path: root/configs/zynq_cse_nand_defconfig
2019-06-14configs: Migrate CONFIG_SYS_LDSCRIPT to KconfigTom Rini
In order to migrate this symbol to Kconfig introduce a new symbol to guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then provide the exact final location o the script. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-18CONFIG_SPL_SYS_[DI]CACHE_OFF: addTrevor Woerner
While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances where these configuration items are conditional on SPL. This commit adds SPL variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates the configurations as required. Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Make the default depend on the setting for full U-Boot, update more zynq hardware] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-29ARM: zynq: Disable net for cse nor/nandMichal Simek
There is no need to waste 6k if none needs it. zynq_cse_nand : all -6486 bss -20 data -136 rodata -606 text -5724 zynq_cse_nor : all -6486 bss -20 data -136 rodata -606 text -5724 Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-26ARM: zynq: cse: Shrink u-boot sizeMichal Simek
U-Boot is growing that's why not needed features can be disabled: - CMDLINE_EDITING - AUTO_COMPLETE - SYS_LONGHELP Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-26ARM: zynq: cse: Disable autoboot featureMichal Simek
Intention of CSE targets is not boot anything that's why also bootdelay is not necessary Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-09-26arm64: zynqmp: Handle CONFIG_BOARD_LATE_INIT via KconfigMichal Simek
Disable BOARD_LATE_INIT via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-08-06Kconfig: Move config SYS_MALLOC_LEN to Kconfig for zynqSiva Durga Prasad Paladugu
This patch moves the the config SYS_MALLOC_LEN to Kconfig. It will be just for Zynq arch and to do will be for all other archs. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Vipul Kumar <vipul.kumar@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-19arm: zynq: Setup ENV_SIZE via KconfigMichal Simek
Simplify zynq_cse config by setting up ENV_SIZE via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19arm: zynq: Add Nand flash mini u-boot configuration for zynqSiva Durga Prasad Paladugu
Add configuration files/dtses for mini u-boot configuration which runs on smaller footprint of memory. This configuration has only required nand flash support. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
