path: root/configs/xilinx-ppc440-generic_defconfig
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27ppc: xilinx-ppc440-generic: Wire LL_TEMAC driverRicardo Ribalda Delgado
If the xparameters file contains a LL_TEMAC definition compile its driver and the net commands. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx-ppc4xx: Port to DM serialRicardo Ribalda Delgado
xilinx_uartlite has been ported to DM, this patch makes the xilinx-ppc405-generic and the xilinx-ppc440-generic boards use the new DM driver. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
