CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
Prepare v2021.10-rc4
# gpg: Signature made Tue 14 Sep 2021 06:58:32 PM EDT
# gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C
# gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate]
# Conflicts:
# board/Arcturus/ucp1020/spl.c
# cmd/mvebu/Kconfig
# common/Kconfig.boot
# common/image-fit.c
# configs/UCP1020_defconfig
# configs/sifive_unmatched_defconfig
# drivers/pci/Kconfig
# include/configs/UCP1020.h
# include/configs/sifive-unmatched.h
# lib/Makefile
# scripts/config_whitelist.txt
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
Mini u-boot timer clock is not updated when u-boot is migrated from
emulator to silicon. Due to this slower clock of 2.72Mhz, delay() functions
are not working accurately. Update CONFIG_COUNTER_FREQUENCY to 100Mhz.
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
The "cmd/Kconfig" has a TODO description for CMD_MISC that it should
really be named as CMD_SLEEP. Change it in the whole source tree.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
CONFIG_BZIP2
CONFIG_GZIP
CONFIG_LZO
CONFIG_ZLIB
CONFIG_LZMA
CONFIG_LZO
The symbol "CONFIG_ARM_DCC" is used to control building
drivers/serial/arm_dcc.c. Provide a simple Kconfig entry for this.
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Tom McLeod <tom.mcleod@opalkelly.com>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
[trini: Fix kmcoge5ne board, re-run migration as well]
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
bdi is useful to see how memory is mapped.
Also enable 3 memory banks to be mapped.
The PSCI_RESET and EXPERT are not needed for mini configurations so remove
them to save space.
Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
Define board_late_init which performs bootmode detection
and prepares corresponding distro boot commaand sequence.
Also disable it for mini platforms because simply there is no need to have
it enabled.
But also disable it for virtual platform because Qemu is not modelling this
register space that's why travis testing would fail. This configuration
should be reverted when mainline Qemu is updated.
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with
allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line
with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of
cmd/ switch to using CONFIG_IS_ENABLED() to test what is set.
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig
parameters; only for the ARC architecture. This patch turns these two
parameters into Kconfig items everywhere else they are found.
All of the include/configs/* and defconfig changes in this patch are
for arm machines only. The Kconfig changes for arc, nds32, riscv,
and xtensa have been included since these symbols are found in code
under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined
include/configs/* or defconfigs for these architectures exist which
include these symbols.
These results have been confirmed with tools/moveconfig.py.
Acked-by: Alexey Brodkin <abrodkin@snopsys.com>
Signed-off-by: Trevor Woerner <trevor@toganlabs.com>
[trini: Re-migrate for a few more boards]
This patch adds new mini target for versal.
This configuration is very minimal in size which runs
from OCM. It contains support for mtest which can be
used for running DDR memory tests.
