path: root/configs/zynq_zc706_defconfig
2018-02-02Kconfig: gadget: Move CONFIG_USB_FUNCTION_THOR to KconfigLukasz Majewski
This commit moves USB_FUNCTION_THOR config to Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Acked-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-30arm: zynq: Moved ethernet PHY configs of Zynq boards to defconfigVipul Kumar
This patch moved ethernet PHY configs of Zynq boards to respective defconfig. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-30arm: zynq: Enable distro defaults settingMichal Simek
BOOTCOMMAND is composed with distro_bootcmd but this variable is not present. Enabling distro defaults setting is fixing it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-30arm: zynq: Move bootcommand to defconfigMichal Simek
It will cleanup generic config and enable option to change it for every board. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-30arm: zynq: Enable DM_GPIO when neededMichal Simek
There are two reasons for doing this change. There is still !DM driver for xilinx soft gpio IP and especially it is saving some space for memory constrained boards like cse (almost ~400B). Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-30arm: zynq: Add identification string to Xilinx boardsMichal Simek
It is good to see this string to make sure that u-boot which runs on the board is the same which should run there. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-14arm: zynq: Fix SPL SD boot modeMichal Simek
This patch is fixing two issues: 1. Insufficient stack size for fat fs buffers 2. Insufficient space in malloc area Tested on zc702 and zc706. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-29arm: zynq: Enable debug uart on zc706Michal Simek
Enable debug uart by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28arm: zynq: Move ZYNQ_SERIAL to KconfigMichal Simek
Move cadence/zynq serial driver via Kconfig Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-28arm: zynq: Enable FPGA/FPGA_XILINX via KconfigMichal Simek
Enabling fpga via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28arm: zynq: Enable MACRONIX flash for zc702/zc706/zc770 xm010Michal Simek
Enable MACRONIX flash for boards with QSPI enabled. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28arm: zynq: Enable bootz command for Xilinx platformsMichal Simek
bootz command is valid way how to boot Linux kernel. Enable it by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-11Convert CONFIG_CMD_THOR_DOWNLOAD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_THOR_DOWNLOAD Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-05-22Convert CONFIG_CMD_FPGA_LOADBP et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FPGA_LOADBP CONFIG_CMD_FPGA_LOADFS CONFIG_CMD_FPGA_LOADMK CONFIG_CMD_FPGA_LOADP Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-13Merge tag 'xilinx-fixes-for-v2017.03' of git://www.denx.de/git/u-boot-microblazeTom Rini
Xilinx fixes for v2017.03 - defconfig alignment - Topic.nl board updates - Minor microblaze comment fix
2017-02-10xilinx: Align defconfig with current Kconfig orderMichal Simek
Keep all defconfig sorted to ensure the smallest diff. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-01-31mmc: zynq: rename CONFIG_ZYNQ_SDHCI to CONFIG_MMC_SDHCI_ZYNQMasahiro Yamada
Make the naming scheme consistent; all SDHCI-base drivers prefixed with CONFIG_MMC_SDHCI_. While we are here, add "depends on ARCH_ZYNQ || ARCH_ZYNQMP". Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-10ARM: zynq: Move CONFIG_SYS_TEXT_BASE to KconfigMichal Simek
Enable CONFIG_SYS_TEXT_BASE via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-08-02xilinx: Sync defconfigs with the latest Kconfig layoutMichal Simek
Update Microblaze, Zynq and ZynqMP defconfigs to reflect latest Kconfig changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22zynq: config: Enable CONFIG_SYS_NO_FLASH through defconfigSiva Durga Prasad Paladugu
Enable config CONFIG_SYS_NO_FLASH through defconfig for all zynq boards. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22usb: zynq: Define config USB_STORAGE through defconfigSiva Durga Prasad Paladugu
Define config USB_STORAGE through defconfig for all respective zynq boards Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22usb: Kconfig: Add Kconfigs entry USB_EHCI_ZYNQSiva Durga Prasad Paladugu
Add Kconfig entry config option for USB_EHCI_ZYNQ and update the same to enable for all zynq boards which supports USB Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22ARM: zynq/zynqmp: Use the default CONFIG_BOOTDELAY=2Michal Simek
Based on: "ARM: uniphier: use the default CONFIG_BOOTDELAY=2" (sha1: 7c8ef0feb97586d35b0296b48903daef8c06ab21) "I do not insist on CONFIG_BOOTDELAY=3. The default value in Kconfig, CONFIG_BOOTDELAY=2, is just fine for these boards." Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-05-24ARM: zynq: Simplify zynq configurationMichal Simek
Extending Kconfig for adding new platform is a lot of work for nothing. Setting SYS_CONFIG_NAME directly in Kconfig and remove all dependencies on TARGET_ZYNQ_* options including SPL. As a side-effect it also remove custom init folder for ps7_init_gpl.* files. Folder is chosen based on device-tree file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-01Migrate CONFIG_ULPI* to KconfigMateusz Kulikowski
Move CONFIG_USB_ULPI* from headers to defconfigs for boards that use it. Also - add CONFIG_USB where necesarry - all boards use it, but some are not defining it explicitly. Affected boards: colibri_t20, harmony, mcx, mt_ventoux, twister, zynq_(picozed, zc702, zc706, zed, zybo) Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-22mmc: Kconfig: Add Arasan SDHCI entryMichal Simek
Add Arasan SDHCI entry to Kconfig and fix all references. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Move FLASH_BAR to KconfigMichal Simek
Clean up config and use Kconfig more. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Define sys prompt for all Zynq boardsSiva Durga Prasad Paladugu
Define CONFIG_SYS_PROMPT for all Zynq boards It was removed by: "kconfig: add config option for shell prompt" (sha1: 181bd9dc61d2da88b78f1c1138a685dae39354d6) Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
