path: root/configs/xilinx_zynqmp_virt_defconfig
2020-08-20xilinx: zynqmp: Enable DFU tftp supportMichal Simek
Enable DFU tftp support for firmware update. Fill dfu_ram_tftp variable to have command present for showing how to use it. boot FIT image has been created from below fragment. Key part is that type of image has to be firmware. Also based on experiment load property is completely ignored and base addresses are taken from dfu_alt_info variable. $ cat update_uboot.its /dts-v1/; / { description = "Automatic U-Boot update"; #address-cells = <1>; images { Image { description = "Kernel"; data = /incbin/("/tftpboot/Image"); compression = "none"; arch = "arm64"; type = "firmware"; os = "linux"; load = <0x80000>; entry = <0x80000>; hash-1 { algo = "sha1"; }; }; system.dtb { description = "DTB"; data = /incbin/("/tftpboot/system.dtb"); compression = "none"; arch = "arm64"; type = "firmware"; load = <0>; hash-1 { algo = "sha1"; }; }; }; }; $ mkimage -f update_uboot.its /tftpboot/boot When U-Boot starts get IP address and server IP. dhcp setenv serverip 192.168.0.105 And then run prepared command. run dfu_ram_tftp Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-08-20xilinx: Enable preboot feature for ZynqMP and VersalMichal Simek
Enable preboot functionality for ZynqMP and Versal platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-07-28configs: migrate CONFIG_SPL_LOAD_FIT_ADDRESS to defconfigsPeng Fan
Done with: ./tools/moveconfig.py -S SPL_LOAD_FIT_ADDRESS ./tools/moveconfig.py -S SPL_LOAD_FIT_ADDRESS -H Signed-off-by: Peng Fan <peng.fan@nxp.com> [trini: A few more migrations] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-06-26spi: Enable missing CONFIG_SPL_DM_SPI supportTom Rini
Due to how the Makefile logic is we currently get DM_SPI support in SPL enabled by having DM_SPI enabled for full U-Boot but not having CONFIG_SPL_DM_SPI set. Add this missing option to boards that were inadvertently making use of it. Cc: Adam Ford <aford173@gmail.com> Cc: Akash Gajjar <akash@openedev.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Andy Yan <andy.yan@rock-chips.com> Cc: Anup Patel <anup.patel@wdc.com> Cc: Atish Patra <atish.patra@wdc.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Chee Hong Ang <chee.hong.ang@intel.com> Cc: Chin-Liang See <clsee@altera.com> Cc: Dalon Westergreen <dwesterg@gmail.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Klaus Goger <klaus.goger@theobroma-systems.com> Cc: Levin Du <djw@t-chip.com.cn> Cc: Ley Foon Tan <ley.foon.tan@intel.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Luca Ceresoli <luca@lucaceresoli.net> Cc: Marek Vasut <marex@denx.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Mike Looijmans <mike.looijmans@topic.nl> Cc: Nicolas Ferre <nicolas.ferre@microchip.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Palmer Dabbelt <palmer@dabbelt.com> Cc: Patrick Delaunay <patrick.delaunay@st.com> Cc: Paul Walmsley <paul.walmsley@sifive.com> Cc: Pavel Machek <pavel@denx.de> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Cc: Suniel Mahesh <sunil@amarulasolutions.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Wolfgang Grandegger <wg@aries-embedded.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2020-06-26Convert CONFIG_BOARD_EARLY_INIT_F et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_BOARD_EARLY_INIT_F CONFIG_BOARD_EARLY_INIT_R Signed-off-by: Tom Rini <trini@konsulko.com>
2020-06-25Merge tag 'xilinx-for-v2020.10' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next Xilinx changes for v2020.10 Versal: - xspi bootmode fix - Removing one clock from clk driver - Align u-boot memory setting with OS by default - Map TCM and OCM by default ZynqMP: - Minor DT improvements - Reduce console buffer for mini configurations - Add fix for AMS - Add support for XDP platform Zynq: - Support for AES engine - Enable bigger memory test by default - Extend documentation for SD preparation - Use different freq for Topic miami board mmc: - minor GD pointer removal net: - Support fixed-link cases by zynq gem - Fix phy looking loop in axi enet driver spi: - Cleanup global macros for xilinx spi drivers firmware: - Add support for pmufw reloading fpga: - Improve error status reporting common: - Remove 4kB addition space for FDT allocation
2020-06-24topic: zynqmp: Add support for zynqmp-xilinx-xdp platformMike Looijmans
XDP - Xilinx Drone Platform is a board for drones or other UAV. Pinmux the SD card by default, and if the SD card detect line is high (inactive) then pinmux the SD1 interface to EMIO instead. SD is placed on extension card and shares connection with on board wife. That means that when SD card is present in the board wifi can't be used. There seems to be an issue with DDR access from PL at 2400MT/s, after updating the PMU and ATF firmware this is causing extremely slow DDR access. Reducing the DDR speed from 2400 to 2133 appears to solve that issue, even though the hardware has proven to be 2400 capable. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-06-12net: phy: Add support for TI PHY initDan Murphy
ti_phy_init function was allocated to the DP83867 PHY. This function name is to generic for a specific PHY. The function can be moved to a TI specific file that can register all TI PHYs that are defined in the defconfig. The ti_phy_init file will contain all TI PHYs initialization so that only phy_ti_init can be called from the framework. In addition to the above the config flag for the DP83867 needs to be changed in the Kconfig and dependent defconfig files. The config flag that was used for the DP83867 was also generic in nature so a more specific config flag for the DP83867 was created. Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Dan Murphy <dmurphy@ti.com>
2020-06-04serial: Convert ARM_DCC to KconfigTom Rini
The symbol "CONFIG_ARM_DCC" is used to control building drivers/serial/arm_dcc.c. Provide a simple Kconfig entry for this. Cc: Luca Ceresoli <luca@lucaceresoli.net> Cc: Michal Simek <monstr@monstr.eu> Cc: Tom McLeod <tom.mcleod@opalkelly.com> Cc: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-27xilinx: Enable MTD and UBIFS for zynq and zynqmpMichal Simek
Both of them have nand controller that's why it is good to enable it because these configurations are also covered by testing. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-04-06arm64: zynqmp: Enable netconsole for ZynqMPMichal Simek
It is nice feature Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-04-06arm64: zynqmp Add support for zcu102 rev1.1Michal Simek
rev1.1 has different DDR sodimm module that's why it requires different DDR configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2020-01-14arm64: zynqmp: Add support for zcu1285 revA boardMichal Simek
zcu1285 is the same as zcu1275 but it is using Avnet FMC http://www.ultrazed.org/product/network-fmc-module Unfortunately not everything is connected now that's why this is only describing system which Xilinx is using. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Add support for zcu208Michal Simek
The board is very similar to zcu216 with zu49dr device. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Move PANIC to KconfigMichal Simek
Convert another option Kconfig. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Use zynqmp_virt platformMichal Simek
Decrease amount of the similar defconfigs and use generic one instead. The change was declared by commit 4b37c13dc353 ("arm64: zynqmp: Introduce virtual defconfig") and this patch removes configs for the most of the boards. Utra96/zcu100/zcu102/zcu102 and ZynqMP based System controllers *a2197*. have been also boot tested to make sure that funcionality remains the same. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Add missing Kconfig options to zynqmp_virt platformMichal Simek
These options are taken from zcu102/104 platforms. Also use OF_SEPARATE instead of OF_BOARD. Maybe at some point this option will be taken back but as of now board detection is not ready. export DEVICE_TREE="zynqmp-zcu102-revA" make xilinx_zynqmp_virt_defconfig make -j Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-08arm64: zynqmp: Introduce virtual defconfigIbai Erkiaga
Add virtual defconfig for ZynqMP architecture using of_board dtb. This defconfig should become generic config for all ZynqMP boards. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
