path: root/configs/zynq_zc706_defconfig
2015-10-24Revert "ARM: zynq: disable CONFIG_SYS_MALLOC_F to fix MMC boot"Simon Glass
This reverts commit 321f86e18d6aae9f7b7ba3ef1eb0cec769481874. The original bug has been fixed. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-on: Zedboard and ZC706 board Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-on: zc702 Tested-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19zynq: enable CONFIG_NET_RANDOM_ETHADDRMasahiro Yamada
We have to set a MAC address to use network. Otherwise, the tftpboot command fails with the following message: Gem.e000b000 Waiting for PHY auto negotiation to complete........ done *** ERROR: `ethaddr' not set Since commit 92ac52082140 ("net: Remove all references to CONFIG_ETHADDR and friends"), we can not use CONFIG_ETHADDR. The easiest way to set a MAC address is to enable CONFIG_NET_RANDOM_ETHADDR. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19zynq: Make CONFIG_OF_EMBED default caseMichal Simek
Use embedded DTB to let users use u-boot instead of u-boot-dtb.bin. And fix SPL to use this target. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-07-01zynq: defconfig: Move CONFIG_OF_* to KconfigJagan Teki
This commit moves: - CONFIG_OF_CONTROL - SPL_DISABLE_OF_CONTROL from zynq_*_defconfig files into arch/arm/Kconfig "config ARCH_ZYNQ" Signed-off-by: Jagan Teki <jteki@openedev.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-25ARM: zynq: add separate configuration for ZC702 and ZC706Masahiro Yamada
Prior to this commit, ZC702 and ZC706 shared the same configuration and were built as follows: ZC702: make zynq_zc70x_defconfig && make ZC706: make zynq_zc70x_defconfig && make DEVICE_TREE=zynq-zc706 This commit introduces separate configuration for them, which makes the next commit much easier. Going forward, the recommended build commands are: ZC702: make zynq_zc702_defconfig && make ZC706: make zynq_zc706_defconfig && make Although the old work flow is still supported, CONFIG_TARGET_ZC70X has been marked as deprecated. If used, the warning message is shown to prompt users to switch to the new scheme. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
