path: root/configs/xilinx_zynqmp_a2197_revA_defconfig
2019-10-08arm64: zynqmp: Define default SYS_PROMPTMichal Simek
All boards are using the same prompt that's why add it as default value to Kconfig to simplify defconfigs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2019-10-08arm64: zynqmp: Add a2197 memory board revAMichal Simek
Similar to processor board but i2c structure is completely different. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-08arm64: zynqmp: Add System Controller for a2197-g/pMichal Simek
Similar SCs but different wiring. - dc_i2c is connected to X-PRC cards that's why label is required to have an option to hook up some devices. - Exactly identify i2c devices on x-prc boards. In case of missing i2c connection devices won't be accessible. - USB 0 should be device mode with super speed. - USB 1 should be host mode. - Fix i2c mux reset pin entry - commented, not verified. - Fix i2c1 eeprom compatible string - it is an ST 128Kbit device. Need to use atmel fallback. - Fix si570 I2C slave address and add corresponding part numbers. - Enable AMS for system monitoring. - phy reset property should be commented because it will throw a warning dump when called from context that can sleep. No support for phys property (zynqmp phy driver) with SGMII. Add is-internal-pcspma property required by uboot. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Harini Katakam <harini.katakam@xilinx.com>
2019-10-08arm64: zynqmp: Add generic a2197 system controller configMichal Simek
Add generic configuration for a2197-p/-m/-g boards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
