path: root/configs/zynq_zc702_defconfig
2016-08-02xilinx: Sync defconfigs with the latest Kconfig layoutMichal Simek
Update Microblaze, Zynq and ZynqMP defconfigs to reflect latest Kconfig changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22zynq: config: Enable CONFIG_SYS_NO_FLASH through defconfigSiva Durga Prasad Paladugu
Enable config CONFIG_SYS_NO_FLASH through defconfig for all zynq boards. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22usb: zynq: Define config USB_STORAGE through defconfigSiva Durga Prasad Paladugu
Define config USB_STORAGE through defconfig for all respective zynq boards Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22usb: Kconfig: Add Kconfigs entry USB_EHCI_ZYNQSiva Durga Prasad Paladugu
Add Kconfig entry config option for USB_EHCI_ZYNQ and update the same to enable for all zynq boards which supports USB Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22ARM: zynq/zynqmp: Use the default CONFIG_BOOTDELAY=2Michal Simek
Based on: "ARM: uniphier: use the default CONFIG_BOOTDELAY=2" (sha1: 7c8ef0feb97586d35b0296b48903daef8c06ab21) "I do not insist on CONFIG_BOOTDELAY=3. The default value in Kconfig, CONFIG_BOOTDELAY=2, is just fine for these boards." Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-05-24ARM: zynq: Simplify zynq configurationMichal Simek
Extending Kconfig for adding new platform is a lot of work for nothing. Setting SYS_CONFIG_NAME directly in Kconfig and remove all dependencies on TARGET_ZYNQ_* options including SPL. As a side-effect it also remove custom init folder for ps7_init_gpl.* files. Folder is chosen based on device-tree file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-01Migrate CONFIG_ULPI* to KconfigMateusz Kulikowski
Move CONFIG_USB_ULPI* from headers to defconfigs for boards that use it. Also - add CONFIG_USB where necesarry - all boards use it, but some are not defining it explicitly. Affected boards: colibri_t20, harmony, mcx, mt_ventoux, twister, zynq_(picozed, zc702, zc706, zed, zybo) Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-22mmc: Kconfig: Add Arasan SDHCI entryMichal Simek
Add Arasan SDHCI entry to Kconfig and fix all references. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Move FLASH_BAR to KconfigMichal Simek
Clean up config and use Kconfig more. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Define sys prompt for all Zynq boardsSiva Durga Prasad Paladugu
Define CONFIG_SYS_PROMPT for all Zynq boards It was removed by: "kconfig: add config option for shell prompt" (sha1: 181bd9dc61d2da88b78f1c1138a685dae39354d6) Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-13arm: zynq: Enable SPL_DM_SEQ_ALIAS for all Zynq configsNathan Rossi
This feature is required in SPL to enable support for loading from SPI flash when the device is booted from QSPI. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18net: gem: Add driver dependencies to PHYLIBMichal Simek
Clear driver dependecies via Kconfig. Remove PHYLIB dependency from the driver. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-07ARM: zynq: Enable debug console for zc702Michal Simek
2015-12-07net: gem: Move gem to KconfigMichal Simek
Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-12-07ARM: zynq: Remove PHYLIB from config to defconfigMichal Simek
Move PHYLIB from board config to defconfig Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-11-04arm: zynq: Use separate device tree instead of embeddedSimon Glass
Production boards should not use CONFIG_OF_EMBED. Fix this for the Zybo boards. The image to use now becomes u-boot-dtb.bin. For example, the .bif file should contain a line like: [load = 0x04000000,startup=0x04000000]/path/to/u-boot-dtb.bin instead of: [load = 0x04000000,startup=0x04000000]/path/to/u-boot.bin When device tree is enabled we need to load u-boot-dtb.img. Change the settings so that SPL does the right thing. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-10-25configs: zynq: Enable zynq qspi controllerJagan Teki
Enable zynq qspi controller driver on respective zynq boards. Signed-off-by: Jagan Teki <jteki@openedev.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Jagan Teki <jteki@openedev.com>
2015-10-25configs: Enable legacy SPI flash interface supportJagan Teki
Enable legacy spi-flash interface support for boards which supports qspi controller with connected spi-nor flash. Signed-off-by: Jagan Teki <jteki@openedev.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Jagan Teki <jteki@openedev.com>
2015-10-24Revert "ARM: zynq: disable CONFIG_SYS_MALLOC_F to fix MMC boot"Simon Glass
This reverts commit 321f86e18d6aae9f7b7ba3ef1eb0cec769481874. The original bug has been fixed. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-on: Zedboard and ZC706 board Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-on: zc702 Tested-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19zynq: enable CONFIG_NET_RANDOM_ETHADDRMasahiro Yamada
We have to set a MAC address to use network. Otherwise, the tftpboot command fails with the following message: Gem.e000b000 Waiting for PHY auto negotiation to complete........ done *** ERROR: `ethaddr' not set Since commit 92ac52082140 ("net: Remove all references to CONFIG_ETHADDR and friends"), we can not use CONFIG_ETHADDR. The easiest way to set a MAC address is to enable CONFIG_NET_RANDOM_ETHADDR. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19zynq: Make CONFIG_OF_EMBED default caseMichal Simek
Use embedded DTB to let users use u-boot instead of u-boot-dtb.bin. And fix SPL to use this target. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19ARM: zynq: drop "optional" from board select in favor of ZC702Masahiro Yamada
One disadvantage of commit a26cd04920dc (arch: Make board selection choices optional) is that Kconfig could create such an insane .config file that no board is selected. Rip off the "optional" again in favor of ZC702 as the default target. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-07-01zynq: defconfig: Move CONFIG_OF_* to KconfigJagan Teki
This commit moves: - CONFIG_OF_CONTROL - SPL_DISABLE_OF_CONTROL from zynq_*_defconfig files into arch/arm/Kconfig "config ARCH_ZYNQ" Signed-off-by: Jagan Teki <jteki@openedev.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-25ARM: zynq: add separate configuration for ZC702 and ZC706Masahiro Yamada
Prior to this commit, ZC702 and ZC706 shared the same configuration and were built as follows: ZC702: make zynq_zc70x_defconfig && make ZC706: make zynq_zc70x_defconfig && make DEVICE_TREE=zynq-zc706 This commit introduces separate configuration for them, which makes the next commit much easier. Going forward, the recommended build commands are: ZC702: make zynq_zc702_defconfig && make ZC706: make zynq_zc706_defconfig && make Although the old work flow is still supported, CONFIG_TARGET_ZC70X has been marked as deprecated. If used, the warning message is shown to prompt users to switch to the new scheme. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
