path: root/configs/xpress_spl_defconfig
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_EXT_SUPPORT to KconfigSimon Glass
2016-04-18kconfig: Move CONFIG_OF_LIBFDT to KconfigMichal Simek
This patch follows work done by: "Move CONFIG_OF_LIBFDT to Kconfig" (sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4) Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Add xpress* to the patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-26arm: mx6: Add CCV xPress board supportStefan Roese
This patch add support for the CCV xPress board which is equipped with the i.MX6UL. And provides the following interfaces: - 128MiB DDR - UART - I2C - eMMC (with booting) - Ethernet - USB This patch adds two build targets. One with and one without SPL. The non-SPL version is used for loading U-Boot via USB (imx_usb_loader). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
