path: root/configs/zipitz2_defconfig
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_LZMA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_LZMA Signed-off-by: Simon Glass <sjg@chromium.org>
2016-11-23serial: pxa: use kconfig for serial configurationMarcel Ziswiler
Migrate the PXA serial driver to be configured via Kconfig. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-04-18kconfig: Move CONFIG_OF_LIBFDT to KconfigMichal Simek
This patch follows work done by: "Move CONFIG_OF_LIBFDT to Kconfig" (sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4) Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Add xpress* to the patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-27zipitz2: restore board supportVasily Khoruzhick
zipitz2 was dropped in 49d8899ba9c26335e4a12e01c18028fc5e40c796 Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
2015-09-11arm: Remove pxa255_idp, zipitz2 boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
