path: root/configs/zipitz2_defconfig
2016-03-27zipitz2: restore board supportVasily Khoruzhick
zipitz2 was dropped in 49d8899ba9c26335e4a12e01c18028fc5e40c796 Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
2015-09-11arm: Remove pxa255_idp, zipitz2 boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
