path: root/configs/xilinx_zynqmp_zc1275_revA_defconfig
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-02-07configs: Remove SF_DUAL_FLASHVignesh R
SF_DUAL_FLASH claims to enable support for SF_DUAL_STACKED_FLASH and SF_DUAL_PARALLEL_FLASH. But, in current U-Boot code, grepping for above enums yield no user and therefore support seems to be incomplete. Remove these configs so as to avoid confusion. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-02-01spl: Kconfig: Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FATTien Fong Chee
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-24arm64: zynqmp: Convert all reference boards to OF_SEPARATEMichal Simek
Build warning was added by: "fdt: Add warning about CONFIG_OF_EMBED" (sha1: 841d5fbae4e993476fa87d8933db0cd58d3c2d41) ZynqMP mini configurations are not moved yet and it is questionable if make sense to move them too. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Disable MMC for for zc12xx_revA boardsMichal Simek
All these boards have no SD enabled. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Enable FPGA_LOAD_SECURE commandMichal Simek
Enable fpga load secure feature for xilinx platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Enable ISSI flash for some platformsMichal Simek
Enable ISSI flash for platforms. Xilinx reference boards are also used internally with different flash part to increase coverage that's why enable also ISSI parts for all these boards even if that board is released only with one part. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Enable SPI on several boardsMichal Simek
Enable GQSPI driver, SF command and SPL support for some platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24arm64: zynqmp: Setup DM_ETH/MMC if NET/MMC is enabledMichal Simek
Setup proper ETH/MMC dependency for the whole platform. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-10-16arm64: zynqmp: Enable MP by default via KconfigMichal Simek
Simplify defconfig for ZynqMP but keep option not to enable it for mini targets. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19arm64: zynqmp: Sync defconfigs in connection to DEFINE_TCM_OCM_MMAPMichal Simek
CONFIG_MP was added to Kconfig with enabling CONFIG_DEFINE_TCM_OCM_MMAP=y for zynqmp boards. This option is enabled by default that's why it shouldn't be in defconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-06-04xilinx: Sync symbols location in defconfigsMichal Simek
CONFIG_DEBUG_UART_BASE and CONFIG_DEBUG_UART_CLOCK have changed that's why this sync. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-31arm64: zynqmp: Sync defconfigs with latest Kconfig layoutMichal Simek
Sync defconfigs. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-11arm64: zynqmp: Show model information instead of custom IDENT_STRINGMichal Simek
DISPLAY_BOARDINFO in OF case show model identification string from DT. Enable this feature instead of custom IDENT_STRING which does the same thing. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2018-04-09arm64: zynqmp: Add support for zc12xx boardsMichal Simek
Add support for zc12xx boards. All of them are internal boards for silicon validation and share very similar base platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
