ZC706 board
Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Tested-on: zc702
Tested-by: Michal Simek <michal.simek@xilinx.com>
Some boards' defconfigs are disordered. Reorder them.
We have to set a MAC address to use network.
Otherwise, the tftpboot command fails with the following message:
Gem.e000b000 Waiting for PHY auto negotiation to complete........ done
*** ERROR: `ethaddr' not set
Since commit 92ac52082140 ("net: Remove all references to
CONFIG_ETHADDR and friends"), we can not use CONFIG_ETHADDR.
The easiest way to set a MAC address is to enable
CONFIG_NET_RANDOM_ETHADDR.
Use embedded DTB to let users use u-boot instead of u-boot-dtb.bin.
And fix SPL to use this target.
