path: root/configs/xilinx_zynqmp_zcu102_revB_defconfig
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-10xilinx: Align defconfig with current Kconfig orderMichal Simek
Keep all defconfig sorted to ensure the smallest diff. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-02-08cmd: move CONFIG_CMD_UNZIP and CONFIG_CMD_ZIP to KconfigMasahiro Yamada
CONFIG_CMD_ZIP is not defined by any board. I am moving CONFIG_CMD_UNZIP to defconfig files except UniPhier SoC family. I am the maintainer of UniPhier platform, so I know "select CMD_UNZIP" is better for this platform. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
2017-01-31mmc: zynq: rename CONFIG_ZYNQ_SDHCI to CONFIG_MMC_SDHCI_ZYNQMasahiro Yamada
Make the naming scheme consistent; all SDHCI-base drivers prefixed with CONFIG_MMC_SDHCI_. While we are here, add "depends on ARCH_ZYNQ || ARCH_ZYNQMP". Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-17drivers: usb: Add USB_XHCI_ZYNQMP to KconfigMichal Simek
Move symbol to Kconfig to cleanup configuration file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-20block: Move ceva driver to DMMichal Simek
This patch also includes ARM64 zynqmp changes: - Remove platform non DM initialization - Remove hardcoded sata base address Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-09Revert "Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze"Tom Rini
This reverts commit 3edc0c252257e4afed163a3a74aba24a5509b198, reversing changes made to bb135a0180c31fbd7456021fb9700b49bba7f533.
2016-12-08block: Move ceva driver to DMMichal Simek
This patch also includes ARM64 zynqmp changes: - Remove platform non DM initialization - Remove hardcoded sata base address Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Series-to: sjg, agraf@suse.de Series-cc: uboot Series-version: 4 Series-changes: 2 - make ceva_init_sata static - Move SATA_CEVA to defconfig - Initalized max_lun and max_id platdata Series-changes: 3 - Extend Kconfig help description - sort dm.h - Remove SPL undefinition from board file - Fix Kconfig dependecies
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-22ARM64: zynqmp: Enable CONFIG_AHCI via KconfigMichal Simek
Move CONFIG_AHCI to defconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-22fpga: xilinx: zynqmp: Add PL bitstream download support for ZynqMPSiva Durga Prasad Paladugu
Add PL bitstream dowload support for ZynqMP Bitstream will be validated by uboot and loaded to PL by invoking an smc instruction to ATF which route this request to PMU FW which will take care of loading it to PL Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-08-02ARM64: zynqmp: Do not enable DM_MMC by defaultMichal Simek
The patch: "dm: mmc: zynq: Convert zynq to use driver model for MMC" (sha1: 329a449f2c289b4de8f892fca1d9379ce5fd81b8) added dependency on enabling some MMC options by default. There are minimal ZynqMP configurations which require only minimal configurations to be enabled to keep u-boot size as lower as possible. Move options to defconfig instead. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-08-02ARM64: zynqmp: Define config USB_STORAGE through defconfigMichal Simek
Define config USB_STORAGE through defconfig for all Xilinx ZynqMP boards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-08-02xilinx: Sync defconfigs with the latest Kconfig layoutMichal Simek
Update Microblaze, Zynq and ZynqMP defconfigs to reflect latest Kconfig changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22ARM64: zynqmp: Enable SPL for all zynqmp boardsMichal Simek
Compile SPL for all boards even psu_init.c/h files are not in the tree yet. But this change enables covering SPL issues in mainline. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22ARM64: zynqmp: Enable CLK and SPL_CLK by defaultMichal Simek
Serial driver starts to use clk framework that's why enable it by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22ARM: zynq/zynqmp: Use the default CONFIG_BOOTDELAY=2Michal Simek
Based on: "ARM: uniphier: use the default CONFIG_BOOTDELAY=2" (sha1: 7c8ef0feb97586d35b0296b48903daef8c06ab21) "I do not insist on CONFIG_BOOTDELAY=3. The default value in Kconfig, CONFIG_BOOTDELAY=2, is just fine for these boards." Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Modified: configs/ls1012afrdm_qspi_defconfig configs/ls1012aqds_qspi_defconfig configs/ls1012ardb_qspi_defconfig include/configs/ls1012afrdm.h include/configs/ls1012aqds.h include/configs/ls1012ardb.h Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-06ARM64: zynqmp: Extend malloc space before relocationMichal Simek
For boards which have more devices it is necessary to extend malloc space. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Enable support for SPL FIT imagesMichal Simek
Enable support for RAM based FIT images read by SPL. Empty function for now to keep compiler happy. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-27efi_loader: Select bounce buffers for known-bad boardsAlexander Graf
We know for certain that we have 32bit DMA hardware, but 64bit addresses on LS2085A and ZynqMP, so let's enable EFI bounce buffers for all defconfigs on these SoCs. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-05-24ARM64: zynqmp: Enable CLK frameworkMichal Simek
ZynqMP is using fixed clocks now that's why enabling it to be available for drivers. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-05-24ARM64: zynqmp: Wire up debug_uart setupMichal Simek
It has to be enabled by debug_uart_init(). Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-05-24ARM64: zynqmp: Enable HUSH parser for all zynqmp targetsMichal Simek
Enable HUSH for all zynqmp boards which don't have it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-20configs: Update some Xilinx configsTom Rini
As part of 3457bba these configs didn't get updated. Update them now. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-13ARM64: zynqmp: Add defconfig for zcu102 revB boardMichal Simek
Support natively revB board. Till now support for revB was done via zcu102 defconfig where device-tree was changed to revB. This patch is adding direct defconfig for RevB. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
