- Finish migration of CONFIG_PHYLIB and a number of related symbols to
defconfig files.
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_FSL_USDHC
[trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list]
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
CONFIG_SUPPORT_EMMC_BOOT
As requested by Michal Simek <michal.simek@xilinx.com>, these boards
have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated:
xilinx_zynqmp_zc1275_revB
xilinx_zynqmp_zc1751_xm018_dc4
xilinx_zynqmp_zc1751_xm019_dc5
xilinx_zynqmp_zcu100_revC
xilinx_zynqmp_zcu102_rev1_0
xilinx_zynqmp_zcu102_revA
xilinx_zynqmp_zcu102_revB
xilinx_zynqmp_zcu104_revA
xilinx_zynqmp_zcu104_revC
xilinx_zynqmp_zcu106_revA
xilinx_zynqmp_zcu111_revA
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Acked-by: Ramon Fried <ramon.fried@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both
obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be
used to control the build in both SPL and U-Boot.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
The bounce buffer is used by a few drivers (most of the MMC drivers)
to overcome limitations in their respective DMA implementation.
This moves the configuration to Kconfig and makes it user-selectable
(even though it will be a required feature to make those drivers
work): the expected usage is for drivers depending on this to 'select'
it unconditionally from their respective Kconfig (see follow-up
patches).
This commit includes a full migration using moveconfig.py to ensure
that each commit compiles. To ensure bisectability we update
dependencies of various drivers to now select BOUNCE_BUFFER when needed.
[trini: Squash all patches to ensure bisectability]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion]
Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion]
Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
CONFIG_BOARD_EARLY_INIT_F
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
This patch follows work done by:
"Move CONFIG_OF_LIBFDT to Kconfig"
(sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4)
[trini: Add xpress* to the patch]
This patch add support for the CCV xPress board which is equipped
with the i.MX6UL. And provides the following interfaces:
- 128MiB DDR
- UART
- I2C
- eMMC (with booting)
- Ethernet
- USB
This patch adds two build targets. One with and one without SPL. The
non-SPL version is used for loading U-Boot via USB (imx_usb_loader).
Cc: Fabio Estevam <fabio.estevam@nxp.com>
