path: root/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig
2018-03-01i2c: Added kconfig support for CONFIG_ZYNQ_I2C0 and CONFIG_ZYNQ_I2C1Vipul Kumar
This patch added Kconfig support for CONFIG_ZYNQ_I2C0 and CONFIG_ZYNQ_I2C1 and enabled it in respective defconfig. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-03-01i2c: Added Kconfig support for CONFIG_ZYNQ_GEM_I2C_MAC_OFFSETVipul Kumar
This patch added Kconfig support for CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET and enabled it in respective defconfig. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-03-01i2c: Enabled CONFIG_SYS_I2C_ZYNQ in the respective defconfigVipul Kumar
This patch enabled CONFIG_SYS_I2C_ZYNQ in the respective defconfig. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-02-02Kconfig: gadget: Move CONFIG_USB_FUNCTION_THOR to KconfigLukasz Majewski
This commit moves USB_FUNCTION_THOR config to Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Acked-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-30arm64: zynqmp: Moved ethernet PHY configs of ZynqMP boards to defconfigVipul Kumar
This patch moved ethernet PHY configs of ZynqMP boards to respective defconfig. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-18arm64: zynqmp: Dont use 4K sector erase by default for spi-flashesSiva Durga Prasad Paladugu
Dont use 4K sector erase by default, Disabling this would use 64K sector erase and decreases erase time. Also disabled by the fact that UBIFS and JFFS2 won't work with 4K sector erase. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-18arm64: zynqmp: Enable spi flashesMichal Simek
Enabling all spi flashes because some of these boards can have different flashes compared to public version. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-14arm64: zynqmp: Enable fpga bitstream loadingMichal Simek
Enable fpga loadb and loadbp for zynqmp platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-14arm64: zynqmp: Enable SPL ram supportMichal Simek
2017-12-14arm64: zynqmp: Enable misc devicesMichal Simek
Enable misc devices for zynqmp targets. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-14arm64: zynqmp: Enable clock command for all boardsMichal Simek
clk command provides an option to see actual clock setting. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-14arm64: zynqmp: Do not use SPL_SYS_MALLOC_SIMPLE allocatorMichal Simek
This was caused by: "fs/fat: Reduce stack usage" (sha1:2460098cffacd18729262e3ed36656e6943783ed) which converted fat code to use malloc. But simple malloc is not freeing space that's why full malloc implementation is needed. Malloc space is added to RAM. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-11-28arm64: zynqmp: Add support for zcu102 1.0 revMichal Simek
1.0 rev is the latest rev. Describe information in eeprom. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
