path: root/configs/zynq_zc770_xm013_defconfig
2016-01-27ARM: zynq: Move FLASH_BAR to KconfigMichal Simek
Clean up config and use Kconfig more. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Enable SPI_FLASH for zc770 xm013 platformMichal Simek
Enable SPI flash. Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Define sys prompt for all Zynq boardsSiva Durga Prasad Paladugu
Define CONFIG_SYS_PROMPT for all Zynq boards It was removed by: "kconfig: add config option for shell prompt" (sha1: 181bd9dc61d2da88b78f1c1138a685dae39354d6) Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-13arm: zynq: Enable SPL_DM_SEQ_ALIAS for all Zynq configsNathan Rossi
This feature is required in SPL to enable support for loading from SPI flash when the device is booted from QSPI. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18net: gem: Add driver dependencies to PHYLIBMichal Simek
Clear driver dependecies via Kconfig. Remove PHYLIB dependency from the driver. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-07net: gem: Move gem to KconfigMichal Simek
Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-12-07ARM: zynq: Remove PHYLIB from config to defconfigMichal Simek
Move PHYLIB from board config to defconfig Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-11-04arm: zynq: Use separate device tree instead of embeddedSimon Glass
Production boards should not use CONFIG_OF_EMBED. Fix this for the Zybo boards. The image to use now becomes u-boot-dtb.bin. For example, the .bif file should contain a line like: [load = 0x04000000,startup=0x04000000]/path/to/u-boot-dtb.bin instead of: [load = 0x04000000,startup=0x04000000]/path/to/u-boot.bin When device tree is enabled we need to load u-boot-dtb.img. Change the settings so that SPL does the right thing. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-10-24Revert "ARM: zynq: disable CONFIG_SYS_MALLOC_F to fix MMC boot"Simon Glass
This reverts commit 321f86e18d6aae9f7b7ba3ef1eb0cec769481874. The original bug has been fixed. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-on: Zedboard and ZC706 board Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-on: zc702 Tested-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19zynq: enable CONFIG_NET_RANDOM_ETHADDRMasahiro Yamada
We have to set a MAC address to use network. Otherwise, the tftpboot command fails with the following message: Gem.e000b000 Waiting for PHY auto negotiation to complete........ done *** ERROR: `ethaddr' not set Since commit 92ac52082140 ("net: Remove all references to CONFIG_ETHADDR and friends"), we can not use CONFIG_ETHADDR. The easiest way to set a MAC address is to enable CONFIG_NET_RANDOM_ETHADDR. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19zynq: Make CONFIG_OF_EMBED default caseMichal Simek
Use embedded DTB to let users use u-boot instead of u-boot-dtb.bin. And fix SPL to use this target. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-07-01zynq: defconfig: Move CONFIG_OF_* to KconfigJagan Teki
This commit moves: - CONFIG_OF_CONTROL - SPL_DISABLE_OF_CONTROL from zynq_*_defconfig files into arch/arm/Kconfig "config ARCH_ZYNQ" Signed-off-by: Jagan Teki <jteki@openedev.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-10dts: Disable device tree for SPL on all boardsSimon Glass
We plan to enable device tree in SPL by default. Before doing this, explicitly disable it for all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-29ARM: zynq: rename CONFIG_ZYNQ to CONFIG_ARCH_ZYNQMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-18ARM: zynq: use "select" instead of default value in defconfigMasahiro Yamada
All the Zynq boards have switch to Driver Model. "select DM" is better than default value in each defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-08ARM: zynq: disable CONFIG_SYS_MALLOC_F to fix MMC bootMasahiro Yamada
Since commit 326a682358c1 (malloc_f: enable SYS_MALLOC_F by default if DM is on), Zynq MMC boot hangs up after printing the following: U-Boot SPL 2015.04-rc5-00053-gadcc570 (Apr 08 2015 - 12:59:11) mmc boot reading system.dtb Prior to commit 326a682358c1, Zynq boards enabled CONFIG_DM, but not CONFIG_SYS_MALLOC_F. That commit forcibly turned on CONFIG_SYS_MALLOC_F. I have not figured out the root cause, but anyway it looks like CONFIG_SYS_MALLOC_F gave a bad impact on the Zynq MMC boot. We are planning to have the v2015.04 release in a few days. I know this is a defensive fixup, but what I can do now is to add # CONFIG_SYS_MALLOC_F is not set to every Zynq defconfig file to get back the original behavior. Tested on: - Zedboard - ZC706 board Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org>
2015-01-29lib/rsa: Modify rsa to use DM driverRuchika Gupta
Modify rsa_verify to use the rsa driver of DM library .The tools will continue to use the same RSA sw library. CONFIG_RSA is now dependent on CONFIG_DM. All configurations which enable FIT based signatures have been modified to enable CONFIG_DM by default. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29configs: Move CONFIG_FIT_SIGNATURE to defconfigRuchika Gupta
For the platforms which use,CONFIG_FIT_SIGNATURE, the required configs are moved to the platform's defconfig file. Selecting CONFIG_FIT_SIGNATURE using defconfig automatically resolves the dependencies for signature verification. The RSA library gets automatically selected and user does not have to define CONFIG_RSA manually. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-08-30zynq: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Zynq board select menu to zynq/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="zynq"). Refactor board/xilinx/zynq/MAINTAINERS too. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Michal Simek <michal.simek@xilinx.com>
