path: root/configs/xilinx_zynqmp_virt_defconfig
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-27xilinx: Enable MTD and UBIFS for zynq and zynqmpMichal Simek
Both of them have nand controller that's why it is good to enable it because these configurations are also covered by testing. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-04-06arm64: zynqmp: Enable netconsole for ZynqMPMichal Simek
It is nice feature Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-04-06arm64: zynqmp Add support for zcu102 rev1.1Michal Simek
rev1.1 has different DDR sodimm module that's why it requires different DDR configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2020-01-14arm64: zynqmp: Add support for zcu1285 revA boardMichal Simek
zcu1285 is the same as zcu1275 but it is using Avnet FMC http://www.ultrazed.org/product/network-fmc-module Unfortunately not everything is connected now that's why this is only describing system which Xilinx is using. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Add support for zcu208Michal Simek
The board is very similar to zcu216 with zu49dr device. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Move PANIC to KconfigMichal Simek
Convert another option Kconfig. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Use zynqmp_virt platformMichal Simek
Decrease amount of the similar defconfigs and use generic one instead. The change was declared by commit 4b37c13dc353 ("arm64: zynqmp: Introduce virtual defconfig") and this patch removes configs for the most of the boards. Utra96/zcu100/zcu102/zcu102 and ZynqMP based System controllers *a2197*. have been also boot tested to make sure that funcionality remains the same. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: zynqmp: Add missing Kconfig options to zynqmp_virt platformMichal Simek
These options are taken from zcu102/104 platforms. Also use OF_SEPARATE instead of OF_BOARD. Maybe at some point this option will be taken back but as of now board detection is not ready. export DEVICE_TREE="zynqmp-zcu102-revA" make xilinx_zynqmp_virt_defconfig make -j Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-08arm64: zynqmp: Introduce virtual defconfigIbai Erkiaga
Add virtual defconfig for ZynqMP architecture using of_board dtb. This defconfig should become generic config for all ZynqMP boards. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
