path: root/configs/x600_defconfig
2017-01-20ARM: Default to using optimized memset and memcpy routinesTom Rini
We have long had available optimized versions of the memset and memcpy functions that are borrowed from the Linux kernel. We should use these in normal conditions as the speed wins in many workflows outweigh the relatively minor size increase. However, we have a number of places where we're simply too close to size limits in SPL and must be able to make the size vs performance trade-off in those cases. Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: Heiko Schocher <hs@denx.de> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-09-16Convert CONFIG_SPL_NOR_SUPPORT to KconfigSimon Glass
2016-05-31arm: spear: x600: Remove EFI support to reduce image sizeStefan Roese
EFI is not needed on x600. So lets remove the EFI support to make it fit into the 0x60000 image size limit again. Signed-off-by: Stefan Roese <sr@denx.de>
2016-05-17i2c: config: Move SYS_I2C_DW to KconfigStefan Roese
This patch moves all appearances of CONFIG_SYS_I2C_DW from the config header to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Alexey Brodkin <abrodkin@synopsys.com>
2015-11-25arm: spear: x600: Enable tiny-printfStefan Roese
Enabling the new tiny-printf function makes the SPL image fit again in the 8KiB restricted area. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
