path: root/configs/zynq_picozed_defconfig
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-01Migrate CONFIG_ULPI* to KconfigMateusz Kulikowski
Move CONFIG_USB_ULPI* from headers to defconfigs for boards that use it. Also - add CONFIG_USB where necesarry - all boards use it, but some are not defining it explicitly. Affected boards: colibri_t20, harmony, mcx, mt_ventoux, twister, zynq_(picozed, zc702, zc706, zed, zybo) Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-22mmc: Kconfig: Add Arasan SDHCI entryMichal Simek
Add Arasan SDHCI entry to Kconfig and fix all references. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Define sys prompt for all Zynq boardsSiva Durga Prasad Paladugu
Define CONFIG_SYS_PROMPT for all Zynq boards It was removed by: "kconfig: add config option for shell prompt" (sha1: 181bd9dc61d2da88b78f1c1138a685dae39354d6) Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-13arm: zynq: Enable SPL_DM_SEQ_ALIAS for all Zynq configsNathan Rossi
This feature is required in SPL to enable support for loading from SPI flash when the device is booted from QSPI. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18net: gem: Add driver dependencies to PHYLIBMichal Simek
Clear driver dependecies via Kconfig. Remove PHYLIB dependency from the driver. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-07net: gem: Move gem to KconfigMichal Simek
Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-12-07ARM: zynq: Remove PHYLIB from config to defconfigMichal Simek
Move PHYLIB from board config to defconfig Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-11-04arm: zynq: Use separate device tree instead of embeddedSimon Glass
Production boards should not use CONFIG_OF_EMBED. Fix this for the Zybo boards. The image to use now becomes u-boot-dtb.bin. For example, the .bif file should contain a line like: [load = 0x04000000,startup=0x04000000]/path/to/u-boot-dtb.bin instead of: [load = 0x04000000,startup=0x04000000]/path/to/u-boot.bin When device tree is enabled we need to load u-boot-dtb.img. Change the settings so that SPL does the right thing. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19zynq: enable CONFIG_NET_RANDOM_ETHADDRMasahiro Yamada
We have to set a MAC address to use network. Otherwise, the tftpboot command fails with the following message: Gem.e000b000 Waiting for PHY auto negotiation to complete........ done *** ERROR: `ethaddr' not set Since commit 92ac52082140 ("net: Remove all references to CONFIG_ETHADDR and friends"), we can not use CONFIG_ETHADDR. The easiest way to set a MAC address is to enable CONFIG_NET_RANDOM_ETHADDR. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19zynq: Make CONFIG_OF_EMBED default caseMichal Simek
Use embedded DTB to let users use u-boot instead of u-boot-dtb.bin. And fix SPL to use this target. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-29ARM: zynq: rename CONFIG_ZYNQ to CONFIG_ARCH_ZYNQMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-29zynq: Add Zynq PicoZed board supportNathan Rossi
The PicoZed is a System-on-Module board which is marketed as part of the ZedBoard/MicroZed/etc. collection. It includes a Zynq-7000 processor. This patch adds support that covers all the variants of the PicoZed including the SKUs with Z7010/Z7020 and Z7015/Z7030 Zynq chips. This patch set however only covers support for the System-on-Module and does not cover any extra components that are available on carrier boards (except those that are fanned out of the module itself). More information on this board, its variants and available carrier boards is available at: http://zedboard.org/product/picozed Signed-off-by: Nathan Rossi <nathan.rossi@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
