path: root/configs/zynq_picozed_defconfig
2015-04-29ARM: zynq: rename CONFIG_ZYNQ to CONFIG_ARCH_ZYNQMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-29zynq: Add Zynq PicoZed board supportNathan Rossi
The PicoZed is a System-on-Module board which is marketed as part of the ZedBoard/MicroZed/etc. collection. It includes a Zynq-7000 processor. This patch adds support that covers all the variants of the PicoZed including the SKUs with Z7010/Z7020 and Z7015/Z7030 Zynq chips. This patch set however only covers support for the System-on-Module and does not cover any extra components that are available on carrier boards (except those that are fanned out of the module itself). More information on this board, its variants and available carrier boards is available at: http://zedboard.org/product/picozed Signed-off-by: Nathan Rossi <nathan.rossi@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
