DM_VIDEO conversion deadline has passed, disable VIDEO config.
Cc: Marek Vasut <marek.vasut@gmail.com>
CONFIG_NETCONSOLE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_MXS_GPIO
Travis-CI: https://travis-ci.org/lmajewski/u-boot-dfu/builds/571260789
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Peng Fan <peng.fan@nxp.com>
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
The motivation for moving MX23 selection to Kconfig is to be able
to better handle NAND MXS selection through Kconfig.
This selection method also aligns with the way other i.MX SoCs are
selected in U-Boot.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
We need to select an interface for the usb_ether gadget, and they haven't
been converted to Kconfig yet. Add a choice to make sure we have an option
selected, and convert all the users.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The USB Ethernet gadget option has not yet been moved to Kconfig, let's
deal with that.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
CONFIG_ARCH_MISC_INIT
CONFIG_BOARD_EARLY_INIT_F
Move (and rename) the following CONFIG options to Kconfig:
CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI)
CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS)
CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC)
CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS)
CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA)
CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI)
They are the same option names as used in Linux.
This commit was created as follows:
[1] Rename the options with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e '
s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g
s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g
s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g
s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g
s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g
s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g
[2] Commit the changes
[3] Create entries in driver/mmc/Kconfig.
(copied from Linux)
[4] Move the options with the following command
tools/moveconfig.py -y -r HEAD \
MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI
[5] Sort and align drivers/mmc/Makefile for readability
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
move VERSION_VARIABLE from board config file into a
Kconfig option.
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
them from include/configs.
