path: root/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-22fpga: xilinx: zynqmp: Add PL bitstream download support for ZynqMPSiva Durga Prasad Paladugu
Add PL bitstream dowload support for ZynqMP Bitstream will be validated by uboot and loaded to PL by invoking an smc instruction to ATF which route this request to PMU FW which will take care of loading it to PL Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-20configs: Re-syncTom Rini
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-08-02ARM64: zynqmp: Do not enable DM_MMC by defaultMichal Simek
The patch: "dm: mmc: zynq: Convert zynq to use driver model for MMC" (sha1: 329a449f2c289b4de8f892fca1d9379ce5fd81b8) added dependency on enabling some MMC options by default. There are minimal ZynqMP configurations which require only minimal configurations to be enabled to keep u-boot size as lower as possible. Move options to defconfig instead. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-08-02ARM64: zynqmp: Define config USB_STORAGE through defconfigMichal Simek
Define config USB_STORAGE through defconfig for all Xilinx ZynqMP boards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-08-02xilinx: Sync defconfigs with the latest Kconfig layoutMichal Simek
Update Microblaze, Zynq and ZynqMP defconfigs to reflect latest Kconfig changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22ARM64: zynqmp: Enable SPL for all zynqmp boardsMichal Simek
Compile SPL for all boards even psu_init.c/h files are not in the tree yet. But this change enables covering SPL issues in mainline. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22ARM64: zynqmp: Enable CLK and SPL_CLK by defaultMichal Simek
Serial driver starts to use clk framework that's why enable it by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-22ARM: zynq/zynqmp: Use the default CONFIG_BOOTDELAY=2Michal Simek
Based on: "ARM: uniphier: use the default CONFIG_BOOTDELAY=2" (sha1: 7c8ef0feb97586d35b0296b48903daef8c06ab21) "I do not insist on CONFIG_BOOTDELAY=3. The default value in Kconfig, CONFIG_BOOTDELAY=2, is just fine for these boards." Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Modified: configs/ls1012afrdm_qspi_defconfig configs/ls1012aqds_qspi_defconfig configs/ls1012ardb_qspi_defconfig include/configs/ls1012afrdm.h include/configs/ls1012aqds.h include/configs/ls1012ardb.h Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-06ARM64: zynqmp: Extend malloc space before relocationMichal Simek
For boards which have more devices it is necessary to extend malloc space. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Enable support for SPL FIT imagesMichal Simek
Enable support for RAM based FIT images read by SPL. Empty function for now to keep compiler happy. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Add debug uart for zc1751-dc2Michal Simek
Add debug uart for zc1751-dc2. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Enable CMD_NAND via KconfigMichal Simek
Simplify board file by enabling CMD_NAND via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-27efi_loader: Select bounce buffers for known-bad boardsAlexander Graf
We know for certain that we have 32bit DMA hardware, but 64bit addresses on LS2085A and ZynqMP, so let's enable EFI bounce buffers for all defconfigs on these SoCs. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-05-24ARM64: zynqmp: Enable CLK frameworkMichal Simek
ZynqMP is using fixed clocks now that's why enabling it to be available for drivers. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-05-24ARM64: zynqmp: Enable HUSH parser for all zynqmp targetsMichal Simek
Enable HUSH for all zynqmp boards which don't have it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-20configs: Update some Xilinx configsTom Rini
As part of 3457bba these configs didn't get updated. Update them now. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-13ARM64: zynqmp: Use i2c cadence DM driverMichal Simek
Use i2c cadence DM driver for all zynqmp targets except ZCU102 because I2C muxes and PCA953x are not supported in the tree yet. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-04-13ARM64: zynqmp: Add support for zc1751 with DC cardsMichal Simek
Support ZynqMP zc1751 with DC cards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
