For legacy reasons we were defining the card detect GPIO for all sunxi
boards in each board's defconfig.
There is actually no need for a card-detect check in the SPL code (which
consequently has been removed already), and also in U-Boot proper we
have DM code to query the CD GPIO name from the device tree.
That means we don't have any user of that information left, so can
remove the definitions from the defconfigs.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Samuel Holland <samuel@sholland.org>
Tested-by: Samuel Holland <samuel@sholland.org>
Commit 08574ed339fb ("Convert CONFIG_SYS_MONITOR_LEN to Kconfig") moved
the definition of said config variable from the common sunxi header to
*every board's* defconfig.
This is a platform choice, not board specific, so remove the variable
from there, instead set the one value for all Allwinner boards in
Kconfig.
Acked-by: Jernej Skrabec <jernej.skrabec@gmail.com>
To do this, we set a default of 0 for everyone because there are a
number of cases where we define CONFIG_SYS_MONITOR_LEN but the only
impact is that we set TOTAL_MALLOC_LEN to be CONFIG_SYS_MALLOC_LEN +
CONFIG_ENV_SIZE, so we must continue to allow all boards to set this
value. Update the SPL code to use 200 KB as the default raw U-Boot size
directly, if we don't have a real CONFIG_SYS_MONITOR_LEN value.
The X96 Mate TV box is a TV box with the Allwinner H616 SoC. It is
available with up to 4GB of DRAM and 64GB eMMC.
The DRAM chips require a different configuration when compared to the
OrangePi Zero2, we must not use read/write training and write leveling.
Add a defconfig for the box, so that we can easily build U-Boot for it.
We synced the .dts file already from the kernel tree.
Reviewed-by: Jernej Skrabec <jernej.skrabec@gmail.com>
