path: root/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-24usb: host: remove the xhci-zynqmp driverJean-Jacques Hiblot
This driver is not used anymore. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-10-08arm64: zynqmp: Define default SYS_PROMPTMichal Simek
All boards are using the same prompt that's why add it as default value to Kconfig to simplify defconfigs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2019-10-08arm64: zynqmp: Define default SPL_TEXT_BASE address in KconfigMichal Simek
Define default address via Kconfig. There is no need to change this address for most of the boards but it is also possible. This one line save a lot of lines in defconfigs that's why make sense to do it. The similar change has been done by commit 9340d8fe8beb ("sunxi: move CONFIG_SPL_TEXT_BASE from *_defconfig to Kconfig") Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-02-14arm64: zynqmp: Remove board config filesMichal Simek
All options have been moved to Kconfig and there is no need to have board header files. Mini configurations require them that's why they are still there. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Convert all reference boards to OF_SEPARATEMichal Simek
Build warning was added by: "fdt: Add warning about CONFIG_OF_EMBED" (sha1: 841d5fbae4e993476fa87d8933db0cd58d3c2d41) ZynqMP mini configurations are not moved yet and it is questionable if make sense to move them too. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Enable FPGA_LOAD_SECURE commandMichal Simek
Enable fpga load secure feature for xilinx platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Enable SPI on several boardsMichal Simek
Enable GQSPI driver, SF command and SPL support for some platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Setup DM_ETH/MMC if NET/MMC is enabledMichal Simek
Setup proper ETH/MMC dependency for the whole platform. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-10-16arm64: zynqmp: Enable MP by default via KconfigMichal Simek
Simplify defconfig for ZynqMP but keep option not to enable it for mini targets. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-19arm64: zynqmp: Sync defconfigs in connection to DEFINE_TCM_OCM_MMAPMichal Simek
CONFIG_MP was added to Kconfig with enabling CONFIG_DEFINE_TCM_OCM_MMAP=y for zynqmp boards. This option is enabled by default that's why it shouldn't be in defconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-06-04xilinx: Sync symbols location in defconfigsMichal Simek
CONFIG_DEBUG_UART_BASE and CONFIG_DEBUG_UART_CLOCK have changed that's why this sync. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-18arm64: zynqmp: Use DWC3 generic driver and DM_USBMichal Simek
Remove harcoded XHCI lists and detect mode, speed based on DT. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Serial-changes: 2 - Remove also XHCI macros from hardware.h - Remove additional new line in zcu106
2018-05-11arm64: zynqmp: Show model information instead of custom IDENT_STRINGMichal Simek
DISPLAY_BOARDINFO in OF case show model identification string from DT. Enable this feature instead of custom IDENT_STRING which does the same thing. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2018-04-09arm64: zynqmp: Add support for zc1751 dc3Michal Simek
zc1751 is based board with dc3 extenstion card which is used for silicon validation. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
