CONFIG_MXC_UART
Acked-by: Peng Fan <peng.fan@nxp.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
The motivation for moving MX25 selection to Kconfig is to be
able to better handle MX25 specific errata, so that an errata option
can be selected at SoC level instead of board level.
This selection method also aligns with the way other i.MX SoCs are
selected in U-Boot.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-by: Sebastien Bourdelin <sebastien.bourdelin@savoirfairelinux.com>
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
CONFIG_ENV_IS_IN_FLASH
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Some boards' defconfigs are disordered. Reorder them.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This patch moves the following config options to Kconfig:
CONFIG_AUTOBOOT_KEYED
CONFIG_AUTOBOOT_PROMPT
CONFIG_AUTOBOOT_DELAY_STR
CONFIG_AUTOBOOT_STOP_STR
AUTOBOOT_KEYED_CTRLC
[trini: Drop ip04 and pm9263 configs/ additions, those boards previously
set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over
all boards that did change. Make digsy_mtc_* string include seconds to
match others and not warn. ]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
