path: root/configs/xilinx_zynqmp_zcu104_revC_defconfig
2019-02-14arm64: zynqmp: Remove board config filesMichal Simek
All options have been moved to Kconfig and there is no need to have board header files. Mini configurations require them that's why they are still there. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-02-14arm64: zynqmp: Switch all platforms to DM_I2CMichal Simek
CONFIG_PCA953X is not needed because of PCA953X is integrated in gpio subsystem already. That's why also remove CMD_PCA953X which is only for this driver. zcu102/zcu104-revC/zcu106/zcu111 contain links to eeprom which stores MAC address. DM_I2C is not enabled for the whole SoC because it increase size for mini configurations and there is no I2C symbol present to setup dependencies. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-02-07configs: Remove SF_DUAL_FLASHVignesh R
SF_DUAL_FLASH claims to enable support for SF_DUAL_STACKED_FLASH and SF_DUAL_PARALLEL_FLASH. But, in current U-Boot code, grepping for above enums yield no user and therefore support seems to be incomplete. Remove these configs so as to avoid confusion. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-01-24arm64: zynqmp: Convert all reference boards to OF_SEPARATEMichal Simek
Build warning was added by: "fdt: Add warning about CONFIG_OF_EMBED" (sha1: 841d5fbae4e993476fa87d8933db0cd58d3c2d41) ZynqMP mini configurations are not moved yet and it is questionable if make sense to move them too. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Enable FPGA_LOAD_SECURE commandMichal Simek
Enable fpga load secure feature for xilinx platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Enable ISSI flash for some platformsMichal Simek
Enable ISSI flash for platforms. Xilinx reference boards are also used internally with different flash part to increase coverage that's why enable also ISSI parts for all these boards even if that board is released only with one part. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Enable SPI on several boardsMichal Simek
Enable GQSPI driver, SF command and SPL support for some platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Setup DM_ETH/MMC if NET/MMC is enabledMichal Simek
Setup proper ETH/MMC dependency for the whole platform. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-03arm64: zynqmp: Add new header file for zcu104 RevCT Karthik Reddy
Created a new header file for zcu104 RevC board and added below configurations to use MAC address from EEPROM. CONFIG_ZYNQ_GEM_EEPROM_ADDR CONFIG_ZYNQ_EEPROM_BUS Added CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 to xilinx_zynqmp_zcu104_revC_defconfig Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-10-16arm64: zynqmp: Enable MP by default via KconfigMichal Simek
Simplify defconfig for ZynqMP but keep option not to enable it for mini targets. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19arm64: zynqmp: Sync defconfigs in connection to DEFINE_TCM_OCM_MMAPMichal Simek
CONFIG_MP was added to Kconfig with enabling CONFIG_DEFINE_TCM_OCM_MMAP=y for zynqmp boards. This option is enabled by default that's why it shouldn't be in defconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-06-04xilinx: Sync symbols location in defconfigsMichal Simek
CONFIG_DEBUG_UART_BASE and CONFIG_DEBUG_UART_CLOCK have changed that's why this sync. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-18arm64: zynqmp: Use DWC3 generic driver and DM_USBMichal Simek
Remove harcoded XHCI lists and detect mode, speed based on DT. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Serial-changes: 2 - Remove also XHCI macros from hardware.h - Remove additional new line in zcu106
2018-05-11arm64: zynqmp: Show model information instead of custom IDENT_STRINGMichal Simek
DISPLAY_BOARDINFO in OF case show model identification string from DT. Enable this feature instead of custom IDENT_STRING which does the same thing. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2018-04-09arm64: zynqmp: Add support for zcu104 customer boardMichal Simek
Xilinx zcu104 is another customer board. It is sort of zcu102 clone with some differences. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
