path: root/configs/yucca_defconfig
2015-05-10kconfig: Move REGEX to KconfigJoe Hershberger
Having this as a Kconfig allows it to be a dependent feature. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
