path: root/configs/xilinx_zynqmp_virt_defconfig
2020-01-22configs: Resync with savedefconfigTom Rini
2020-01-14arm64: zynqmp: Add support for zcu1285 revA boardMichal Simek
zcu1285 is the same as zcu1275 but it is using Avnet FMC http://www.ultrazed.org/product/network-fmc-module Unfortunately not everything is connected now that's why this is only describing system which Xilinx is using. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Add support for zcu208Michal Simek
The board is very similar to zcu216 with zu49dr device. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Move PANIC to KconfigMichal Simek
Convert another option Kconfig. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Use zynqmp_virt platformMichal Simek
Decrease amount of the similar defconfigs and use generic one instead. The change was declared by commit 4b37c13dc353 ("arm64: zynqmp: Introduce virtual defconfig") and this patch removes configs for the most of the boards. Utra96/zcu100/zcu102/zcu102 and ZynqMP based System controllers *a2197*. have been also boot tested to make sure that funcionality remains the same. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Add missing Kconfig options to zynqmp_virt platformMichal Simek
These options are taken from zcu102/104 platforms. Also use OF_SEPARATE instead of OF_BOARD. Maybe at some point this option will be taken back but as of now board detection is not ready. export DEVICE_TREE="zynqmp-zcu102-revA" make xilinx_zynqmp_virt_defconfig make -j Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-08arm64: zynqmp: Introduce virtual defconfigIbai Erkiaga
Add virtual defconfig for ZynqMP architecture using of_board dtb. This defconfig should become generic config for all ZynqMP boards. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
