path: root/configs/zynq_z_turn_defconfig
2019-06-14configs: Migrate CONFIG_SYS_LDSCRIPT to KconfigTom Rini
In order to migrate this symbol to Kconfig introduce a new symbol to guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then provide the exact final location o the script. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-18CONFIG_SPL_SYS_[DI]CACHE_OFF: addTrevor Woerner
While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances where these configuration items are conditional on SPL. This commit adds SPL variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates the configurations as required. Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Make the default depend on the setting for full U-Boot, update more zynq hardware] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-02-14ARM: zynq: Run distribution boot commands firstMichal Simek
This patch is doing two things. 1. Exchanging order of boot commands. distro_bootcmd is run first followed by Xilinx boot command. 2. Remove CONFIG_BOOTCOMMAND from configs (and follow mainline) by creating Xilinx distribution bootcommand and wiring it as the last bootcommand. QSPI, NAND distribution boot command will be added later. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-01-07configs: Resync with savedefconfigTom Rini
2018-07-19xilinx: Enable led support for some boardsMichal Simek
Enable led support for boards which have "gpio-leds" node. And also for microblaze which is converted to DM_GPIO now. Tested on zcu100. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-06-04xilinx: Sync symbols location in defconfigsMichal Simek
CONFIG_DEBUG_UART_BASE and CONFIG_DEBUG_UART_CLOCK have changed that's why this sync. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-11arm: zynq: Remove checkboard and enable DISPLAY_CPUINFOMichal Simek
Now that showing silicon version is part of the CPU info display, let's remove checkboard(). Note that the generic show_board_info() will still show the DT 'model' property. For instance: U-Boot 2018.05-rc2-00025-g611b3ee0159b (Apr 19 2018 - 11:23:12 +0200) CPU: Zynq 7z045 Silicon: v1.0 Model: Zynq ZC706 Development Board I2C: ready Based on patches from Ariel D'Alessandro <ariel@vanguardiasur.com.ar>, and Ezequiel Garcia <ezequiel@vanguardiasur.com.ar> mini configuration doesn't need to show this information. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-28Migrate IMAGE_FORMAT_LEGACY to KconfigAlex Kiernan
This converts IMAGE_FORMAT_LEGACY to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-09ARM: dts: zynq: Rename dts for Z-turn boardAnton Gerasimov
Makes naming in line with other Zynq boards. Signed-off-by: Anton Gerasimov <tossel@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-03-23xilinx: Sync defconfigs with latest Kconfig updatesMichal Simek
Make defconfigs up2date with current location. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-02-28arm: zynq: fpga: Added Kconfig support for CONFIG_FPGA_ZYNQPLVipul Kumar
This patch added Kconfig support for CONFIG_FPGA_ZYNQPL and migrates the values over to the defconfigs. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
2018-02-02Kconfig: gadget: Move CONFIG_USB_FUNCTION_THOR to KconfigLukasz Majewski
This commit moves USB_FUNCTION_THOR config to Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Acked-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-30arm: zynq: Moved ethernet PHY configs of Zynq boards to defconfigVipul Kumar
This patch moved ethernet PHY configs of Zynq boards to respective defconfig. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-30arm: zynq: Enable distro defaults settingMichal Simek
BOOTCOMMAND is composed with distro_bootcmd but this variable is not present. Enabling distro defaults setting is fixing it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-30arm: zynq: Move bootcommand to defconfigMichal Simek
It will cleanup generic config and enable option to change it for every board. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-30arm: zynq: Enable DM_GPIO when neededMichal Simek
There are two reasons for doing this change. There is still !DM driver for xilinx soft gpio IP and especially it is saving some space for memory constrained boards like cse (almost ~400B). Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-14arm: zynq: Fix SPL SD boot modeMichal Simek
This patch is fixing two issues: 1. Insufficient stack size for fat fs buffers 2. Insufficient space in malloc area Tested on zc702 and zc706. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28arm: zynq: Move ZYNQ_SERIAL to KconfigMichal Simek
Move cadence/zynq serial driver via Kconfig Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-28arm: zynq: Enable FPGA/FPGA_XILINX via KconfigMichal Simek
Enabling fpga via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-11Convert CONFIG_CMD_THOR_DOWNLOAD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_THOR_DOWNLOAD Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-02zynq: Add Z-Turn boardAlexander Graf
The Z-Turn board is a low cost development board based on the Xilinx Zynq SoC. While it's powerful and quite versatile, it so far lacked upstream support. This patch adds basic support for the Z-Turn. It does however for now miss enablement for MIO51 reset which means that USB and ethernet don't work. For that either FSBL or SPL need to be adjusted. The SPL part will follow later. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
