path: root/configs/xilinx_zynqmp_mini_emmc1_defconfig
2019-01-24arm64: zynqmp: Setup DM_ETH/MMC if NET/MMC is enabledMichal Simek
Setup proper ETH/MMC dependency for the whole platform. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-30arm64: zynqmp: Wire mini-emmc1 configuration with zcu102Michal Simek
For testing purpose use zcu102 which has SD at controller 1 and this can be used for testing this mini configuration. U-Boot 2018.11-00279-gdc482e7ee092 (Nov 30 2018 - 10:22:56 +0100) Model: ZynqMP MINI EMMC1 Board: Xilinx ZynqMP DRAM: 512 MiB EL Level: EL3 MMC: sdhci@ff170000: 0 In: dcc Out: dcc Err: dcc ZynqMP> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-30arm64: zynqmp: Use minimal size for environment variablesMichal Simek
There is no reason to have huge space for variables because none is using that. But there are some which are setup automatically. baudrate=115200 fdtcontroladdr=ffffa0d0 stderr=dcc stdin=dcc stdout=dcc Environment size: 72/124 bytes Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-30arm64: zynqmp: Do not save variables about boardMichal Simek
No reason to save this data to environment. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-29arm64: zynqmp: Disable autoboot feature for miniMichal Simek
There is no reason to have autoboot enabled because it should never start anything automatically. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-26arm64: zynqmp: Disable bootelf and fdt commands for mini configurationsMichal Simek
There is no reason to enable these commands for mini configurations. It saves some space: aarch64: (for 2/2 boards) all -19076.0 bss -1048.0 data -1720.0 rodata -3840.0 text -12468.0 xilinx_zynqmp_mini_emmc1: all -19076 bss -1048 data -1720 rodata -3840 text -12468 xilinx_zynqmp_mini_emmc0: all -19076 bss -1048 data -1720 rodata -3840 text -12468 Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-10-16arm64: zynqmp: Enable MP by default via KconfigMichal Simek
Simplify defconfig for ZynqMP but keep option not to enable it for mini targets. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-09-26arm64: zynqmp: Handle CONFIG_BOARD_LATE_INIT via KconfigMichal Simek
Disable BOARD_LATE_INIT via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19arm64: zynqmp: Setup ENV_SIZE via Kconfig for mini targetsMichal Simek
Mini targets are using different ENV_SIZE then standard one that's why defconfigs should be updated to simplify config files. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-06-15arm64: zynqmp: Split emmc configuration into emmc0 and emmc1Siva Durga Prasad Paladugu
This patch splits the current mini emmc configuration into emmc0 and emmc1 configurations because emmc is probed at boot time and on systems which have only one interface mini configuration is failing on unused interface. This patch also adds required clock node in dts and enables CONFIG_MMC_SDHCI_ZYNQ through defconfig. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
